Posts posted by archjofo
Hello dear friends,
thank you for your kind words and support, that means a lot for me.
During the weekend, I continued making the hammock cranes.
There are 152 holes with a diameter of 0,5 mm is required.The eyelets I made out of a U-piece brass wire. These are inserted and soldered in two holes.
Here are some pics, so you can enjoy them.
Hello Karl,
thanks for your nice comment.
It continues with the production of hammocks cranes.
The sheet brass is 0.2 mm thick. The required strips of 1 mm width I sawed with a circular saw. By bonding the sheet to a plywood underlay you get very precise strips.
The bending of the eyelets I made with a prepared plier.
38 holders are to be made. -
Hello Mark,
unfortunately my English is not so good.
But I try to explain to you:
It is correct that way.
The breeching rope is long enough. In this type carronade from the year 1830, the recoil was limited with a strong rope. This is called non-recoil-principle.The operator had to go through the gun port to load the carronade from the outside.
I hope I have expressed myself correctly. -
- Wishmaster, Elmer Cornish, gjdale and 19 others
- 22
Thanks all!
Meanwhile, all gunports lids were fitted into the ports.
Only the last pair is still to be finished. They are for the gun port in the bow on the port side.
This gun port is a special case, because of the rounding of the bow.
The fit of this cover halves at this place requires special attention.
This couple also receives a dropfront as a protection against the armature.To be continued ...
- JesseLee, gjdale, Elmer Cornish and 12 others
- 15
Hello friends,
lately I hardly have time for the model building.
Currently I'm still working on the gunports lids.Meanwhile, a modeller colleague has created a video of the La Creole.
See here: LINK
I hope you enjoy it.
- mtaylor, cabrapente, SailorGreg and 3 others
- 6
Absolutly phantastic, Alex!
Hi Karl,
the capstans are handcrafted masterpieces.
I admire your skills.
Absolutely fantastic.- Jeronimo, CaptainSteve, Bindy and 1 other
- 4
La Créole 1827 by archjofo - Scale 1/48 - French corvette
in - Build logs for subjects built 1801 - 1850
Hello friends,
today I will show you how to attach the upper gunports cover with hook and eyelet.
For this detail I have researched long. I hope this is the correct version.
The difficulty was to bend the small hook with eyelet from 0.3 mm brass wire.
This detail must now be implemented in the model.
Here are the corresponding images:
