Old Collingwood
  1. Thanks carl, I had to shape the tops of the bits to allow for the rope tie offs, not easy at 100scale. OC.
  2. Yep on both the forecastle deck and poop deck, the bits continue through the deck down onto the main gun deck, also under the poop deck there should have been the frame and shoe to take the bowsprit, but due to the construction on my kit, this part is boxed in. OC.
  3. Thanks pat, I kind of noticed it after I had fitted it and thought "damn silly thing to do" It dd fall appart whe I moved it, but luckily it just needed re gluimg when the posts were positioned. OC.
  4. Evening everyone, after fitting my forecastle bits I came across an "upss moment" - I had the bits to close to the edge of the forecastle deck, not leaving much room for the ships bell/frame, so I decided to re fit it on the other side of the mast, and instead fitted two single bit frames without the cross piece. I then turned my attention to the rear poop deck - this has a ladder running up from the quarter deck, up through the poop deck, I had to cut this out with my sharp knife then a little sanding, next I constructed a frame for the opening and glued the four pieces in place, it will need filing to make the edges square and smooth. Here are a few pics. OC.
  5. I love your interest in all the victory feeds john, I guess you had some interest in her.
    Regards  OC.
  6. Looking good, you are on the right track, the thing I have discovered with wood kit building - its all about practice and repertition, the more kits and time at the bench - the better you/I and everyone become. OC.
  7. Ok everyone I give in here are some pics - the bits show the glue waiting to dry. Oh foregot to mention - the captains cabin facia was made up form oddments I had, then put together and painted. OC.
  8. Looking great kev, have you seen the kits over at Atlantic Models, they have a 1/350 scale resin kit of HMS Glamorgan, it looks superb. OC.
  9. Sorry for delay in replying, I foregot to check my own thread Hand is not to bad I have good and bad days depends if I am using my left hand much - holding stuff thats when it starts to play up and my fingers lock, however on good days it gives me less trouble. Im doing some gentle light work at the moment - building the bits and fitting them through the forecastle deck down into the front of the gundeck. Not really any pics as I am waiting to progress a little further. OC.
  10. So pleased she is being brought back to life, she is not that far from what i am building.C. O
  11. That is looking rather nice EJ really nice build you have going on there, the fact that you create your own carvings is even more credit to you. OC.
  12. Thank you for looking in, although im not working on her at the moment, its great having you have a look at what I have done so far. OC.
  13. Stunning work bob, she is just like a scalled down version of the real ship - museum quality without a doubt. OC.
  14. She is looking grand all the assembliess and sub assemblies coming together now, such a neat job. And regarding your margin - I like it a lot it looks so correct. OC.
  15. Your doing a great job kev, keep remembering the sheer scale of her, that makes it all the more remarkable what you are doing. OC.
  16. Tell you what - those things are Huge, I stood next to one as a kid and they are massive. OC.
  17. WOW that looks smart and the detail it so brings the rear section to life, lovely work kev. OC.
