HMS GREYHOUND by fukui
Old Collingwood replied to fukui's topic in - Kit build logs for subjects built from 1501 - 1750
Hi and welcome, is this the Corel kit? I part built one in the forum. OC. -
Evening all, I did a bit more work this evening - firstly I removed the tape and checked the seams, these needed just a bit of sanding (but no filler I dont think) this was a supprise to find two companies who manage to build kits with quite high build standards - it also makes my first observations what I first started to build this kist (in my earlier build log - Not Eduard one) as being incorect. Anyway next off was to fit the prop cone bulkhead, then when set I had to fix one of the exhausts stcks that had broken in two, this was fixed then glued in place in the recess - same the other side, then I got the engine cover and test fitted it, quite a bit of scraping and sanding was needed to get a good fit - then this was glued down. It needs sanding and cleaning up whne its set. So here are a couple of pics including one of my Supermarine prod line. OC.
