Came out great! You would have to know it was there in the first place to even notice it. Sometimes as model builders, we are our own worst critics and nothing is ever perfect enough. That's me, anyway, and my OCD disorder. :huh:
Thank you for that,  I am quite pleased with it, using the magnifier I can paint cleaner with my fine brush.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
You know, there's something else I thought about that happened to me one time before...
I had this magnifying glass that was attached to a movable stand. Well, it was in just the right place where sunlight from my window came through and it darn near started a fire in my workshop. A set of plans were scorched from it. Taught me a lesson about leaving magnifying glasses in close proximity to a window and sunlight.
This makes A lot of sense and I think is the Cause, I had my magnifier (6 inch round one)  on the stand and there was strong sunlight coming through over my shoulder,  I will learn a lesson from it.
OC.
Current builds
Completed works.
The plan for tomorrow -  Finnish off touching up the Ap507B mid grey colour around the stern and the bow, that will finnish off the camo on the Port side.
After letting this settle for a bit it will be the turn of the Starboard side - repeating what I have done but minus the repair work to the damaged section.
OC.
Current builds
Completed works.
I finnished off touching up both Ap507C  and 507B  so the port side is finnished.
Here are a few pics folks.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Good recovery OC, as if she came straight from the slipway
Carl
Thanks Carl.
OC.
Current builds
Completed works.
A  written update folks minus any pictures at the moment,   as all I am doing is the same on the Starboard side as I did on the Port, Its careful work as I am not using any tape for masking, and just hand painting the camo to where it meets the angled Torpedo Bulge,  Its slow going but tidy.
OC.
Current builds
Completed works.
I thought it was appropriate to say a Big Thank You to all those who  constantly keep pressing the like on my build - It means A lot  folks :dancetl6:
OC.
Current builds
Completed works.
it happens to everyone from time to time........things look bleak.   there is light at the end of every tunnel ;)    she's look'in splendid now....super!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks mate,  its actually more enjoyable now, as I am working in small areas at a time, and feel that much more in control, a couple more days and the hull painting will be finished.
Next will be a bit of minuture drilling out of the pump outlet pipes.
OC.
Current builds
Completed works.
Just been doing a bit more tidying up of the starboard paintwork, and while at it I have also touched up a few other areas including the spernwater and edge of the hull side/deck edge.
Here are a few photos that give an idea of the progress.
OC.
Current builds
Completed works.
gett'in her back in order,  in fine shape!  look'in good  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank You - Yep she getting there a bittttttttttttttttttttttt  at a time ;):)
OC.
Current builds
Completed works.
That's some mighty fine brush work there, OC.
Beautiful!
Thank You so much, the lesson I learned was just to work in a small area, work under a strong magnification and keep the psint quite thin - like skimmed milk, dry it between coats using a hairdryer, and after three or four coats the acrylic paints tend to smooth out nicely.
OC.
Current builds
Completed works.
Next job on the hull will be to drill out the bilge pump pipes that run just above the bootline, this photo shows the location of them.
OC.
Current builds
Completed works.
I finished tidying up the Hull and even re painted the props,  and have now moved onto the rear deck area,  I started in the same way as the other deck areas by firstly sanding off slightly the raised plastic deck boards, to get a smooth flat surface for the wood deck to sit on, next will be to paint all the protrusions that stick through the deck when its down,  next I will cut out these fittings on the wood laminate and tidy them up, before fixing the laminate wood deck down.
Here is a picture showing the laminate wood section and the sections to be cut out.
OC.
Current builds
Completed works.
Just posting a pic to show the current situation - I painted the areas that will stick through the wood decking,  and  also cut out these areas on the wood decking.
OC.
Current builds
Completed works.
Another area I plan to work on after the rear deck is in place,  is to scribe a couple of armour lines into hull, where they were most noticable, this will be along the shelf hull and on the extreme bow, I have done a drawing to show what I mean,  and the Stern.
OC.
Current builds
Completed works.
More work on the rear deck laminate today,  I managed to cut the deck section away from the sheet it was attached to then did a bit of dry fitting - adjusting - dry fitting  etc,  then the "Hold breath"  stage again where you get just one chance to lay the Very very sticky laminate,  again starting from the rear turret  and carefully placing it down pressing gently as I went.
It went down with a slight portion to one side but this just ment a bit or trimming around obstructions and the edge to balance it out.
Here are a few pics fisrtly showing the laminate down and the rest are how the whole ship is looking to date.
OC.
Current builds
Completed works.
Here's  my next stage folks  - fitting all the PE  deck fittings - hatch covers and the like.
OC.
Current builds
Completed works.
I got round to placing the PE  hatch covers to  day  -  18  in total,  the normal tip  I use  for doing this is to apply a small amount of White Glue by a paint brush tip,  then move the PE part into place with the tip of my modeling knife
Here is a few pics folks.
OC.
Current builds
Completed works.
Managed to get a bit more work done today on the rear deck,  I built up the rear access hatches starting with fitting the four plastic frames (a bit like cold frames)  I glud these down with my revel glue, then this afternoon I cut out the four hatch covers to go ontop of these, from the PE fret, these were again glued down with PVA.
Here's a pic of the progress  folks.
OC.
Current builds
Completed works.
Nice work OC matey.
You have come some way since my last looking in here.
I am not sure, but by your pictures you are going water line, if so, good choice.
PVA is a good choice to and it works for railings too, a little patience works wonders.
Great stuff.
Frank :piratebo5:
Edited by foxy
Nice work OC matey.
Great stuff.
Frank :piratebo5:
Hiya Frank    thanks for the comments,  No  its a Full Hull build as I got over the Hull problems I had,  the rear deck pics are while its not stuck down to the hull yet, works better that way.
OC.
Current builds
Completed works.
Did a bit more painting this evening  on the hatch covers giving them a few coats 507C.
OC.
Current builds
Completed works.
Folks still pushing on -
I have decided to apply a bit of artistic license with my build folks, my way of thinking is during the old lady's later battles 1943-1944, her captain considered her rear deck area near her rear flagstaff and right above her rudders, to be vulnarable to plunging attack, esp around the area of the rear hatches as these where considered a weakness from cutting into the light deck armour of just 1inch, so the captain decided to fit two armour plates of 2 inchs in thickness over the hatches, to give an additional layer of protection.
These I will fashion myself out of square secion plates and attach these via a frame.
OC.
Current builds
Completed works.
Looking good OC. Hope to as well as you when I work on my battleship
Looking forward to that  Carl.
OC.
Current builds
Completed works.
