Everything posted by druxey
One can get even finer ended needle-nose pliers (jewelers' supply houses), but the best Swedish ones are quite pricey at around US$50.00. However, they perform beautifully. Just don't drop them accidentally on to concrete as I once did!
So, the frames are becoming 'bolt dense'? Soon there will be very little frame wood left - just a maze of bolt heads! Your model continues to inspire, Ed.
- 3,618 replies
- young america
- clipper
THE BLACKEN-IT TRIALS
druxey replied to Erebus and Terror's topic in Metal Work, Soldering and Metal Fittings
Yes, E&T, the Scotch-Brite are the ones I'm using right now. -
OK, OK! In my defence: I use a pair of pliers for changing blades and have never performed inadvertent surgery upon myself. I'm sorry that I ever brought the subject up, Ed! Enjoy your razor blades, ladies and gentlemen.
- 3,618 replies
- young america
- clipper
Recently I've experimented with abrading the metal surface before blackening in order to avoid nasty chemicals. I've been using Scotch-BriteTM radial bristle disks that are 400-grit. These disks, in a rotary tool, make short work of getting to a clean metal surface. The flexible bristles get into nooks and crannies nicely. I use the same technique prior to silver soldering. -
Lovely, lovely. But Ed - with all your sophisticated tools, jigs and fixtures, you are still using a razor blade??? Try a #11 surgical blade in a surgical handle.
- 3,618 replies
- young america
- clipper
50-gun ship by newbee - 1/72 scale
druxey replied to newbee's topic in - Build logs for subjects built 1751 - 1800
Apparently the articles on the 50-gun ship also appeared in book form, along with two other models by R.J Collins (Myrmidon of the 1780's and a sixth rate of the 1680's). A search on abebooks might yield you a result. -
Thank you for these exhaustive test results, E&T. They are very informative. -
I don't know which you are better at: model making or photography! Both are excellent, Gaetan.
- 728 replies
- le fleuron
- 64 gun
ancre Le Fleuron by cabrapente - FINISHED
druxey replied to cabrapente's topic in - Build logs for subjects built 1501 - 1750
Now that was a lot of work! Very nicely done, Cabrapente. I particularly like the metal strops that you've made.- 332 replies
- le fleuron
- 64 gun
There are 5 sheets in the plan set, apparently. The how to model this subject was described in a series of 1953 Model Engineer articles by R.J. Collins. I believe that the plan set is still available (search on-line) and old copies of Model Engineer can be found on e-Bay. Happy hunting! -
Renshape for scratch builders
druxey replied to rshousha's topic in Modeling tools and Workshop Equipment
High density foams have been around for a while. I've used them in theatrical set construction in the past. They work very well for carving in detail but, as mentioned, are very expensive and only available in large chunks. My only reservation would be the longevity of the material, but for most folk this probably isn't a big consideration.- 11 replies
- scratch building
- parts
- (and 8 more)
Superb work, Ed - but now you've made me run out of superlatives!
- 3,618 replies
- young america
- clipper
Interesting thread. I recall visiting an English country church in my childhood. There was an ossuary in the undercroft with stacks of both femurs and skulls. I presume these had been disinterred from the churchyard to make room for newer arrivals (think of the graveyard scene in Hamlet).
Pete is correct: in the 18th century the copper strakes started at the keel and were laid parallel to it. This results in the highest strakes running out at an angle fore and aft at the waterline. On way the sharp ends were dealt with was with a wood batten nailed along the waterline overlapping the edges of the copper. Another, probably later, way was to run the top two strakes of copper along the waterline. See the photos of a coppered model of Bellona on the National Maritime Museum's 'Collections' site that shows the earlier method.
