After a lot of contemplation, I decided that I would start work on the Most current Volvo Ocean Race 2014-2015 Farr Yacht Designed Volvo 65. I am building her in a 1/4" = 1' - 0" Scale . I started researching this build while building the Volvo open 70 ( completed in the Gallery ) I started Cutting out frames and building jig while I waited for the Varnish to dry on The Herreshoff Buzzards Bay 14 ftr. I was hoping to have started this build sooner , However here we are , I have not decided at this point whether to build her static or let her free sail. I do have plans to build a larger boat that will be RC. Here are the drawings for the boat, wich I will be using for the graphics and colors
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Ok Here we go, I have cut out the frames and made the building jig , I then set up the frames and added the keelson , Next will be to add the Deck clamps ( port and starboard ) and fair the frames , to get her ready for planking . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
I was going to relax but this build will be too exciting for the rocking chair and foot stool.
Bob
Current build:  SS_ Mariefred
Thank you Patrick, I hope so she will be a challenge to build
Thank you Cap'n'Bob, someone has to keep you on your toes
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I started by adding the Deck Clamps to the Frames, Then I faired the Frames, at that point I realized that I needed to add the Keel slot and box ( to house the Keel ) Then finished Fairing the Frames, Next will be to plank the Hull. So far so good , she is coming out right on the money. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Dave B. I appreciate the vote of confidence,
Thanks Patrick, I am pleased with the results
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I started by finishing fairing the Frames. While I was fairing the Frames, I soaked the Balsa sheets in rubbing alcohol ( 3 hours )This will make the Balsa more pliable  , and easier to bend ( Alcohol also dries quicker than water , making the material ready to use faster ) . After that I started by planking the sides of the Hull, faired the sides to match the frames, then planked the bottom of the Hull. I then cut out the Keel slot and started to fair the bottom to the sides of the Hull. It is just a rough fairing at this point. Next will be to finish the Fairing , and seal up the Hull ( I will use Epifanes Varnish for this Process ) Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Just incredible that you get a non-fuzzy sanding job on the balsa.  I love the lines of her.
Thank you Mark , I Like the lines of this one as well , as far as Racing boats goes, I think the Farr designs are some of the best ( in the modern era )
Hey Patrick, There is no trick to the Balsa, I sand with the grain starting with 320 grit sand paper ( very lightly ) I guess the trick is going slow
Thanks Jay, Glad to see you here, I am building her as a static model, so no need to use the West System on this one . I was thinking about it this morning and I will probably just seal up the Hull by Brush coating Titebond 3 ( wich is water proof ) that should do the trick
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hi Jay, its nice to have you back
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, After completing the Varnish on the Herreshoff, I turned my attention to finishing the fairing of the Hull. I started where I left off with 320 grit sandpaper and worked my way up to 600 grit. after I got her close I brushed on a coat of Titebond 3 glue to the entire outside of the Hull. and of course This Hull design would make a great canidate for a sailing version ( just bump the scale from 1/4" to 1/2" Scale) in any event , the next step will be to sand with 400 grit and fill in a few voids and repeat the process and she will be ready to be removed from the Jig. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hi Marc, I am not sure about that , I am having a great time building them. Glad to have you along for the ride
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I started the day by fairing the hull, wich proved to be more dificult than I had originally thought. I figured that it would take "maybe" a few hours, it ended up taking all day . I got her close and sprayed a coat of flat white on the Hull . ( I figured that the lines can be seen more easily ) next will be to get a final fairing and remove the Hull from the building jig. Here are the results
Edited by Pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Well it worked, Painting the Hull Flat White did the trick , I was able to get the Hull faired more easily  ( it reminded me of my Racing days , I would Fair the Keel on a regular basis especially before a race ) I then removed the Hull from the building Jig. then got the Building Jig cleaned up and ready to build the next one. Next will be to lay out the Deck and get it cutout and attached to the Hull. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Patrick, She is Defiantly a Racing Machine, and she has been quite the challenge to build thus far
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
A very fine race-hull Pete,
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Nils, These are state of the art racing Boats
Thanks Jay, Fairing this Hul sure kept me on my toes
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
After completing the Varnishing on the Buzzards Bay ( for the day ) I started by sanding the top of the hull flush with the Deck Clamp. I then turned my attention to laying out the deck the Bass wood sheet is only 4" wide so I will have to scarf on the remainder. ( I left off the forward Bow section of the deck to allow for the proper fitting of the bowsprit)The next step will be to cut out the stations to allow the Cockpit floor to be installed, adding the Mast step and setting the deck camber . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Patrick, once the deck is on it should make a huge difference especially once the Cockpit floor is installed
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
