Everything posted by mtaylor
Best advice I ever heard came from the movie "White men can't jump"..... it was "Listen to the woman.
- 290 replies
- Quinquereme
- Finished
Make it easy on yourself for planking... here's a great groups of tutorials: https://modelshipworld.com/forum/98-planking-downloads-and-tutorials-and-videos/ Just soaking really I find the easiest way for planking is after lining off the hull, to mark and shape the wood to taper to the tic marks. Then I use the Chuck method of a bit of a soak and then fix to shape on piece of scrap wood... and apply heat from either a hair dryer or a heat gun. The key is the heat which softens the chemical bonds of the wood fibers. Plain water just won't do it.
- 134 replies
- sea of galilee boat
- SE Miller
I believe that workflow is something each of us has to figure out what works for us. Generally I do yards and masts as much as possible (fittings) off ship first, then start at the front and work my way astern doing standing rigging first and then another pass doing running. I do try to set up my rigging such that it's also installed from centerline outward. I may not completely run the full line leaving one (outboard line) for later. One key is to study the rigging and look for "gotcha's" where if you do something it blocks other things. And finally, don't rush it and inspect and re-inspect frequently.
Technical drawings & Dutch shell first
mtaylor replied to Jules van Beek's topic in Nautical/Naval History
Thanks for the answer. I appreciate it. -
I hope you're feeling better, Bob. Rule number 1 with wives.... "Listen to the woman and obey". It keeps the peace.
I have some questions/thoughts, Jules. 1) Given all the wars that went through Europe over the centuries, is likely that many (most?) records were destroyed? 2_ Guilds in many ways were secret societies so if build plans were made, would be realistic to think they were destroyed when the ship was launched? I do believe that much knowledge in the past was word of mouth and not recorded in an archival form. I'm just curious.... thanks for any thoughts. -
Trouble with scuppers
mtaylor replied to wmherbert's topic in Building, Framing, Planking and plating a ships hull and deck
I can't answer your question but I did fix the title. -
https://www.archaeology.org/news/11609-230725-vasa-shipwreck-passenger
Renault RE20 Turbo by DocRob - FINISHED - Tamiya - 1/12
mtaylor replied to DocRob's topic in Non-ship/categorised builds
Nice work. I'm guessing the painted surface at this point matches the infamous Chevy Orange Peel finish? -
Very well done, Chris. Display her proudly. You must have kept her in a clean room as with me, it would have had 17 years of dust being blown off.
- 69 replies
- fly
- victory models
I think you're one the right path with the "split" beams. The longer pins should work since they also have to through the deck planks and that will be the new reference for what ever needs to be on deck.
- 393 replies
