mtaylor
Moderators
Everything posted by mtaylor
  1. It's very tricky to get those transoms lined up and you've done it very well. Excellent job!
  2. After thinking about this... maybe the guns were being double-charged and double-shotted (or even triple-shotted as some have reported) when they closed in?
  3. Richard, Post what you have to this topic. If there's interest, we'll pin it so it stays at top of the forum.
  4. Hank, I agree with Eamonn and Evan. You'll come up with a better foremast. Hopefully, though, when the foremast is complete you won't re-look at other bits and decide to re-do them.
  5. I like that sanding table idea. Hmm... I have some pegboard... And it'll keep the Admiral happy.
  6. Just another beautiful bit of work, Danny. Thanks for the comparison to the coin as I for one, often forget how small things are when looking at pictures.
  7. Looks fantastic, Chris. Now put away L'Orient....
  8. I am in total awe. Just amazing. A black floor... what a great idea. Now to convince the Admiral.
  9. Nenad, I think most of us have been there to some degree. It's not a perfect world, far from it. But if modeling gives us the pleasure and focus to put the day behind us, who cares? It's a good thing and the spice flows. Mow the lawn, wash the car, and spend some time with Admiral. Her Majesty will be patient.
  10. Let's try to call you Ray, but we don't have to call you Johnson. Reference for those who remember this --> http://www.youtube.com/watch?v=LztZu5s0-QU
  11. I've been fiddling with the saw while waiting for glue to dry. I put a shim into the forward end of the fence (the tall add-on) and it cants just enough so the back of the blade isn't hitting the plank coming off. I'm thinking about Jeff from HobbyMill's method for a guide fence on the feed side. He uses a block of wood and his thumb... hmm....I'm still considering similar to an Indexing Block as a viable alternative. So many choices, just need to figure out which is best for me.
  12. When you've been around model ship building, you know that sometimes crap happens. Same for the "name the ship" game. It happens and there's no chastising. Another hint, some players are known to change or remove the background to ruin anyone using Google Image Search. I'm not a player, just an interested follower.
  13. You might check (if you've not done so) your spam folder and also spam settings. It's also possible that your ISP is blocking sites for some reason.
  14. Dan, I slept on what you've said and I'm going to rethink things on the saw. You're right about the kickback. I've been lucky so far. I'm thinking that a small mod to the tall fence to give some clearance at the rear of the blade (it's an add-on) might do the trick.
  15. I have to remind myself that this isn't full-size. Excellent work on that "shoe".
  16. Sjors, Err... no. The saw isn't handmade or maybe it was since it was made in China.
  17. John, The guard is always off.... I do have push sticks in abundance and I stand to the right of the saw and move the wood from left to right. I don't want to be in the way of a kickback. I hate to say it, but I'm scared as hell of this saw. I had the guards on and darn near lost a finger when the wood kicked. So, no guards, stand out of the way and use push sticks. Don, I wish this was the Jim Saw, but it's not. With the Jim Saw, the aft end of the fence can be set such that there's more space at the rear of the blade than at the front. So usually, I CA a block of wood to the left so the plank can peel off and not get chewed up by the back of the blade. The main fence is just some mental security. When I get some time, I'm going to rework the fence a bit so has a step just aft of the leading edge of the blade to do this and then use the feather board properly. Or, hope something trashes the saw and I can justify buying the Jim Saw.
  18. Did anyone play "Rule Britannia" while giving you the tea???
  19. Bob, Beautiful work on the deck framing. Your scratchbuild work is fantastic.
  20. Scott, We're a patient lot... your model will be there when there's time and so will we. Some things like "life" have to come before a hobby.
  21. Piet, The story behind O-19 and your passion has made this build special to a lot of us. I know it has for me.
  22. Exactly. I just bought 4 Thurston blades (different tooth count) which Jeff from HobbyMill recommends for the Byrnes Saw and spent less than what 2 blades would have cost me from MM. And they are superior blades. He may hate it being called that, but that's what he calls it on his website. On the featherboard.... how hard would it be to make one?
  23. I swear, my next ship is going to be Gaetan sized..... if I can figure out where to put it. Anyway, keel number 5 is just stuck in position and not glued up yet. Once glued, I'll do the final 3 half-frames but I do have to work on the transom first. That would be that small pile of planks in L-square. I've cut the rest of my planking and it's in the pic. Just another quickie side-topic.... here's a shot of the setup on my saw for cutting the planks. I set the wood to the fingerboards, move the fence, and cut a plank. Move the wood to the left and then the fence and rip another strip. I do it backwards since I'm left handed. The featherboard is locked down (in this case) to produce a 1/32" thick plank. The wood I'm cutting it from is 1/8" thick boxwood.
