Everything posted by druxey
Basswood dents easily, but it's usually good when treated as you suggested.
- 40 replies
- Lowell Grand Banks Dory
- Model Shipways
Check out Bob's build log for additional helpful information:
- 144 replies
- Harriet Lane
- Model Shipways
Allan; you are assuming that Bray's lovely illustration is of a boat belonging to Pallas. I interpret that as a boat ashore that he saw, not one of his ship's boats.
- 24 replies
- Small boats
- cutter
Iron Mast Cap Orientations in Steam/Sailing Ships
druxey replied to BANYAN's topic in Masting, rigging and sails
Yes, the trim of masts could be altered. One method was by adjusting the wedges at the partners. Another method (in use in the 18th century, at least) was a moveable mast step that could slide a few inches fore and aft along the keelson. it was secured by pairs of wedges fore and aft of the step. The wedges rested between the step and bolts driven into the keelson.. -
Well, you have a wealth of information available, Rob! That makes for a good start.
- 55 replies
Tuning Copper sheathing
druxey replied to allanyed's topic in Building, Framing, Planking and plating a ships hull and deck
'Turned up' it is! Thank you, Bruce. -
Interesting use of the word 'tuned', James. -
EURYALUS 1803 by Peter6172 - 1:48
druxey replied to Peter6172's topic in - Build logs for subjects built 1801 - 1850
Nice bit of kit to have. Your work so far looks very neatly done. -
I think Jaager is correct: turned rather than tuned. Sometimes transcribing period script is difficult. -
Doing a nice careful job of it, Don. Styrene for sanding sticks is a good idea.
- 40 replies
- Model Shipways
The problem may be two fold. One; various plastic formulations will react differently as they have different malleability points and ranges. So what may work nicely on one plastic will be a disaster on another. The other issue that you've already alluded to is the varying thickness of the moldings. If you can determine the malleabilty range of the plastic you are using and apply just that amount of heat to the piece gradually getting it up to temperature with the piece on the curved form, then allowing it to cool, it might do the trick. Good luck!
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Call for Woollen blankets in UK for Sutton Hoo ship replica
druxey replied to Louie da fly's topic in Nautical/Naval History
And let's not mention Goya's etchings of the Disasters of War.... -
Hey, WWAC, for a first model, that is pretty respectable! And, imprtantly, you completed it. Sure, there were frustrating moments and you are probably you own worst critic but, as Bob pointed out, you've learned a lot from building this model. So, take a bow and a pat on the back.
- 43 replies
- Model Shipways
That shape can easily be fixed, so don't despair! Moisten the inside of the planks from the point where the curve becomes concave, let things soften and re-mold to the correct convexity. The planks may tend to come away from stem and transom, but can easily be reglued.
- 43 replies
- Model Shipways
