Posts posted by robdurant
Okay- the rigging is complete. I'm waiting for a case to be made, so Ethalion's under a cardboard frame with a plastic dust cover over her at the moment - not her best look.
I shall take some better photos and post them when she re-emerges. I shall add (at least some of) the ship's boats around the model rather than on the skids as they hide so much of the deck beneath. But for now I'm going to call this one finished . Thanks so much to everyone for your encouragement, interest, wisdom, likes, ideas, etc... Especially Barbossa, Ray, Beef Wellington... I've taken so much inspiration from your builds!
Here's just a few photos...
She's in much need of a nicer stand, but that will happen when the case arrives
Thanks again.
Rob
8 hours ago, dunnock said:
At the bow, I am grateful to Jason for his solution to the problem of providing support for the planking where modifications for the bowsprit and the stem have taken it away.
I neglected to do this properly, and it shows on my final model, so I think you've done a great job there. The more work you do to really get it sanded down neatly and ready for the second planking, the easier that will prove. It's a great start well made
8 hours ago, dunnock said:Probably because my starting points and measuring were not precise enough.
If you work it out again as you go every few planks, you can accommodate for the inaccuracies and push things back into line... it's the only way I find will work for me, as my planking is never accurate enough to get it right first time. The mix of planks that are never perfectly the dimensions I think they are, and slightly off marking, and slightly off cutting mean I'm never quite where I expected to be.
1 hour ago, BobG said:
This demonstrates how much I have yet to learn about gathering information from the plans and then be able to make something like these filler blocks from that information. Nice job!
Thanks Bob. I'm gradually learning. I think I probably over-engineer a lot of my solutions, but I have fun doing it, and it's a hobby, so what's not to like
First planking
First I should probably say that I went back and added a rabbet at the bearding line, as on Ethalion, as I figured that would give the best chance of a neat termination for the planks at the stern post, once the second planking was in place.
The lime wood planks provided with this kit are lovely - really well cut and nice and easy to shape... even so, the stern transom of this ship is a challenge...
Using an app called conecalc, I worked out the radius the plank would need to be bent to laterally to sit flat round the stern... it's pretty severe, and my first few efforts at bending the plank like that were dismal. I ended up using 3x1.5mm beech I already had in the end so that I could get the bend. And even with soaking, and using a rib-bending iron, it was still quite the task.
The planks were added with superglue, and once the whole hull was first-planked, I painted watered down carpenter's glue (Aliphatic resin) over the hull to stick the planks together. This seemed to give a really nice solid base.
The rib-bending iron is great... in a matter of seconds, you can get something like the the result below (and the wood is dry from the heat before it goes onto the hull, so it isn't going to shrink, either...)
With carefully edge bending using the rib iron, and gently teasing the planks, I managed to plank half way down the hull, and also the garboard strake and the two planks above without tapering any of them... The rest was then filled by letting the planks lie as they wanted to.
Once the hull was closed up on both sides, a liberal coat of wood filler was added, and the hull sanded back to get a really smooth finish, ready for the second planking. The sternpost, and the strip that adds onto the bow? were also added now that the sanding was mainly done and they wouldn't get damaged.
After taking these photos, I went over the whole hull and sanded it down further, as I realised there was more filler left than I wanted, but it gives an idea of the result. It'll do for a first planking.
I've begun the second planking, but no photos to show yet. So that's me up to date.
Thanks for all the likes and for looking in.
Rob
- chris watton, gsdpic, egkb and 7 others
- 10
The stern former
As with the bow, the stern is shaped using balsa formers. These are a little more tricky than at the bow, as it's one single piece that is entirely responsible for the eventual shape of the stern in all three dimensions.
It all begins with three identical balsa blocks of equal shape.
Again, I made a cad drawing of the plans given by MarisStella so I could take some measurements off it and put extra lines onto it. The extra lines showed where the balsa blocks should start and finish on the x, y and z axes. This enabled me to cut them down to rough shape in the vertical and horizontal planes before sticking them together.
I've tried to draw a picture of how I went about this... hopefully it gives some idea... basically the idea is to take away what you know WON'T be in the final shape one axis at a time, and then see what you're left with... when you've done that, you can start to take off the edges back to the curves you will eventually want.
