mtaylor
Moderators
Everything posted by mtaylor
  1. Thanks, Glenn. I think I've got the right position at this point or at least "close".
  2. Kev, This is not really a "one size fits all" thing. Everyone has their preferences because for that one works best for them. For example, for me, wipe on poly is my go to but I also use others including spray on finishes. Having said that, I'm not an expert on finishes but just a builder.
  3. I've seen this done on posts where someone has responded to say "bob" and "bob's" name shows up in green cartouche containing a link to their profile. How is this done?
  4. Not that much done today but enough.. a bit more work later to be done later this evening. The counter has been soaked and pinned (but not glued). I wondering if this in right position . Feels (mentally) like I"m too far astern and it needs to in the direction of the arrow.
  5. Welcome to MSW, Len. We have a wide range of ship builders here. Everything from plastic to wood, including RC builders. Looking forward to your build log.
  6. That is one well used aircraft. It'll need a new paint job in the near future.
  7. Starboard side is done. Did the finger test* on both sides and I'm pretty happy. I also trimmed up the stern area, fitted the counter to test and it's now soaking to be bent and secured into place. I'll pull the blue tape off tomorrow. *Finger test: close eyes, run finger tips over hull.
  8. I like how the gun came out. Is there a reason not to remove the char from wheels? To my eye, it gives the appearance of a cast iron band which wasn't used on ships.
  9. Doesn't really matter as such as software of the site will make them fit if too big. I use a 1500 pixel width. Others may use something different.
  10. Welcome to MSW, Richard. Your log looks to be an interesting build. As for log here for RC control, just do a search using the key word "radio" and checking the box "content titles only"..
  11. My local hobby shop when I bought my paints for Sphinx had some Model Master paints but hadn't received any for months. Apparently its supply chain issue or they've stopped making them. I've heard you can use enamel for the base and then acrylic for the top coat... or maybe it's the other way around. I'm using only acrylics as enamels are a pain what with turpentine, odor, etc.
  12. Port side is pretty much done sanding. Feels smooth to the touch. Lessons re-learned.... do a better job planking. Maybe add some filler between bulkheads in any area with curves (bow mainly). Now to start the starboard side. I may rip off a few planks and re-lay them. Note to self... check and re-sand and recheck again the stern transom area.
  13. Looks to be a fascinating project, Richard. And a big one. If you would, open an intro in our new member introduction area. It's basically a "meet and greet" area. https://modelshipworld.com/forum/3-new-member-introductions/
  14. I have found that to be very true. I have one blade that I only used for ebony as the wood leaves a serious stain on the metal. Luckily, I don't cut much ebony even though I have a stock of it that was rough cut.
  15. I merged these two topics... part 1 and part 2. If you would, if there's a part 3 just continue here using the Reply at the bottom. And for any other topics you do.. just add the additional parts to the original if you would.
  16. Sounds great. Some of the "ebonies" being sold are striped with various shades of black and even brown.
  17. Egilman is onto something here that might work. Get another one. Leave off or cut away the top of hull on the second one. Or... battle damage. Catch is, in most cases the worst appearance was the turret blow off, sometimes sitting at an odd angle or off the the side. Hmmm.... more brain storming... don't glue the top hull to the lower. Make it removable.
  18. Err.... rethink that. I don't think a hammer would be productive.
  19. Big barrels for wine and foodstufs... small ones for brandy or other distilled spirits. I'll make a note.....
  20. Tamiya makes some as does Vellejo. Both spray and bottles.
  21. Welcome to MSW. When the kit comes, open a build log. It's the best way to get help and meet others. The captain's motto is a good one to follow.
