Evening my fellow - very patient followers, some more progress on my build - I am working on the ground plan, this is taking some testing and shaping to get all the buildings and walls to lign up, i got the main section in supported by a sheet of paper underneath, then a bit of putty was put in a few of the gaps and painted over, i also put a couple of water puddles in the corners from the rain that ran down off the roofs, I will do the same - paper trick underneath the front sections before putty and paint - then there will be some washes and dust dry brushing. OC.
Evening all, some more progress this evening - remember those Three 2nd KGL? well I took them off their bases then put them to One side, I got the base section near the pond and worked out where I wanted to place my new figures - this required some planks making up and stacking together to give some height so they could fire through the holes in the wall, so my lolly sticks came into use - cut sanded glued then a Brown coat followed by a Black was - then my dark wash finished of with a dust dry brush. These were put to One side while - "Those bricks from the wall" were made into a little pile - glued in place then painted. Then the Three figures were glued in position - looking quite busy. OC.
The finished ship should be displayed in a museum with a video tutorial of the build - its that good. OC.
- 355 replies
- vanguard models
- Sphinx
Evening all, I had quite a productive evening for a few hours - I decided to get my airbrush/spray booth out and started by Flat top coating the last Three finished KGL, I have a very good Acrylic Flat top coat called - Ammo by Mig Ultra Matt Lucky Varnish it is in a tall bottle and even has a ball bearing inside for shaking it, its been fab so far whaen brushed on - however I was realy supprised that it was even better when misted on using my airbrush. I was soon getting used to the dual action and the finish was Superb Dead Flat. So I thought why stop there - so I got my box out containg my 50 odd painted figures and set about spraying these with the Flat coat. I was finding I could do Three at a time with the metal pot on the airbrush about 3/4 full, as soon as it was empty I would wash it through with some cleaner and plain water - then continue again - took me about Three hours to finish all of them. Loving the airbrush. OC.
Thank you kindly Alan, I know tell me about it. I am still picking up ways of improving the faces - sometimes I use more or less wash that settles in the groves and eye sockets, and also using a combination of colours to shadow/highlight the different parts of the face - same with the cheeks giving them a slight pink glow - its all about trying different shades to nail it. OC.
