KenW
Posts posted by KenW
  1. I’ve been working on the two remaining sails: the gaff topsail and the main topmast staysail.  I made both sails and started by attaching the staysail to the main topmast stay and then attempting to furl it.  I couldn’t get a furled sail that looked reasonable. However, I read in Darcy Lever’s , “The Young Sea Officer’s Sheet Anchor”, that the staysail was either brought down to the foremast and made into a bundle that was stored on the top.  Or, it is taken down and stored below. My boat doesn’t have a top and my bundle looked horrible so I decided to store the sail below deck. I left the halyard hooked to the stay block and considered the problem solved. I wanted the gaff topsail, however, to be furled and seen.  The furled bundle is nowhere as bad as the staysail, but … I do know that I need to replace the gaskets; and I may consider adding a silkspan covering, if I can, to make the bundle look more appealing. Any suggestions would be welcome.
    Qu7c725NiEPFxw7VXSe12dGZvmWzIboA9gq5r4EFN6iYj-3nuPctr-eLRDKST7jN8Vp3zA_AAkpe85ET8KaAgyGPaa8o3II8aPZQreBYIfzBw0SNUeOfpiglhP_FS8Lr4HyD_nyU
    fek8M0VUF6fkaQhnQXAyRERRfUQvyqDjXM57hwqGVaObTIPO0IFIyNh38OIbWxs7H0oa4F0Isq6PH2FR0-dxaqQTr5gDb_ClNukhTwh6uf5pmF_MPYF6sP6L_xyjoaOB3IhUU5ki
  2. The fore topmast yard and sail were installed without too much trouble.  The shrouds were also added as well as the fore topmast stay and back stay.
    0__IRQQhvgSHkzFjz8zoxUEWAdT5mBMnsAavft9VFcoh2I0vxo33H-9d35Ed8FcYQlEytpC901BWngp8SncoA5dlfjNn66HAjxXGsfyN7Et-nB2XSLJBM6Hji_4gomX2nRvJ46Bx
    3lbx9DwNPp1VFn_Q1SAmeSPij0mtwkN6m2AdgPB8UgmEdL-HM98ExKBjLQiyumZPLIW10_aiDT3Qpj_dd6dhgXv6z8IQPYaWsROEpyY3a2XTRxiZR-VsjUPoUWtTaXISVd3KlScA
    vhVhhmEYtHiqaMtuYbUaC9ehKDtu0DknzgKG4ro--CtakjOMy5qK-JrXHIVf8p2lX-aflHOshmlgXCJYQf0iAz-zCOf2GLZqt2QlyN-Ylf4xkI94TD5NOMt6EYtZ74IxnchC0rQs
    One thing I noticed is that the way I’m tying off the rigging is very similar to the rigging plan that came with the kit.  The differences are that I’ve given all the stays and fore topmast yard lifts the ability to be adjusted. I believe this was done on all ships.  One thing the rigging plan, and my rigging, have in common is that the fore bit is becoming very crowded.
    ecK0Rp6cWs9eqdjqIZ8CXWnZ6-EHLBoteMJJF17_ezq5hx00jv770U6A0R3W3Ng7J3OPX8PYFiD-gjZOPTggRtJtL5K-yOxMLeonY95MRZ8m3sofAHJDN8QvcY9JdIYe4pIaBAzW
    I’m going to have a major task when I glue and trim all those lines and then add rope coils to that bit.  The deck looks very messy now, but I hope to change that soon.
  3. Since the last entry I’ve added the furled fore staysail and the jib.  Both were made from silkspan as described earlier and the furling was based on previous research.  I think the ‘look’ is good. The mainstay was added but not finished or tied off. Also, I decided to use footlopes or ‘horses’ rather than the netting that came with the original kit.  Somehow the net didn’t look right to me. I made netting, so if I’m challenged, I can always change my mind. I’m constantly changing the rigging plans from the kit to be more in line with my limited experience and research.  As a result, the boat looks less and less like the kit’s instructions and photos. I hope I haven’t created a boat that is completely different from what existed at the time.