As they say, the way to eat an elephant is slice by slice! When done this way the whole thing feels much more achievable.
The first wood I removed was the angle at the top - This forms the continuation of the line that runs along the tops of the bulkheads, and is not horizontal... it is higher at the stern than at the final bulkhead. (see 1 on the diagram.)
This was achieved by marking the difference in height from the plans, and then sawing off the majority and sanding flat with sandpaper laid on a flat surface. The slope can kind of be seen below:
Here are some more photos of progress... I marked the outline of the third balsa block - this is more than all that will be left of it once shaped, so why stick on the rest? It'll only need to be sanded or cut away...
And here it is cut down and attached...
Then I marked the angle of the backside of the stern (the transom) - again, this is not vertical... the curve of the stern at the top of the block sticks out more than the curve at the bottom of the block... I started this shape by removing the excess straight across the stern.
Then, using a template made from the plans, I shaped the lower curve so that it was the right shape... (slowly and carefully, checking progress lots...) As I got closer I used a strip of paper pinned into the balsa to mark the line of the wale...
And in this way, the shape gradually took form... Once it was close, I stuck it on to the bulkhead (using gravity to keep it in place as it stuck - which was either brave or possibly stupid, but I seemed to get away with it... ), hence the angle of this photo...
I noticed that the angle of the rear bulkhead could easily be wrong, so I used balsa blocks to wedge it up and make sure it stuck in at right angles to the false keel. (There are no dowels through this bulkhead to help you out!
Final shaping was then done on the model.
Next up is first planking. But again, that will need a separate post.
- Beef Wellington, GrandpaPhil, BobG and 3 others
- 6
Okay - with the gradual wrapping up of Ethalion (the rigging is completed), it's time for an update on the Barque Stefano.
With the bulkheads roughly faired, we finished last time with them glued into place, save the final bulkhead at the stern. The next task is to fair the balsa blocks that provide shape for the bow and stern.
I scanned the plans, and created CAD copies of the pertinent outlines to help me shape the blocks, and once these were stuck onto cardboard and cut out, they made good templates...
This was done before the balsa was stuck on, and then I rough shaped the balsa off the model using a coping saw to stop the room being consumed by a pile of shavings... The false keel and bulkheads gave the rough pattern for what shapes these parts should be. The block was built up so that the gap that would be left on the outside was filled at the bow so the whole area would be solid in front of the front two bulkheads. (Sorry - an ugly sentence, but hopefully the picture explains)
(Remember these are handed - they have to fit either side of the bow!, I almost forgot.)
It doesn't have to be pretty at this stage... it's all going to get sanded down and up soon enough.
The blocks are then stuck into place.
I quickly realised that sanding was going to take forever to remove this much material, and still created buckets of dust, so I switched to a small plane... Finishing off was then done by sandpaper folded to make it fairly firm, and in broad sweeps to get nice curves...
And here are the profile templates...
The gap between the first and second bulkheads was also filled at the outer edge... and then sanded back to make a smooth curve...
Next up is the stern balsa former... But this post is long enough already.
- rybakov, BobG, GrandpaPhil and 4 others
- 7
Hi David,
It was these guys. And it was really really lovely wood - just what you'd expect from a luthier's supplier.
https://shop.exotichardwoods.co.uk/castello-boxwood-guitar-banding-800-x-6-x-2mm.html
They do, however, have a minimum order, so I got some sheets of Castello Boxwood at the same time, which I used for the replacement stem and rudder post. In retrospect I wish I'd bought more of these banding strips. I ran out.
Rob
It's a long slog to get that deck planked but it looks like you've done a great job. The bulwarks add lots of strength for planking which is a great help. Far less risk of snapping off the bulkhead tabs.
Hope the 5mm planks turn out to be well milled.
Seeing that angled break on the stempost, I was expecting to see it's matching break on the bow of the model... It looks like it could be pretty vulnerable if it were stuck on too early in the build.
You've made a great start. Those gunport linings look really neat. Hope you won't mind if I follow along.
24 minutes ago, ccoyle said:
...as well as the number of bulkheads supplied. The kit appears to have about half again as many as one normally sees in a PoB kit.
