druxey
Everything posted by druxey
  1. Should be accepted for display? Should be, Peter??? If not, MSW will come down hard on the NYYC. Please give Dan my congratulations on such a fine detailed model. Very well done!
  2. Automatic scaling with either Adobe or with the resident software on one's printer is something to be eternally vigilant for!
  3. Congratulations on completing this magnum opus, Chris. She looks very impressive.
  4. Reading in Steel's tables, it looks as if (1805) there were two methods of retaining the tiller at the time. One was with eyebolts driven into both sides of the tiller two feet forward of the rudderhead and two eyebolts in the 'fore part of the rudderhead'. Presumably tackle was rigged each side between these. The other method was as described above. Apparently the tiller could become loose with shrinkage over time, according to Steel. Also a norman and chocks were to be provided, but it does not describe how these were used! I don't know whether this is helpful or simply provides more confusion to the discussion....
  5. Waterstops and wedged scarphs: very nice details, Ed! You are out-doing yourself this time around.
  6. Would they need locking together, in fact? The tiller engages the sweep with the gooseneck. Wouldn't that, and the tensioning tackle, prevent the tiller from moving forward and disengaging from the mortise in the rudder?
  7. Careful of taking any AOS book as gospel truth, Gary! I don't doubt that the arrangement shown was used but, as you ask, how early did this come into use? My suspicion is that it was closer to 1800 than 1760.
  8. Please take care, Toni: your hands are your most valuable asset. I trust the damage was not too serious.
  9. And so it really begins! This is going to be an enjoyable spectator sport.
  10. Very nice going, Chris. It's very gratifying when the work one did years ago pays off. Speaking of years, when my only daughter was young, no modeling happened for ten years after she was a few months old. So, your expectation of two more models after this may be realistic, especially if one is a monster 110-gun ship....
  11. My understanding is that ships' boats of the period had no standard color scheme. Often it was 'captain's fancy'; in other words, whatever the individual captain ordered. So you would be safe to use any of the standard colors of the day; ochre, blue, black and red. Or, as you've suggested, varnished. You're the captain!
  12. We hoist a glass to you on the laying of your keel, Ed! And eagerly await your progress reports....
  13. Are you speaking of the turns around the lashing? If so, these are important because they tighten any lashing. It forces the round turns down slightly between the two parts of the shroud so they 'bite' and prevent anything slipping. Using a sewing needle works perfectly for executing lashings.
  14. Damp - not wet! - brushes of various sizes can pick up dust and quite large particles by surface tension and/or adhesion. It's a tedious process, but will deal with everything the vacuum won't.
  15. Dan: I learned a great technique from a jeweller for silver soldering successive joints. She told me that, as well as using 'hard' (high melting point) for the first joint, 'medium' for the next and 'easy' for the third, you can protect previously soldered joints with yellow ochre. This is in powder form. Mix with a little water to a paste, then paint it over the joints you want protected. Heat will turn this red, but it will wash off when pickled. There is also now an 'extra easy' grade of silver solder available, but she doesn't recommend using it - it doesn't make a very good joint. Hope this is of some help.
  16. Mark: the prop could be uncoupled from the shaft before it was raised, in the vertical position.
  17. Tom: you mention 'no channels'. These ships did not have them in the traditional way. The deadeyes were usually attached to straps fixed to the bulwarks and appeared either through or just inside the rails. What you've done looks right.
  18. Most collars have eyes spliced into their ends and these ends are lashed around the spar. Start with a longer length of line than needed and start seizing the various blocks/hearts/eyes into it. Then form the eye splices at the ends of the collar.
  19. From 1:60 to 1:72 scale, Ed? Most of is tend to build to ever increasing scales as our eyesight becomes less than perfect! Looks like a terrific start.
  20. If well sealed and then well stirred, enamel paints will last a while. I have some tinlets (Humbrol, in this instance) from 1986 that are still good and being used now! A squirt from a can of inert gas on top to displace air before sealing will also extend paint life.
