Everything posted by druxey
Syren Ship Model Company immediately springs to mind. https://syrenshipmodelcompany.com/
A suggested upgrade for the rope you need would be from the Syren Ship Model Company. Line about .035" or .045" in tan would be about right. See: https://syrenshipmodelcompany.com/miniature-rope.php
- 62 replies
- First Build
- Grand Banks Dory
Ev ery model is a learning experience! Looks like you are doing well.
- 62 replies
- First Build
- Grand Banks Dory
Steaming right along there, Nils.... Not much space to turn her around in, though! Anything much larger would have to be a half-model.
- 330 replies
Just catching up with your (mis)adventures, Dafi! Some woking things do not scale well, unfortunately. Valiant effort, though.
Tiller tackle
druxey replied to Dr PR's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
Not Sim Comfort's error: the pages are facsimile from Steel himself! -
HMS EURYALUS by Matiz - FINISHED - scale 1:56
druxey replied to matiz's topic in - Build logs for subjects built 1801 - 1850
I love the point where the rails go on and the model starts to take on a finished look! Lovely work, as ever. -
Yes, one does not need aggressive clamps, as you've discovered. And wetting the wood to reshape it is a good fix. I like the fact that you are taking care building this model.
- 62 replies
- First Build
- Grand Banks Dory
Welcome aboard, Sam!
Transom Build Plans
druxey replied to Matrim's topic in CAD and 3D Modelling/Drafting Plans with Software
That is the wing transom! That is the one where the upper surface comes to an angle. Below is s set of transoms for another ship. 'W' is the wing transom, viewed from above. The grey line is the lower outline of the transom. Note that conventional numbering of the other transoms is from above to below. -
Transom Build Plans
It's more like an inverted cone: the top edge of the wing transom should come to a point or angle. -
A slightly damp rather than wet brush is effective for removing glue. I suspect you flooded the joint with water, diluting the glue in the joint. Otherwise, a great beginning!
- 62 replies
- First Build
- Grand Banks Dory