Yes, it's 21, compared to 17 in HMS Diana by Caldercraft (the only similar example I have personal experience of), which makes a hull almost identical length. This is particularly at the bow and stern, where the bulkheads are closer together, and this should make a big difference when fairing for the first planking, especially in avoiding the bumps and flats where the planks can get pulled too tight across the bulkheads.
7 hours ago, BobG said:
Nice work, Rob. I'm following along closely.
Welcome to the build
So here's a little update. The next step in this build is to fair the bulkheads. The plans (specifically an overhead view, P5 on plan sheet 3) provide lines at three levels. Specifically the main rail along the top of the hull (where the planking stops at the top), the deck level, and a third level... This was defined in the plans as the "highest wooden plating line".... Some head-scratching was done, and comparing the widths of that profile at the bulkhead seemed to confirm that this is in fact the highest copper plating line. This being the case, it's effectively the shape of the hull at the waterline.
Once I'd figured that out, I went on to work out the difference in bulkhead width from front to back, as below.
These were then carefully marked out at those three levels on forward three frames... and the shaping began, with a mix of a sharp x-acto blade and some files. Bulkhead two was roughly shaped off the model, and then glued in place where the balsa blocks will be added and the shaping will be finessed.
Once the time came to fit bulkhead two again, I realised that the part I glued to the back side was blocking it going into the slot. So the bar across the back was modified as shown below.
Bulkhead two was then glued in place.
The same was done for bulkheads 20 and 21 at the stern.
I haven't glued bulkhead 21 in yet, as I'm still feeling my way with this build a bit.
Finally, a few shots taken this morning of the build so far.
It really shows the accuracy of the laser cutting off, doesn't it!
Okay - more soon
Happy building.
Rob
- bruce d, Rudolf, marktiedens and 8 others
- 11
A minor update in v1.0.7. I've added a Recent Files list in the File menu so that you can get back to recent profiles more easily. The list will be empty when you first use the app, but it'll fill in as you save settings files and start using them.
As always, this completely free (cost-free, licensing-free, ad-free) app is available at: https://www.durant.biz/pictureresizer/
I think this is probably the last update for a little while, and I'll work on getting the documentation in a bit better shape. It's a few versions behind right now.
Here's a screenshot of the recent files list in action:
Hi Jason,
It's been a productive month or so
I've attached my calculations below which are based on AOTS. The first page shows mast dimensions (with long, proper and stump additional measurements for topgallant (add the first column "height o/a" to the stump / long / proper)). These measurements are shown 1:1 in feet and inches, 1:1 in metres, and then 1:64 in cm. I opted for the long, but I have to say, it does add quite a lot to the height of a case!... It looks really smart, though, and gives the masts a sense of really gracefully stretching out above the hull.
Please do check these yourself before you start cutting wood, because my mind's a little foggy on how I went about this, and I wouldn't want to steer you off course
If you download this pdf, the second and third pages are all of the yard dimensions from AOTS.
I drew all of these out in CAD and used those as the basis for making the spars. Unfortunately I lost those drawings with some computer troubles, otherwise I'd share them here. Hence not being quite as sure as I would have been as to what I decided.
The rigging is all roughly per the kit, but looking at Lennarth Petersson's book to help me get it right... Those are the places where I used deadeyes instead of the special blocks Caldercraft provides.... (fiddle blocks?). Altogether I think they're pretty similar. My model is not going to be a completely accurate rendition as I've already realised that I missed out a shroud on the main mast, which has been repurposed as a topmast shroud so that the deadeye is occupied. And I missed the cleats on the masts, so the belaying points are being reworked a little. But I'm satisfied the overall effect will be sufficiently accurate to look workable.
Thanks to all for the encouragement and interest shown.
Rob
I've just completed the main mast stays - topmast, topgallant, and royal stays, as per the fore mast. And in doing so I ran out of .5mm natural thread.... again... but not before I got all of the yards attached to the masts, and the spritsail yard attached too with their trusses and parrel beads as appropriate.
Here's what I did (although I'm aware that in various places it may be a little unorthodox - not least because I forgot to put the cleats on the masts, and it's way too late to start at this stage! Lesson learned!
The bits that hold the yards up (trusses, parrel beads, and halyards?)
