Nice work, Bob.  Well.. it's a tug so I guess there's a reason for doing things that way.  Ease of line handling, perhaps?
Thank you all.  The only reason I can think of for the bollards on the bulwarks is to clear deck space.
Bob
Current build:  SS_ Mariefred
Having done mooring cleat sizing for even just an 85 foot boat, I have to say those must be some HEFTY bulwarks! Properly sized and designed cleats carry a LOT of load in them. Have you seen any photos of the boat that confirm the plans, or provide more clarity into how the arrangement might have been used?
~ Ben
___________________________________________________________________________________________________
Current Builds:
'Doll-Boat' - 1:12 scale 40' Cruising Sailboat
S.S. Edmund Fitzgerald - 1:350 plastic kit w/ Photo Etch Parts (On Hold)
Hi Ben,  Being a designer you would enjoy the Pequot website.  There are lots of drawings and tons of photos of the Pequot and here sister ships.
http://indicatorloops.com/usn_pequot_plans.htm
Bob
hey there Bob...........I finally caught up to you!  :)   what a fine looking build you have here.   the hull looks super........interested in seeing how you do the metal hull look.   I'll pull up a chair  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks, Popeye.  I'm learning a lot on this build.  So I'm not surprised you are, "interested in seeing how you do the metal hull look"  I am too.
Bob
As I said before, the hull was welded but the bulwarks were riveted.  I was going to show some welded seams on the hull but realized that at this scale the welds would not be seen.  On the other hand, thanks to Nils (Mirabell61), I am showing the rivets.
Bob
You can see here how the cleats and Bollards are mounted.
The rest show the riveting of the bulwarks.  They and the hull will be painted black which was standard during WWII.
Very Nice, Bob, she's looking good, Beautiful work
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Looking good on rivets, Bob.   I quite agree about the welds.  Unless they used overlapping plates, welds shouldn't be seen.
Thanks to all oh you for your good and encouraging words.  I need to paint the bulwarks but I'm afraid to paint too soon because I know the foil does not take pain well.
Bob
riveting and weld seams may not be prominent detail,  but it would be considered texture.  thinking back to the early plastic model,  rivets and seam lines weren't even tooled into the molds.    they were bland......wood modeling is no different really.   even if they were to get flattened down,  they would still be seen.   in wood modeling,  we try to add in these textures to give them realism.........expanding the medium out of the  'wooden ship'  box.   looking very good so far  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
is this aluminum foil Bob?   you could try the dull side out......it would be rougher and would take primer.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye, it's an aluminum foil tape used for ductwork.  It's .005 thick and has a waxed paper backing.  I usually use acrylic paint so I dabbed some on a scrap of tape and let it dry two days.  The paint came off easily with my fingernail.
Bob
super riveting Job Bob,
I know and experienced the paint coming off (fingernail test) in the beginning as well :(,  and to overcome this, I clean the metal thorrowly and carefully with acetone on a cotton cloth first and then apply a resin based paint without any primer underneath. The criteria will be if you mask a tape over the cured paint, and it does`nt come off, when peeling the tape away, then you`ve got it.... :rolleyes:
very nice work
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Thanks. I'll have to fine the resin based paint.  Is that the Mr.Base White 1000 you mentioned in your build?
Bob
Hi Bob,
the Mr. Base White 1000 is a filler primer I use for small wooden and and brass made parts.
The resin based paint applied without primer,  is the red one (pls. ref. to my posts  # 647 and #681 of the KWdG build log, also the black silicone based paint has a very good adhesion even to the shiny aluminium, but I do`nt know if that would be available in other colors...
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks, Nils, I'll look into that.
Bob
Finally the holidays are over and I can get back to modeling.  In painting the hull I messed up the rivet band so that had to be redone.  Plans are to paint the bulwarks and deck, install the rail and start on the cabins.  Here are the pictures for now.
Bob
Patrick, I always Look forward to what will be next.  It's great fun.
John, I do not know about military ships but my friends who do tell me during WWII the hull should be black and the deckhouse should be off white.
Bob
looking really sweet Bob  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks, Popeye.
Bob
Hi Bob, just read thru your log. Looks really good.
I think the color you may want to use for the deck-house is called 5-L Light Gray or 5-H Haze Gray. Vallejo and Testors both carry these as water based paints
Ken
Started: MS Bounty Longboat,
Thanks Ken.  The white I have is more of a warm white but going towards the gray makes sense.  I'll have to look into it.
Bob
Bob, I think back during WW II, 3/4 of the Navy was some shade of gray. Most camo measures were blues and grays, with some black on subs and some surface ships later in the war. A good site for USN camouflage is: http://www.shipcamouflage.com/.
Ken
