Everything posted by druxey
Part of the problem both of you gentlemen may be facing is relying too much on station sections so far aft. You can'r assume their accuracy here. The contours change very rapidly as seen in vertical section. I'd rely far more on waterlines (aka transom shapes), buttock lines and proof diagonals to fair things up.
ancre La Salamandre by tadheus - 1:24
druxey replied to tadheus's topic in - Build logs for subjects built 1751 - 1800
That is an interesting question! Would the three planks have been put together with tongue-and-groove joints? If not, then your suggestion makes sense. It would make more sense if the battens ran next to the frame. Then the scuttle would run smoothly without twisting. -
Hmm. More anomalies.... Well, no-one is perfect! -
Then either the draftsman forgot to draw the openings on the deck plan or the deck planks are removable. That the planks are moveable is less likely, as the beams would be rebated to take the plank ends. I think that those two pairs of short lines in the deck plank between the beams show moveable square covers. -
Is there either a scuttle in one of the bulkheads, or do those short lines in the deck above indicate small hatch openings? -
AOTS series often contain errors, unfortunately. The planking pattern you show is one example. The second version is correct. If the first layout were actually used, once one butt gave way, the rest would follow like a zipper. (This particularly applies to hull planking). The second, staggered pattern minimizes this possibility and is much stronger.
- 4 replies
- deck planking
- butt shift
Cutty Sark by NenadM
druxey replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
I'm sorry also to read of your friends' passings. In troubled times, model making is good therapy. Congratulations on your children's successes, though.- 4,152 replies
- cutty sark
- tehnodidakta
Poor Man's Photo Etch Parts
druxey replied to torpedochief's topic in Metal Work, Soldering and Metal Fittings
Very clever adaptation of conventional photo-etching, Don! I wonder how small you can go using this process. Have you experimented with that? -
You need a tissue that will stand up to wetting without disintegrating. Also, shiny would be distracting, I think.
You figurehead might look like Kermit to you, Omega, but at that scale the overall effect or impression is what matters. In this case, the effect looks very good.
50-gun ship by newbee - 1/72 scale
druxey replied to newbee's topic in - Build logs for subjects built 1751 - 1800
Good things do take time, you know! Looks like you are on your way, Newbee. -
Terrific work, as usual, Ed! Would marking, say, the top timber height of every third or fourth toptimber and running a light batten to get the intermediate ones have been a option? I'm curious as to why you used the height gauge to measure every last one.
- 3,618 replies
- young america
- clipper
Sorry about your early snowfall, Michael. Fire up that wood stove! Great way to use up your scrap wood....
- 2,215 replies
So, one of your ships has finally been found! I guess you'll need to rename yourself EorT, for the moment.
- 346 replies
- terror
- polar exploration
This framing photo shows you how the wing transom is shaped at the outer corners. (This model is of a sixth rate, so is smaller and has less transoms than a 74, but is essentially similar.) Note the smooth run of the filling transoms' surfaces up to the margin line. There is no sharp turn or bend, which appears on your frame grab.
