Everything posted by mtaylor
Allan, that's the top timber only. Thanks James. That's basically what I'm doing.
- 505 replies
- vanguard models
- Sphinx
Yep, I had the building maintenance guy run his humidity meter for a bit. Foggy outside, inside it's dry as a bone. Picked up a humidifier and have it running. I'll re-fill the cracks, sand and go for the paint again in the morning.
- 505 replies
- vanguard models
- Sphinx
Ah... thanks for that explanation. I'm not very familiar with that era.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Well.... I made a dog's breakfast of painting. Call it lack of experience as I haven't spray painted in decades. Need to sand and fill some spots. What looked ok yesterday showed that the low humidity here is creating a few problems. I'll sand, re-paint, and see what happens. I'm not upset, just focused on learning more and mistakes are part of learning or re-learning.
- 505 replies
- vanguard models
- Sphinx
Nice stove. Love it Would there have been a sheet of metal under the stove or brick?
- 2,696 replies
- heller
- soleil royal
(and 9 more)
I both amazing and a feast for the eyes the amount of detail you're packing into this model.
Thanks Bug, and BE. Looks like tomorrow is masking and start painting day.
- 505 replies
- vanguard models
- Sphinx
Question for the group and maybe I should have asked this in the painting area..... I did make a decision that I'm not going to paint the keel, stem, or stern so as not to hide the nice details Chris etched into the bow and rudder units. And yes, I'll be doing black from the black strake to the waterline and white from the waterline down. The hull is well sanded, filled some cracks that showed up (lack of humidity?). So, my question is, should I put some varnish or clear coat first to the wood before painting? At the local hobby shop, I got mixed messages.... some say over the final color only, others say do both. I'm using acrylic paints, both spray (for the white) and brush for everything else. I have the brush on varnish from Vellejo and Tamaya flat clear spray. Opinions and thoughts are welcome as I haven't painted my wooden ships in the past... this is a first.
- 505 replies
- vanguard models
- Sphinx
Those illuminated panels will really pop when installed. Just curious here.... should then be red? Or did the subs have dual colors for night and day use?
I'm not sure, Allan by what dimension you're looking for.
- 505 replies
- vanguard models
- Sphinx
Tom, open a build log for this in the appropriate area. You'll get more "eyes" on it there. This area is just for introductions.
Where did you find it?
Well, for now, I'm going with them I think. I do have a lot of filling, sanding, and painting coming up but that's a project I'll start tomorrow after the meds wear off from today's medical procedure. AD, Thanks for the observations. I think it's the angle of the photo. I'll flip the hull over tomorrow and put in it's proper position. The cobbled together upside down mount isn't the best setup. I do note that my "roof" on the quarter panels is a bit thicker at the stern than at the forward but everything else is pretty much determined by the slots in the hull lining and the pre-cut/pre-marked wood and matches the photos. I'll take a another look for those "tags". I thought I removed them all.
- 505 replies
- vanguard models
- Sphinx
Swan-Class Sloop by Stuglo - FINISHED - 1:48
mtaylor replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Looks you nailed that beam and all it's curves, etc. Well done, sir.- 475 replies
Looks wonderful from here. As for dealing with bits and pieces and needing them fitted to check everything, there's two ways for this. One is a few drops of something like Elmer's Glue All (a white general purpose glue) or rubber cement. Once checked, the glues can be removed. Alcohol for the white glue . Rubber cement can be rubbed off. Use either but very sparingly for test purposes. As always, test on scrap before committing to use on a build.
Finding trades people the last year or so has been a nightmare. One of my local friends is pulling his hair out over it. We've talked about the both of us doing what he wants but then getting it inspected and approved is a big problem as the inspectors and codes insist on licenses for doing any plumbing or electrical. It's not that there's a shortage of them but that they are all so busy re-working houses that been bought by new owners.
It could very well be their ISP or even one of the network "switches" that's the problem. Also possible there's issues with the virus and personnel but seems more likely it's something in the Internet causing the issue. However, that's no excuse to blame you. Cut back a bit... maybe 1 email a day or even every other day. And see if the problem continues. They are a sponser here. Maybe Chuck or James have a contact that can help?
Welcome to MSW, Emil. I hope your new adventure is a good one.
