Old Collingwood
  1. Thank you kindly mark, yep I thought of that and made sure the cutouts in the hull are free of paint, and also the linkage holes - so it should glue well. OC.
  2. Thank you for putting my mind at rest, I guess all the extra bits of work will make it worth it in the end. OC.
  3. This is how I could possibly attach the deadeyes to the links on the channels - I could drill through the plastic linkages then attach the deadeyes with thick-ish thread around the outer of the deadeyes and through the drilled out linkages - I could then tie them and add some glue to the thread to give it some strength. Here's the idea - OC.
  4. The lower linkage arms below the channels are plastic, they have a ball end that glues into a small hole in the hull, I would hope that these joins being plastic to plastic using poly cement - will bond well and give enough strength (there is no room to pin them you see). The deadeyes will have to attached in a manor I haven't worked out yet - as the push in plastic devices along the edges of the channels are designed for ball and socket type ends of the (kit pre molded all in one shrouds) but I am going to make my own using threads and wood deadeyes that I also have. Nothing like a challenge. OC.
  5. Thank you so much for your imput ej, that was kind of my thinking from all the builds I have seen. OC.
  6. Thank you mark I will try (I have the admiral keeping a close eye on this one - as its for her she is worth it though) all the best to you and yours also. OC.
  7. Just to follow - up, my idea is to carry on making/painting/weathering the channels and fitting the lower deadeyes, then these will be glued to the hull, i will then start with the foremast - glue the lower section in place including the lower masttop, then start on the standing rigging by fitting the foremast stay to the bowsprit, and fit the bobstay. Does this sound ok? as it will be my very first mast/rope work I have ever done. OC.
  8. Evening all, slight departure from the work so far - so I turned my attention to the channels starting with the smallest ones for the mizzen mast, these are plastic units of good shape, they have link devices attached then two plastic chain attachment type devices, was glued in place after checking for alignment with holes in the hull then set aside to set. Here is the one I started - OC.
  9. Keep up the great work kevin - she is looking splendid. OC.
  10. Evening all, the little boaty if finished - I cut the rest of the fitting from the spru then cleaned them up and did my normal - painty - weathering thingy bob, then after fitting the rudder I placed the rest of the fittings to the boat with some small amounts of plastic glue. Here are a few pics including a couple placed on the deck. OC.
  11. Thank you sincerely, I think the dark washes applied roughly helped. OC.
  12. Thank you lou, just doing my best to do her justice and make her look as life like as possible - im loving working on her. OC.
  13. Thank you piet, it hasn't scrubbed up too bad so far. OC.
  14. Since thanks for all the likes and replies. More work on the wee boaty - I painted the grey/black all over, then when dry I highlighted ontop including the top framework and a slight amount to the bottom deck section, then I glued the lower deck inplace followed by the top framework. Just a few pics to show this stage. OC,
  15. Used to be a program on British tv in the 70s (I think) called Michael Bentines Flying Circus. OC.
  16. Could be for this - remember - https://www.bbc.co.uk/programmes/articles/2LF04Y9n5hJTHK1l6ffLhPc/the-rise-and-demise-of-the-flea-circus OC.