    Next up is the fore topmast yard and sail.  I feel I'm getting closer to the end.
  4. I added the standing rigging in the bow section; specifically the forestay and jib stay.  I’m exploring ways to rig all the lines and not use too many timberheads or space on the bitts.  I always worry about not having enough room to tie off all the lines. I did use two timberheads, but I think everything is going well and I’ll find the space somewhere.
  5. Next up is to step the main mast and its rigging.  The shrouds, vangs and halyards are the same as on the fore mast; while the boom topping lift is different.  I also changed the way the brails are tied off. The new method frees up space and is similar to most of my research.  I also added the jib boom in preparation for rigging the fore stays and sails, as well as the fore topsail.
    Edit to enlarge the photos.
  6. Thanks for the comments Dave, and yacht1255.
    Thanks also to MtZigg.  In answer to your questions:  As I remember the sequence of events, I first planked the deck and then the first layer of the hull.  Next, I planked the inner bulwarks, followed by the final layer of hull planking.
    I've been using silk span from this site:  https://brodak.com/silkspan-lite-white-only-2-sheets.html
    I use the thinest silk span, which Brodak calls "Lite Silkspan BH-916".  As described in my entry I laminate three sheets together using white glue diluted with water at a ration of 1 part glue to 7-10 parts water.  When it comes to furling the sail, I wet the sail with water and form the furl.  Once the sail dries, it's stiff but looks good.  You can always re-wet and re-form the furl it you think it's necessary.
    Hope this answers your questions; and, good luck with your model.
  7. After a long period of attention to my group build, I’ve returned to the Independence.  Since the last post I’ve tenuously added, without glueing, the lower fore shrouds. But my main focus has been on the fore lower sail which is a gaff sail.  I want the sail to be brailed and look proper. When I attended the meeting of the Northeast Clubs at New London, Connecticut, I acquired a collection of designs of ships published in 1882 in Paris.  One of the plates shows a ship very much like the Independence with brailed sails. I want my model to look like that ship. But I couldn’t get either cloth or silkspan to behave. I came up with the idea to make the sail in two parts.  The first part is what is furled up to the gaff; and the second part is what is furled to the mast. Some photos:
    DOHvmbpEsaPRm0t8YLN3kKet_YPKbIbRSL6-7ksdVeFv_7fNH5y5VubZ85ZwEkExwPMxmuMs_3bVEkQgkEyEPrq20aPmbhmCSJrACfBuQbhQWh1nVbixgiJRNwrUdfAoksW18vuk             LZk9u5bYTPlz8uo6Rs5D6Be1BfFyxK0AuTXiUo2PKTcmjy-Ge8F3xoPppskZV3hLlIkpTgLgvLiCMmrkc6c81V39rm29FAyfj34m7WVnrzdFmoM9YNft8BFzq2MElqC7V_Qipk1V
    The piece that is furled to the mast I done first.  Then the diagonal part is furled to the gaff, with some effort to merge to two pieces together.  (Not a good explanation, but it’s the best I can do.)
    579TAXTFyAQ9GDiVKDHNHH8GsoT6fH7bTVt_YixKZTD-BKSrTVV-VFOVX0Ih44ydhFj59uDngNytyFNM8TrEbdeU2AMok59yuxJQ6ew_3a06OSsBX_1epCp8La2BS8hj3mR5rWu7            ZFML8uroekJcp4bx7Np5hzymt2gzq20oAqtgZkAozQJefb_9BTu8f5ifxjlCQqneVXIu_0GQf_Ew6gvPGKsgQkpo0M1M9MpOZQC6U4UnD2DqDFzxOD8L2_7V6U94_qCn9UZBXpmv
    The last photo shows the sail brailed exactly as shown in the 1882 plate.  (I’m not able to get a decent copy of the plate to include here.)
