Everything posted by alde
It's been a while since I posted to my build log. Progress has been a little slower than I would like but it's been moving along. The hull is almost planked and I am pretty happy with it for the most part. I have been using the plank patterns provided in the plans and they are shaped pretty well but I ran into a bit of a problem. I did the upper belt first and then started working from the keel up and when got to the middle I started to run out of room to get the correct number of planks in. I will be 3 planks short on both sides and some of the planks will be too narrow. I am basically faking them in. It will look alright but I'm glad the hull will be painted. It still has a nice shape to it. What I should have correctly laid out the number of planks on each bulkhead and trimmed each on to fit the tick marks on the bulkheads correctly. It's a good lesson for next time and should be pretty easy to correct on the next build. Here are a couple of pictures as she sits now.
You continue to amaze. Thanks for more inovation for the hobby.
- 1,051 replies
- cheerful
- Syren Ship Model Company
Congratulations on the award and the fantastic build. What's next on you build list. I'm sure whatever it is you will build another winner.
- 659 replies
- syren
- model shipways
More fantastic work Sal. You and the other Syren builders are making the kit shine.
- 659 replies
- syren
- model shipways
JesseLee, Your carronades are a huge improvement over the kit parts. They look like total junk compared to what you are producing plus you will have the satisfaction of having done it yourself. I am looking forward to seeing them installed and rigged. They will look great. Feel better my friend.
- 1,306 replies
- syren
- model shipways
Mick, I remember when I had 20 years to go. I know it's hard to belive but it goes pretty quick. Especially the last 5 years. I enjoy my job working for the Navy but have been at it nearly 37 years. I have to deal with some health issues and do plan to make ship modeling one of my priorities. I sure I will be looking for help and encouraging words in the process. I plan to get my keel parts made for the cross section in the next couple of weeks since I have the box wood and pear. May as well jump in with both feet.
- 504 replies
- washington
- galley
Hi Mick, Thanks for he encouragement. I am still at the kit phase right now and just learning how to work with wood and some of the tools. I have the books and plans for the HMS Naiad and that is one of my ultimate goals. The Washington will be a great stepping stone for me once I graduate to a fully framed model. Right now my work quality is pretty low compared to what I see from some of you guys on the forum but I expect that at my level. I will retire from my job in a couple of months and will have much more time to put into the hobby. I will probably start building some frames and other parts pretty soon to see how it's done and work with some better wood than I am use to in the kits. I have a couple of pieces of boxwood and swiss pear to play with. I may try one of the cross sections to get started. That's a great idea.
- 504 replies
- washington
- galley
That looks great Mick. You are making super progress. I have this set of plans in waiting. I may start it next year after I get more experience. Right now it looks like it would be overwhelming for me.
- 504 replies
- washington
- galley
She looks fantastic Sal. Congratulations on a project well done.
- 659 replies
- syren
- model shipways
Good luck on your first build. It's quite a kit to start with but it looks like you are willing to take your time . I will be happy to stick with you to the end. I am just a beginner too and hope to learn from your experience.
- 117 replies
- constitution
- model shipways
You sir, are a master with a file.
- 1,051 replies
- cheerful
The planking slowly continues.I finished up with the upper belt and have started working my way up from the keel. I am pretty happy with the way it's going so far and it's definitely getting better and easier as it goes. I wish I got more time to work on it but really have a great time when I do. Thanks for stopping in for a look. I hope to have more progress fairly soon
Looks great Tom. Now you can throw that kit part in the scrap bin.
- 1,354 replies
- constitution
- model shipways
Spiling Tools and Questions
alde replied to daveward's topic in Modeling tools and Workshop Equipment
Dave, the widest Scotch tape I could find was 3/4" wide. The problem I see with the masking tape is transferring the plank width from the tick marks to the tape. I guess they can just be measured with a divider after the tape is off the bulkheads and transferred. That would be easy enough but add an extra step. If you could trace the line of the previous plank, mark the bulkhead locations and transfer the tick mark while the tape is on the hull you will have a complete pattern for the plank on one step. -
I picked up one of these adjustable curves to try and it looks promising. The kit I am building now has the spiled planks drawn on the plans so I don't need it for this project but having them drawn and cutting and fitting them has been a very educational process. I may us the tape and curve method on the last belt just to try it. In Chuck Passaro's planking tutorial he uses clear tape. I sent him a PM to ask what type of tape he uses and he said he just uses packing tape from the Post Office and a fine point sharpie to mark the line, bulkhead locations and plank width at each point. It sounds like a pretty straight forward way to go and Chuck sure gets great results. -
Cutter Cheerful 1806 by rafine - FINISHED
alde replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Man that's nice. It sure builds into a pretty little cutter. Your rigging looks fantastic.- 525 replies
- cheerful
Your wheel is 500% better than the kit part. It's going to look great when it's all assembled and in place. Is the basswood from the kit just not workable with machine tools? I was thinking of using my Sherline lathe to taper the masts on my current and future builds but may just get some boxwood to do that with and not even bother with the kit wood.
- 1,354 replies
- constitution
- model shipways
US Brig Syren by Gahm - Model Shipways
alde replied to Gahm's topic in - Kit build logs for subjects built from 1801 - 1850
You sir are an artist. -
You can see how much finer the dust is with the boxwood. I can't imagine it being easy to turn the basswood and get good results. Thanks for giving such detail. Al
- 1,354 replies
- constitution
- model shipways
