hi all
just a quick update on the latest progress.
the list of things to do is getting shorter and shorter!
must remember to order some 3/8 boxwood for the masts
getting ready for some intensive metal working anchors ,rudder pintles,gunport hinges etc
I get back to ur build log since a little time ans whaoooo good progress .
Of the bank I look at an ocean of pleasure, or the tumult attracts you, this global movement will be your tipcart!
current build:   royal caroline
buid finished:  la recouvrancehttp://modelshipworld.com/index.php/topic/3025-la-recouvrance-by-ofencer29350/page-2?hl=recouvrance
Glad to see some progress Mick. Nice work as usual.
Oh, can you tell us about that little brass plane? It looks like the perfect tool for model work.
Edited by alde
The heart is happiest when the head and the hands work together.
Al
Current Builds:
HMS Halifax 1/48 POF Lumberyard Kit
Model Shipways Glad Tidings
Acoustic Guitar Build FINISHED
Hi alde
Thanks for dropping by
Its nice to make some headway.....dont seem to get much time these days.
The little brass plane is a small thumb plane or more correctly a luthiers plane.
I will upload some more photos.
I think the brand name is e.s.e
Its only 1 1/4 inchs long by 1/2 inch wide.
Cant remember where i got it from.....definitely  pre internet days.
Cheers...mick
violin builder planes. I've been eyeing them, but they are expensive, since I'm temporarily into plastic builds, it stays at eyeing for now ... ;)
That is some serious fiddly work on the hinges, Mick. Doesn't look like brass much ... is it?
Carl
Hi carl
Violin planes,good ones anyway,are pricey.....ibex is a good brand
Steer clear of some of the far eastern stuff...some are good but most are dodgy.
Well spotted its not brass but copper...easier to work and easier to blacken eith liver of sulpher.
I shall make the anchors from copper as well
Still bending impossibly small bits of brass?
Cheers for now....mick
When work permits ... although it looks not half as demanding as your hinges ..
cheers mate
Carl
Hi all
On a slightly different note a lovely slab of beech arrived the other morning for the new workbench.
Still got to make some drawers for the left and right sides.....vacuum lived in the middle!
Bench top is 2m in length.....plenty of space for tools!
Just waiting for the danish too dry.
Cheers.....mick
so that's what you've been up to ...
Carl
not much "at work"
it's a rather contrasting view mate ... tidy on the one side ... a bit messy on the other ... the latter looks more like a spot in use ... although the part about the genius ... ;)
Carl
hi all
the saga of the hinges continues
the first attempt with copper was not entirely successful so decided to switch back to brass.
the hinges are nearly done ...just a load of 0.5 mm holes to drill....a lot of cleaning up and then to blacken
photos enclosed as per usual
It doesn't look that small ... so you've made some very realistic hinges, mate ... very commendable ...
Cheers
Carl
Very nicely done mick, how are you getting the ends on the hinge pin
Regards
Paul
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Hi paul
The hinges are 1/16  by 1/32 brass strip silver soldered to 1/16 od brass tube.
The pins are 1/16 brass rod soldered to the same diameter tube , the tube then filed to the width of the rod.
The two are connected by a 0.8mm diameter brass rivet which is cut off and the end peinned over with a small hammer.
The hinge will be glued to the gunport with epoxy and smaller rivets dropped through the holes to represent bolt heads.
The pin will locate into the hull.
Hope this helps
Cheers.....mick
Hi mick
Thanks it was the rivet part I was interested in, I couldn't work out if it was a nail trimmed off and peened on one end, did you anneal the rivet to make it more workable
Again Nice work at that size
Regards
Paul
Previous builds-
Among others 😁
Wow!!
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                           Iron Clad Monitor (complete)
                           Sardine Carrier which I will Name Mary Ann (complete)
                           Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
                           Light House Tende Beech (complete)
