Hallo Nils
:champagne-popping-smiley-emotic  Alles Gute zum Geburtstag!
peter
Herzlichen Dank Peter,
Nils
Current builds
-Lightship Elbe 1
Completed
little update....
the first of the six machine room skylights (dry fit), not quite complete...
Nils
Current builds
-Lightship Elbe 1
Completed
Happy birthday, Nils.  I suppose those workers are singing the birthday song for you!
Great work as always -- your log is always one stop I have to make whenever I come to MSW!
Cheers
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Super work, Nils.
Ed
Thank you very much Ed,
Nils
Current builds
-Lightship Elbe 1
Completed
Cheers
Martin
Thank your greeting and your nice compliment Martin,
I`m very pleased if you look in regulary and you lke it....
the shipyard workers are looking for a place where they wo`nt be disturbed when having their lunch.....
Nils
Current builds
-Lightship Elbe 1
Completed
Nice lights Nils
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Many thanks Keith and Glenn,
and all the "likes"...
Keith,
doing the light lids in brass is quite time consuming, but decision was made, so push it through...
Glenn,
thanks for the greetings, and for looking in regulary, I`m pleased you like it..
Nils
Current builds
-Lightship Elbe 1
Completed
Nils
Brass is the right choice - they look so good. It may be time consuming but time hangs heavy on idle hands.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Nils
Thank you very much Keith,
for your encouraging compliment...
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
look'in good Nils..........the production line looks to be in full swing  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thank you very much Denis,
I`m about halfway through with the skylights part fabrication.....
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much John,
Nils
Current builds
-Lightship Elbe 1
Completed
John,
thanks for your nice compliment....., much appreciated..
I decided to mount the light lids in natural brass appearence (looks a bit more "technical" than a cover with paint). Had to carefully brush off the paint from the one I did upfront. Two of the skylights will show with open lids, and four of them with closed lids
Nils
Current builds
-Lightship Elbe 1
Completed
The thing about building a large passenger ship is that when you are finished you have become a master craftsman because of all the repetition required to complete the job.
Bill in Idaho
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
Thanks Bill,
sometimes I think its better that I did`nt know what all is involved with the build in the beginning, although it does`nt even look so tricky with this scratch build ....., but you`re  right,
I`m learning a lot of things "by doing", out of the necessity...
Nils
Current builds
-Lightship Elbe 1
Completed
Mike,
thanks very much for your words,
and also all the "likes" for clicking on...
relating to the sailing on these liners, take a look at the "rolling mode" of the KWdG ( nickname : Rolling Billy)  compared with the horizon at relatively moderate sea, trust many passengers had become seasick on those rides. Pic borrowed from the web...
Nils
Current builds
-Lightship Elbe 1
Completed
Update
machine room skylights (dry fit ) nearly complete.....
Nils
Current builds
-Lightship Elbe 1
Completed
too cool Nils!  ;)   did you manage to use the one you painted,  or did you make an extra one?    way too awesome!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Denis,
yes, the already painted one was used again......, I put a rotating brush bit on my Dremel and carefully removed the paint and primer. Now there shall go a coating of clear varnish on the brass surface
Nils
Current builds
-Lightship Elbe 1
Completed
Nils,
Astonishing. Your brass work gets better all the time ... They can't complain about ventilation in the engine room. That's certain ...
Carl
Nils, how did you cut the rims from the eyelets for your ports?  Bill in Idaho
 Hi Bill,
presume you mean the rims of the skylight panel lids....
The rims are made by inserting 2,5 ² mm lead sockets (for conduct wire ends) through the drilled holes in the brass panel, and soldering these to the panel. The German word is "Aderendhuelsen", sorry do`n t know the engl. term. I also used these for all the hull`s portholes
The remaining end at the rearside is then cut off, The skylight ports remain without "glassings"
Nils
Current builds
-Lightship Elbe 1
Completed
Many thanks Carl Bob and Oystein,
and all the "likes"
Carl,
right, trust the whole ship was well ventilated with all those vents, I do`nt know if there were perhaps electric powered ventilators somewhere in the line to enforce the airflow...
Bob,
thanks for your nice comment...
Oystein,
If possible, I like to avoid painting brass surfaces, it too easily looks like using plastic parts afterwards. An alternative would have been chemical blackening, but as I used soft solder with the rims and CA for securing the lid-hinges this would have given problems with the surface appeal
Nils
Current builds
-Lightship Elbe 1
Completed