Main yards and cross jack
The main, fore and cross jack yards (those that are lowest on the masts) are fixed with trusses. I formed these by tying two lengths round the yards with loops in the ends at the yard. This was done off the model. Then the yards were put back in place, and the opposite ends passed through the loops and then down to the deck and fixed tied off to a double 3mm block opposite a single block hooked into the eyelet on the deck just behind the mast with a lanyard which ends on the cleat on the mast (or on the bitts if you've forgotten them!). There's a good illustration of this in the instructions, and an even better picture in Lennarth Petersson's book... but here's my attempt.
Parrel beads (top / topgt yards)
The maintop, maintopgallant, foremaintop, and foremaintopgallant yards have parrel beads in two rows with parrel bead separators between them. These are noted as being castings in my instructions, but were in fact brass etched. They need blackening / painting before you begin. Then you have to start the tortuous needs-five-hands-at-least task of getting them rigged.
To make this easier, I did as much as I could off the model..5mm rope was looped round the yard through the footropes, where it would finally end up, and parrel beads were threaded onto the rope, interspersed with the spacers - currently only on one rope (paying attention to which way round the spacers are - the curved edge will face out from the mast when fixed). Then, the other end of the rope was passed through the other hole in the spacers.
The picture will make it more clear, hopefully...
Once done, masking tape is applied to the loose ends to stop it all falling off...
...and the yard is then attached to the mast (it's pinned). Then the loose ends can be passed round the mast on the inner side of any rigging, ensuring that it isn't above or below any blocks that it shouldn't be... and fastened with a knot into a loop in as inconspicuous fashion as possible.
I'll admit, I'm not great at this... but it's done for another model!
I've seen others put extra layers on from this point to go round the middle of the parrel beads, but I call it a day at this point... or my head hurts too much!
Here's an end shot.
The fore and aft booms on the mizzen mast are secured with a single thread with parrel beads on it, but no spacers.
Spritsail yard
This is placed in a sling as shown below... A loop is tied round the bowsprit, and then another round the spritsail yard. It's all tied off in the middle.
The spritsail yard stay can then be rigged...
Finally, the heavy loops that support the weight of the yards, and are formed with suitably heavy rope along with the big 7mm blocks which were rigged and pass down to the deck to be rigged to the eyelets just fore of the mast being tied off on the bitts.
So far so good. The gaps to fit one's hands in are growing smaller... but we're getting there.
Rob
8 hours ago, Ron Burns said:
Absolutely awesome program that keeps me from having to load up Photoshop every time I want to post. It literally took me seconds to load the program and resize 3 images. Thank you for something that is actually useful!
You're very welcome
Great start Hope you won't mind me pulling up a chair and sitting in on this build.
I used Original Marquetry for my boxwood and they were really helpful (even ringing up to check details on the order), and the veneer seemed to me to be very good quality. I found it pretty tough to get it to sit flat on the hull as I put down the second planking, but that was my skill level, not the wood's fault! There's less wriggle room than with the thicker planks. I don't regret using it. It has a really lovely colour.
Hi David,
Many of the ideas are from other builds on this great forum, so I can't claim them for my own, but please do take whatever you find helpful and use to your heart's content. I'm very glad to hear that the software is proving a help as well. I look forward to seeing lots of updates as you progress. Diana makes up into a stunning and very impressive model!
Thanks
Rob
Okay - the new video describing the functionality in v1.0.5 is now live... and since then I've updated it to v1.0.6, which also brings support for GIF, TIFF and Windows Bitmap (.bmp) files.
Hope it's helpful. All questions / comments, welcome.Here's the video.
More functionality. Version 1.0.5 is on the website:
If you check the checkbox that says: "View each file individually before resizing", it'll come up with an image preview window for each picture that's going to be resized. In that window you have the option to manually rotate the image, and/or flip it horizontally or vertically. Then you can either resize that image, or skip it, and it will go on to the next image that's queued up to be resized.
Again it doesn't make any changes to the original file. Just the new one. I haven't documented it yet, but I will when I get a moment, and I'll do a video too.
Hope it's helpful.
Rob
Calypso by Fuji - FINISHED - Billing Boats - 1:45
Hi! Looks like you're doing a great job of this iconic vessel. Hope you don't mind if I follow along.
