mtaylor
Moderators
Everything posted by mtaylor
  1. Hi Srenner, I have one suggestion.... instead of the metal elbows for the keel/bulkhead joints, I'd recommend getting some lengths of square basswood. Maybe 1" square. Use these glued to the false keel and bulkheads. Id' use two pieces between two bulkheads (high and low. When clamped and glued into position, they not only square things up but also help to remove the warp out of keel.
  2. Lovely work on the model Håkan and very sad about your friend. Sometimes live hands us smiles and other times a kick in the stomach. John is right... at some point the piece will come.
  3. A masterpiece, Valeriy. I wish much peace to come your way.
  4. As a former tech writer, I can see that this may very well have been the case. Tech (even ship tech) progresses by leaps and bounds and like other forms of engineering the paper work is always playing catch-up.
  5. You can see it at the top of the home page when log in unless you just go straight to you log.
  6. Just looking at those photos, I can almost smell the sea air. Just an amazing diorama.
  7. Interesting discussion this. Looking the condition of it in the photos, I have to wonder if it isn't a "recent" gun made for the reenactor folks. Possibly Civil War or even Revolutionary era???? As for the markings (proof) wouldn't those tend to be on top and not hidden say on the bottom? I've seen reproductions in the past of reenactor guns used for the reenactments and this one just doesn't look old enough to be the real deal.
  8. There's alot of ways to get there. Here's a short list... 1) Soak for maybe 1 hour or more depending. Put the wood in a microwave and heat. Check constantly so as not to burn the wood. 2) The afore mentioned soak and curling iron, plank bender, etc. Again, the heat must be applied for more than minute or two. 3) There's a method by Chuck involving soaking the plank and then bending it using nails set into a large piece of wood such as to form the shape and allow to cool in the jig. Apply heat with a hair dryer or heat gun. I've found this method works best for me. I'm sure there's a few more but the big thing is don't be afraid to test different methods as to soaking time and heating time. Everything is a variable with different species of wood, different thicknesses, etc. So testing for the best result is necessary.
  9. Merry Christmas Eric! I feel your frustration but the "fixes" to this kit seem to be working very well.
  10. Your work from here looks darn good. If you haven't done so, look up RGL's builds in the kit area 1901 to Present. He does some serious weathering with paints and chipping which should give some ideas.
  11. It's great to hear that you are safe on the home front and also the update on this incredible work of art.
  12. Merry Christmas and Happy New Year to you Keith. Stay warm and safe.
  13. For zero clearance inserts I make my own as I found the plastic deform with a shop vac hooked up does control using the saw's vacuum port. What ended up doing was using ply the thickness of the factory insert and then run some braces one the bottom of the insert such they drop below the insert mounting. Install blade and run the blade up to where comes out the top to the height I need for the wood thickness plus some. I found that with due care, they last a long time and I make several at once using different width blades.
  14. That's true, Keith. Having in the living room would work well but between the price and shipping and then the weight and getting up the steps to my apartment... just seems like to much. As for only one on the block to have one..... Probably the only one within 500 miles of here.
  15. I too am glad you made it through the virus attack. And what Bruce said about using power tools I totally agree with.
  16. I would also check with local zoning and weapons laws. While it would be impressive to have sticking out a window or pointed at the front door in the living room, I'm sure my apartment manglement would blow a gasket.
  17. I haven't been there in probably 20 years or so but it is indeed well worth the time to visit. I'm giving thought to doing a road trip up north this summer (conditions permitting) and this would definitely be on my "must see/do" list.
  18. I have a few places for storage.... one is shelf kept clear except for the model I'm working on. The others are plastic containers in various sizes that I've bought from craft stores and also some old well-cleaned food containers.
  19. Yes. hardwood is an excellent choice for them.
