Everything posted by druxey
A very methodical approach, Andrew. Looking good so far.
- 21 replies
- Muscongus Bay Lobster Smack
- Model Shipways
- (and 2 more)
HMS Euryalus 1803 by rlb - 1:48 scale
druxey replied to rlb's topic in - Build logs for subjects built 1801 - 1850
Shaping up nicely now, Ron. Those hawse timbers and cants are a big challenge to do. I can't image doing them at full size!- 122 replies
- Euryalus
- Plank-on-frame
(and 4 more)
As the other gentlemen said!
- 399 replies
- winchelsea
- Syren Ship Model Company
Some very fine cutting and shaping for that balustrade.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Ah, the learning curve. Some of use needed several attempts before we 'got it'. The up side is that you'll get it right first time on subsequent models.- 122 replies
- Euryalus
- Plank-on-frame
(and 4 more)
Most, if not all of us, don't fully realize what we are getting ourselves into until long after committing to a project. This applies to renovations as well as models.
- 740 replies
- Tudor
- restoration
(and 4 more)
Also see: https://seawatchbooks.com/products/swan-iv-sail-making-supplement-from-the-revised-and-expanded-edition-by-david-antscherl For sailmaking using Silkspan.
Yes, one comment: the plate should also include the maker's name! You are too modest.
- 43 replies
- Lowell Grand Banks Dory
- Model Shipways
Siggi: I thought you had labelled the draught Essex of 1741 (Post #875). What ship is that of then?
re the Essex draught: the floor battens retaining bricks are shown in plan view as the double lines. Aft of the stove is a heavy curved bulkhead with two doors. The stove area itself does not appear to be enclosed. No doorway is indicated along the lines of battens.
A small butane torch creates sufficient heat to anneal brass rod or tube. Be sure to do it on heat proof surface! When peening over, multiple very gentle taps work far better than banging down hard once or twice. This is especially true if the wood is soft, like basswood. Again back up with a very hard surface that will spread the other end of the piece being peened.
- 38 replies
- Norwegian Sailing Pram
- Model Shipways
Looks great, Ron. And you don't look so bad either!
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
Yes, those knees are much less likely to fracture. The copper bolts look very pleasing, if tedious to do.
