Everything posted by mtaylor
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
mtaylor replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Nothing like exercising the guns to bring the whole crew out to the main deck. Beautiful work as always. Your crew is very lifelike.- 883 replies
- royal caroline
- ship of the line
- 2,191 replies
- confederacy
- Model Shipways
Congratulations Mobbsie. You have a achieved modeler's nirvana. If don't get a sash, maybe a medal???? Very well done, Sir Mobbsie.
- 1,279 replies
- agamemnon
- caldercraft
Lime wood soaking
mtaylor replied to Mike Dowling's topic in Building, Framing, Planking and plating a ships hull and deck
Mike, After soaking, and while bending, apply heat. Some of us use electric plankbenders, some steam, some others use a curling iron. With heat, there's very little springback. If steaming, you'll need to clamp the piece into position so it doesn't spring back. If you don't want to use heat, try clamping the piece in the bent position while allowing it to dry. There will be some spring back but two soak, bend, and try cycles seem to work. -
Bensid54, I'd like to suggest you open a build log in either the Kit area or the Scratch area. There's a pinned post that will tell you how to name the log so that it's recognized as an RC build. BTW, nice work on the backbone.
There are other sources for those kits here in the States. A bit of Googling on a given kit (or maybe ship model kits) should give you most of them. Now service, etc. probably won't be as good as ME.....
I asked about spiled since it seems to curve up at the stern... Yep... that's weird.
- 625 replies
- bounty launch
- model shipways
She's going to be a big one then. We do have some very knowledgeable people here for RC and steel navy, but I'm not one of them. Is your dad a member here?
Is that plank spiled and now upside down?
- 625 replies
- bounty launch
- model shipways
Forget the test, I don't want to deal with Homeland Security, the local constabulary, or the ATF... Rethinking this... the accounts do not say WHEN the gun bucked or jumped. Was it while run out of the port? During the actual recoil? Or at the end of the recoil? Logic would say near the end of the recoil. On an English/American ship, the breeching runs from the casabel, down to the ring and then up to the ring on the bulwark. So as the gun got to the end of it's recoil (or rope, literally) the rope would tighten and try to become straight from the casabel to the bulwark ring. The net effect, the muzzle and front of the carriage would go up.
Your choice. Back in my plastic days (cars, tanks, ships, etc.), I usually painted on the sprue and then touched up after cutting it off. However, some parts need to be assembled before painting, in that case, with small parts, I got a pin hot and stuck into the part(s)/assembly in a non-visible location. The bigger parts just needed a jig. For example on a car, the body was assembled with masking tape in the hidden areas, the whole thing mounted on a carefully bent coat hanger and painted. Not just primer, but the color and clear coat also. There's a lot of different ways of doing this. I'd suggest check the Kit Log area out on how they've painted. Even with the wooden kits, the same techniques would apply.
I do agree Chris and Nigel. As I said, I'm reaching here. I'm still wondering about the double-shotting, double-charging or even just the double-shotting, if that would do it. And records do indicate that many times they double-shotted at close range. Recoil, as has been pointed out is a function of windage, gun weight, shot weight, etc.... Hmm... I wonder where I can find a naval 32 pounder and carriage that I could borrow for some "testing"....??? We'd need some balls, powder, and a gun crew also.
Some seek understanding. Some seek illumination. I seek the Holy Grail: Bridgekeeper: Stop. Who would cross the Bridge of Death must answer me these questions three, ere the other side he see. Sir Lancelot: Ask me the questions, bridgekeeper. I am not afraid. Bridgekeeper: What... is your name? Sir Lancelot: My name is Sir Lancelot of Camelot. Bridgekeeper: What... is your quest? Sir Lancelot: To seek the Holy Grail. Bridgekeeper: What... is your favourite colour? Sir Lancelot: Blue. Bridgekeeper: Go on. Off you go. Sir Lancelot: Oh, thank you. Thank you very much. Sir Robin: That's easy. Bridgekeeper: Stop. Who would cross the Bridge of Death must answer me these questions three, ere the other side he see. Sir Robin: Ask me the questions, bridgekeeper. I'm not afraid. Bridgekeeper: What... is your name? Sir Robin: Sir Robin of Camelot. Bridgekeeper: What... is your quest? Sir Robin: To seek the Holy Grail. Bridgekeeper: What... is the capital of Assyria? [pause] Sir Robin: I don't know that. [he is thrown over the edge into the volcano] Sir Robin: Auuuuuuuugh. Bridgekeeper: Stop. What... is your name? Galahad: Sir Galahad of Camelot. Bridgekeeper: What... is your quest? Galahad: I seek the Grail. Bridgekeeper: What... is your favourite colour? Galahad: Blue. No, yel... [he is also thrown over the edge] Galahad: auuuuuuuugh. Bridgekeeper: Hee hee heh. Stop. What... is your name? King Arthur: It is 'Arthur', King of the Britons. Bridgekeeper: What... is your quest? King Arthur: To seek the Holy Grail. Bridgekeeper: What... is the air-speed velocity of an unladen swallow? King Arthur: What do you mean? An African or European swallow? Bridgekeeper: Huh? I... I don't know that. [he is thrown over] Bridgekeeper: Auuuuuuuugh. Sir Bedevere: How do know so much about swallows? King Arthur: Well, you have to know these things when you're a king, you know.
Gary, Can you give us some background on this ship and also what scale you'll be building her?? Looks to be an interesting project.
Are you washing the parts first? All plastic kits have mold release on them. Wash in dish soap and water and rinse well. Try to keep your fingers off the surface to be painted. Also, use several very light coats of spray and allow to dry between coats. The coats should be fog like, thin, light, airy almost.
Roger, Do the plans show the keel and bulkheads at full scale? If so, you can some plywood from a craft store and make new ones.
