7 hours ago, Louie da fly said:
Beautiful work, O.C.
Steven
Thank you so much.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
  • 1 year later...
8 minutes ago, SigEp Ziggy said:
Excellent Job OC!  I had to bring this build up to the front of the build logs.
Thank you kindly ziggy, she now sits in the display cabinet.
OC.
Current builds
Completed works.
  • 3 months later...
Hello again All,    while sorting through my little box's  yesterday  for my other builds, I cam across  some scall metal (Black)  anchor chain that must have come with my other Pontos bits,  but went missing  - didn't  know I had it, anyway  "question -question"   is it worth me  removing the plastic kit chain  that was painted white, and replacing with this scale Black metal chain?
OC.
Current builds
Completed works.
13 minutes ago, RGL said:
As long as you paint it, the shiny chains really distract
What  - dip it  and let it  dry  in what ever colour is appropriate, then fit it after?
OC.
Current builds
Completed works.
Just now, RGL said:
Depends on what colour they are in real life (I airbrush mine, Primer, base colour then a rust wash). Otherwise it looks like cheap jewellery
RN  used to be white I understand, and kept very clean from what I have seen on the net.
OC.
Current builds
Completed works.
Hi OC, long time....
Are the scales of the chain the same and period correct (if you are looking for authenticity that is)?  I don't know when it started, but a lot of anchor chain cables were painted white, but as suggested, yes the 'dib dabs' (as we 'seamen' branch were called by the stokers, greenies [electricians] and store keepers/box packers [supply branch] -  we would dib and dab a bit of paint here and there.  We would try to keep the cables nice and prettied up but that went by the wayside during operational times, especially if working the anchor a lot.
cheers
Pat
Hi Pat,    I have found these Two pics on the net  - one shows Hood with white chains  and  the other from Warpy's bridge  you can just make out the same white colour chains,   the problem with this kit ones they are way over scale.
The only White paint i have the the Admiralty paints Acrylic  in white.
OC.
Current builds
Completed works.
White is the way to go then :) .   You should be able to thin the Admiralty white with water if I recall,  several thin coats would be preferable so as not to clog up the chain links?
cheers
Pat
cheers
Pat
Thanks Pat.
OC.
Current builds
Completed works.
16 hours ago, RGL said:
Or Tamiya rattle can fine white primer
I have the Admiralty Dull White already  so guess thats the route.
OC.
Current builds
Completed works.
The Ole Lady's Ghost  -
OC.
Current builds
Completed works.
4 hours ago, shipman said:
Hi, I was hunting around and found your build, which looks like a grand job, I hope you don't mind me saying how disappointed I am with the fuzzy photography. I've trawled through 3 or 4 pages and given up. Such a shame.
At first my  phone/camera was playing up  hence why some of the pics were fuzzy, but thanks for bringing it to my attention.
OC.
Current builds
Completed works.
The standard of photography on this site is normally exceptional. I suppose numpty's like me have come to take it for granted.
A dedicated camera doesn't have to be expensive; I've been using a Fujifilm Z2 compact for years which I bought second hand and it was ten years old when I got it. Every time I download to my laptop I'm astonished how good it is. Stay safe.
What I will do  Is to do some updated pics now I have my  phone camera working better  (same one I use for my  aircraft builds  in here)   I have some work to do on the Ole Girl  (new chain)   so will do some fresh pics then.
OC.
Current builds
Completed works.
The pic above  was nearly in the dark, the imminunation off a  small sensor light created the shadow  (thats why I took that shot)   because of the  darkness  it needed ISO 2000  hence why it is grainy.
Just love the moodyness of an late night  dark shot  with taht shadow.
OC.
Current builds
Completed works.
  • 7 months later...
Just an update folks  - I received a message  on another forum about this build, it was from the  son of a gentkeman who served on  The Ole Girl, anyway he expressed how much he loved it so I passed it on with my blessing to him.
OC.
Current builds
Completed works.
OC,
That was a very thoughtful gesture and should bring you a lot of good ship building karma.  Beautiful job on the ship by the way.  I have always had a soft spot for this one; it just has cool old school lines.
Cheers,
Wayne
Current Projects:
Kate Cory - Model Shipways - 1:64
USS Massachusetts - Trumpeter - 1:350
1 hour ago, wemattson said:
OC,
Cheers,
Wayne
Thank you kindly Wayne, yep it just felt like the right thing to do.
OC.
Current builds
Completed works.
well done OC, that will also give you some more room
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
That was a very thoughtful and kind gesture; I am sure the 'karma' gods will reward.   In the meantime you can be sure many a person has wished you well on this.
regards
Pat
Indeed Kevin   - got my Chally  to go in there  when its finished  (probably about next christmas)☺️
OC.
Current builds
Completed works.
3 hours ago, Canute said:
OC, that was most kind. Nicely done.
Thanks Ken.
OC.
Current builds
Completed works.
regards
Pat
Indeed Pat, and thank you also mate.
OC.
Current builds
Completed works.
  • 2 years later...
Hi all,    during my flurry  of photo editing  I decided  to  do a  few  crops  of the  pics  I  took   or  the  Ole  Lady   during my  build  log  here  -  hope  they  give  a  bit  more detail  than the  ones  I posted  before.
OC.
Current builds
Completed works.
