great progress OC..........love the decking  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks mate,   yep it sure adds to the look of these ships :)
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hello again folks long time no speak - think i have been suffering from that SAD condition,   as i just have not felt like doing anything let alone the build, and poor ole lady has been sitting there wondering what she has done :o
So today i gave myself a kick up the behind and had a go from where i left off  - I continued with the rear starboard section and added another sheet of brass etch that had been cut to shape, next off was working on some of the front deck bollards and capstans, these required painting prior to removing from the plastic fret, then a little bit of cleaning of the holes on the deck ready to take the lugs on the bottoms of the bollards etc.
Just the two pictures folks.
OC :)
Current builds
Completed works.
Hi OC, mate i think we all have those melancholy periods from which we need to get ourselves re-motivated.   Nice to see another update, she is coming on very nicely.
cheers
Pat
just keep at it OC.........a little at a time.   I always think of the harder stuff and how to get it done.......by the time I get there,  I'll plow through and not even notice  :)   I agree....nice to see an update  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you folks  -  Very Kind Words  :cheers::) :) :)
OC :)
Current builds
Completed works.
More reclaiming mojo time cooked and eat a curry and then on all sytems go - so I carried on by replacing some of the bollards that had been knocked off, then on the rear deck - she had two assistant capstans that needed there mountings drilling into deck then placing.
Here are a few pics folks showing the work and a general view over the ship.
OC.
Current builds
Completed works.
Getting there mate. Are you going to weather her?
Hi greg.
I might do a small amount just the normal dark pencil for shadows,  and a darker shade of paint on some of the inside edges of some of the fittings, I will also add a bit of dry brushing with white to highlight the edges,  not sure about more dramatic weathering - rust salt deposits etc, I dont really feel comfortable going to far.
OC.
Current builds
Completed works.
More work again today - just a couple of hours, doesn't need photos as it just bits and pieces of small fittings like Ammo boxes either side of the forward 20mm shields, and sanding flat the tops of the bollards, and the additional small vent or two added free hand by first making a drill hole then dropping the vent into it.
Next stage will be the vertical vents attached to the two larger 15inch mountings, then adding a bit of two tone shading to them.
OC.
Current builds
Completed works.
More time  on the bench(dinning table) today  - i finished off the painting on the rear starboard bulkhead by applying the two tone camo, when dry helped by a few blasts from the hairdryer I fixed it in place on the rear deck,   so this has sealed in the deck ready for a few small bits and pieces before I give the deck a couple of coats of matt top coat.
Here are a few more pics folks.
OC.
Current builds
Completed works.
OC, you're progressing nicely. Warspite is shaping up.
Thanks Ken.
OC.
Current builds
Completed works.
Decided to lay down some flat top coat today - I was going to just do the the deck, but after I decided to do the hull top side including the boot line,  I have only done the one side as the top coat would skin quite quick,  and as I was applying with a fine brush I was trying to do a few watered down coats.
Here is a couple of photos that also show a slight amount of weathering, only shadow detail mainly.
OC.
Current builds
Completed works.
It does make those details stand out
Thanks Carl.
OC.
Current builds
Completed works.
Tomorrow it will be a repete on the other side again using a few thinned down coats with a brush, but as practice has shown me - applying as little as possible to avoid patchiness.
When I do the hull because of its area I will use a rattle can flat coat for that, as brush applying just wont work without it going patchy.
OC.
Current builds
Completed works.
Looking good OC - I was surprised how much detail popped with the top-coat; is it a  flat or a satin (semi-flat) finish as it does reflect light with a bit of shine to it?
cheers
Pat
Edited by BANYAN
Did some more work on the top coat with my small brush - spent about 4 hours doing it,  the application had to be done faily quick to stop the laquar gunging up, but also in small areas with controled dead stops like pipes etc,  I applied about 6 thin layers - so now the whole top hull section both port and starboard and the deck is flat laquared with acrylic.
No picture as it looks just the same as the port side.
OC :)
Current builds
Completed works.
Folks Im looking for a bit of advice  -  I want to get the hull finished all it needs is the Anti Fouling bottom upto the boot line dulling the gloss finish, its a good layer that went on with an enamel rattle can, I dont want to wait to get a clear matt laquar off the net   and no where near me sells stuff like that.
Could i key the area with wire wool or very fine sand paper if i mask off the boot line to avoid damaging the finish on it.
What do folk think?
OC :)
Current builds
Completed works.
I wouldn't OC as the keying with sandpaper/steelwool (even the finest will leave micro-scratches) which in time may tend to show grime, swirls etc etc - better to wait I think.  Then again, I have seen some high-gloos (but very hard) paint finished with a very, very fine wet&dry with no long effect.
cheers
Pat
cheers
Pat
Thank you for that - I have found some sprays that might do the job.
OC.
Current builds
Completed works.
Do folk think this Humrol Acrylic Matt spray would be ok - its says it can be sprayed over enamel or acrylic and is fine for plastic models.
OC.
Current builds
Completed works.
To err on the safe side, the only way I know to test is to spray the clear over a scrap painted with the same paint that's on your hull. Otherwise, you risk some unwanted reaction on your finished model.  :(
It's my guess that a spray acrylic would be safe sprayed over enamel. But I could be wrong. How long has the enamel been on the model? Enamel can take a very long time to thoroughly dry.
Hi there,  just checked back through my builds - I put the Anti Fouling on Two Months ago so guess it should be completely dry and set by now.
OC.
Current builds
Completed works.
well done OC!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Right then folk you would never call me impatient ;)  but I decided to try a new stratergy with my lower hull  flat coat,  I have some acrylic in a bottle that I hav ebeen using on my upper hull, anyway I decided to mask off sections of the hull starting with a section under the rear hull around the props, I made a box section with tape then mixed my normal skimmed milk thickness flat coat, and started to brush it on in thin layers drying with a hairdryer between each.
About 4 layers and it had a nice flat finish and was touch dry due to the heat from the hairdryer.
Next I masked off a narrow strip along and under the boot line, and proceeded to apply the top coat with my brush in the same manner as the bottom, again with drying in between each coat, again about 4 layers then I removed the tape and the flat finish was quite good.
The idea is to mask off another line tomorrow lower down and carry on in the same manner till the side of the lower hull is flat laquared,  then the main bottom will be done but that is a more controled area and not seen - so less worry about its smooth flat finish.
Well thats what I was doing today folks :)
OC.
Edited by Old Collingwood
Current builds
Completed works.
