Thats what I was thinking mate, I am just attaching the breach rope then I will glue the cannon down with a bit of ca, then I will do the same the other side - then after fitting the ships wheel, I will then be able to glue the poop deck in place. OC.
- 455 replies
- slightly modified
- greyhound
Looking very nice my friend, I completely get what you mean with the filler - so much better if it can be applied in small doses and controled just where you want it. OC.
- 171 replies
- krabbenkutter
- authentic models
Latest work on the bench including finishing my first cannon off - minus the breach rope (I have not been to fussy with the first one and two as they will be manily hidden out of view under the poop deck over hang) I also fitted two rings into the bulwarks (this was a tricky job as I had limited room to get an angle to use my small finger drill, I had to come in at an angle over the top of the opposit side bulwark. I then pinched in the hoop in the ring pins to close them up sligtly, then pushed them into the holes and added a drop of CA by a narrow pin head. After I painted the rings black. The pics show - my cannon and views of the rings, also a view with the poop deck dry fitted - and finally an almost sucsessful view through the opposit side gunport showing the poopdeck stairs and behind that the cannon. Thank you warmly and sincerely for all the likes and views - it means a lot. OC.
- 455 replies
- slightly modified
- greyhound
I can see All the pics now I remember your warspite dio well, what an imaginary pice of art it is. OC.
- 122 replies
- tamiya
- King George V
Really tidy work, and I love the miniture workshop in the background OC.
- 59 replies
- prince de neufchatel
- model shipways
Hi everyone, I got a bit more time on the bench today, I finnished painting the capstan and compass bass (I used the kit metal parts for this as they shaped up ok and painted fine) I also fitted the funnel from the kitchen(although no kitchen is fitted lower - "shhhh no one knows") I am still working on one of two of the cannons that go under the poop deck extention, needed the wheeels painting (black or yellow ocre????) Anyway here are a couple of pics. OC.
- 455 replies
- slightly modified
- greyhound
I hand painted my hull using white Admiralty Acrylic paints, I just applied a few layers drying with a hairdyer between layers, and found it did a good job, no brush marks or streaks, I found best work solution was to mask off where you want the line to and use a decent brush and try to paint in smooth lines from front to back then reverse back to front, but try to avoid over painting while the paint is still tacky. OC.
- 421 replies
- caldercraft
- granado
Looking very nice - lovely tidy paintwork. OC.
- 126 replies
- fly
- victory models
Thank you sincerely mate Im at the (get the fittings done covered by the poop deck) stage these are two 9pdr canons (Im going with the cast carvings as 1/100 scale is too tiny to make them from wood) they are getting the filling down process to clean them up including making the wheels slightly narrower, they will just have the breaching rope attached and painted up accordingly. Also to go in place will be the ships wheel and compass base also any fittings along the bulwark that would have been fitted under the poop deck area. OC.
- 455 replies
- slightly modified
- greyhound
Blimey mate another build You have as many builds as I have VST devices in my Reaper audio device, this one looks equaly interesting as your other builds. OC.
- 171 replies
- krabbenkutter
- authentic models
Thank you so much bob, Im starting to add some of the small attachments to the deck now. OC.
- 455 replies
- slightly modified
- greyhound
Thank you kevin, very kind words. OC.
- 455 replies
- slightly modified
- greyhound
I still just see a group of Jpeg numbers. OC.
- 122 replies
- tamiya
- King George V
Looking Superb that base and sea really brings it all together. OC.
- 378 replies
- java
- pacific crossroads
Thank you so much, its getting there - bit by bit. OC/
- 455 replies
- slightly modified
- greyhound
Hey you are doing a great job - nothing wrong with your planking. OC.
- 574 replies
- cheerful
- Syren Ship Model Company
WOW don she is looking superb, so fast aswel. OC.
- 223 replies
Hi all, today I got round to finishing of fitting the ladder on the poop deck, after fitting and gluing, a liitle bit of light sanding was done then I applied a coat of top coat. Siincere thanks to all those who view/like and comment on my build. Here's a couple of current build pics. OC.
- 455 replies
- slightly modified
- greyhound
Thank yo so much for saying that. OC.
- 455 replies
- slightly modified
- greyhound
Thnak you don, very nice of you to say OC.
- 455 replies
- slightly modified
- greyhound
What a great little ship potential to be an awsome build. OC.
- 102 replies
- speedy
- model shipwright
