rpeteru
About rpeteru
  • Birthday 05/09/1947
  • Gender
  • Location
    Perth Western Australia
1,630 profile views
  1. Have built a few card models myself. Dutch Liner SIBAJAK, Mauretania, Friederich De Grosse on the work bench,, Plastic to many to mention. Plank on frame Zwarte Zee,, HTMS Ayuthia, (Scratch), Mondfelds Spanish Galleon Scratchj, Santa Maria Kit,Hannah Kit. Just a few to keep me off the streets Stash include 2 x Australian river paddle steamersCard HmaB Endeavour Kit, Golden Hind kit Plastic Bismarck. Graf Spee, A few others I can not remember the names off.
  2. Recently got back into card modelling. Currently am doing SMS Friederich De Grosse, Have done Motor ship Sibajak Have the two Australian river steamers in my stash. Been awhile since I posted
  3. Have done this model in card by Scaldis to a scale of 1:250 long time ago.
  4. Why not enquire with the manufacturer Artsania Latina They should have it on file.
  5. There are youtube videos on this particular vessel.
  6. This vessel is powered by Two MAN K9Z 78/140D. The 9 refers to the cylinder count and the 78/140 refer to Bore and stroke respectively,780 mm bore and 140 =1400mm stroke. In my earlier days I spent a lot of time with this engines smaller brethren. Mainly K8Z 57/80C.
  7. Forgot to mention also many an hour on the throttles of the starboard Quadripple expansion engine as fitted in HMAS Diamantina. All manually operated in the days before Dynamic positioning systems. The term we used was manu-matic.
  8. Came across the SD14 Kit when I was an Instructor at the Australian maritime college in the 90.s. Was trying to angle to get in on the build, alas one of the Naval architects had beat me too it. When built was use as an instructional tool for all Marine classes.
  9. Actually in this country wine is sold in carboard boxes hence the expression of "Chateau cardbord" when dealing with your favourite tipple.
  10. Funnel walk ways would have been used by stokers to put the funnel covers on when the boilers that the particular funnel serviced were shut down. The reason for the covers was to prevent outside moisture from dripping down inside the funnel and mixing with the remaining residual soot. The boilers burnt FFO or furnace fuel oil which has a heavy Sulphur content. This Sulphur content in the soot when mixed with any water would produce a mild sulphuric acid which would attack the exposed external boiler piping. The removal of soot build up would normally be carried out with a soot blow, but only with permission depending on direction of travel and prevalling wind conditions. That crowd on the bridge did not like to be covered in soot, especially during daylight hours, so we would blow soot just after dark and before dawn. It was also very nice to sometimes see this crowd annoyed especially if they were wearing tropical whites. Pay back can be a b**ch. Some times it just happens only following the Engineer's orders. Daily soot blows would not remove all the accumulated soot, this would be done during the self maintenance period and be termed a boiler wash down. External panels removed and hidden and ingrained soot externally washed out using a high pressure wash. Once this has been completed tubing where it enters or leaves a steam/water drum could be inspected, for erosion, corrosion, caustic embritlement, necking or deformation of the piping.
  11. rpeteru, hope you did manage to get your mok so now you can drink coffee out of it.
    Been away due to several problems but now back on my built an d closed the hull.
    Sanding and filler is now the actions to be taken until I got a smooth surface for the paint to apply.
    Have a great one there, cheers.
  12. Gents I think the expression is "Chateau Carboard"
  13. Querry where did you get the mug? I want one. Being an ex Marine Engineer.
  14. Depending on where you are there is also the chance some individual has use the tree for target practice. Have seen many clips of people milling local timber only to find lead pellets or shot in the felled trunk.
