Gluing ratlines to the fore-topmast and fore-topgallant shrouds (to be trimmed later).
Finally glued the mainmast in place, and added the lower main shrouds - the starboard ones already had ratlines glued on and deadeyes in place, but needing to be attached to the channel.
Glued the dragon figurehead in place.
Carved oars for the longboat
And added the oars, the mast and spar (I haven't been able to find anything out about what rig these vessels would have had, so I've copied Dutch contemporary pictures and given her a spritsail rig)
And glued the hatch cover and longboat in place on the main deck. I had to wait until the mainmast was glued in place before I could close up the hatch - otherwise I wouldn't have been able to see when I was slotting the bottom of the mast into the mast-step - it's been quite a wait.
Steven
Always nice to follow this build and be surprised what some can do on this small scale.
Great "small" work Steven
To be honest, most of it isn't really much harder than in bigger scales - except the deadeyes! Oh, dear, they're a real problem (not threading them, making them small enough and drilling the holes so they don't split. Then finding fine enough thread to run the lanyards.
In the end I gave up on the deadeyes for the topmasts and topgallants - just wasn't practical - I just left them off. They're so tiny you really have to look hard to see they're missing.
Steven
I wasn't happy with how the ratlines on the fore topmast and topgallant worked out - cutting off the free ends with scissors, craft knife, anything, just didn't work well. Nothing was sharp enough, even when I used a brand-new craft knife blade. The thread "feathered" and went messy; sometimes even came away.
So I decided to try a different method on the main mast, and if it worked I'd re-do the foremast.
First steps the same - glue the shrouds together, and then onto the mast at the top, with a lot of free thread at the bottom. Then glue each shroud to the edge of the fighting top, with a small peg as a weight to pull the shroud straight. Then glue the ratlines on one by one, with an overlap at each end.
So far exactly the same as before. But here's the change. Once all the ratlines were glued on, I removed the shroud/ratline assemblies from the mast, turned them over on the cutting board, and trimmed the ends off with a sharp craft knife. Then glued the assemblies back in place.
20220213_131733.thumb.jpg.fff6b736e2923e680b1920e6b39fcffd.jpg    20220213_131915.thumb.jpg.3ac956d8e65b35c0b8f7fa4a0bab1bc2.jpg
20220213_132450.thumb.jpg.8c53a103a2fa1d5e534c8c802f614cea.jpg     20220213_152331.thumb.jpg.72ae90daf1ccab3166ff36c432178449.jpg
Still not perfect, but a lot better than the previous method. So I'll definitely re-do the ones on the foremast.
Now attaching the lower deadeyes, one by one, to the starboard main channel. NOTE: This is NOT the standard way of doing this - it's my own method that I evolved because I already had the shrouds and ratlines in an existing assembly, because I didn't know what I was doing when I was seventeen.
And all deadeyes in place (sorry about the photo quality). I was even able to re-use some that I'd made back in the day. I'll be fixing these in place with CA so they don't come loose when I tighten the lanyards, and also trim and fix the lower ends to the hull, as though they are the chains - because when I was seventeen I didn't know chains existed.
Now on the larboard side, temporarily gluing the shrouds to the main channel so I can glue on the ratlines to match the starboard configuration. Again, I'm re-using the old shrouds - in this case I never got around to gluing the ratlines on. Note the small peg used as a weight to put tension on the shroud.
All lower shrouds in place and beginning to glue on the lower ratlines - don't worry about the scruffy glue at the bottom where the shrouds meet the channels. That will all be sorted later when I add the deadeyes.
And now completing the main stay by adding its upper deadeye and lanyards. I won't fully tighten it up until later in case the other rigging affects the tension. As mentioned before, the mainstay splits into two and passes both sides of the foremast.
20220214_183038.thumb.jpg.77d1b37701aaa72da45bd6fc189796a4.jpg       20220214_183102.thumb.jpg.8ed7b474df4603926026227a3c303f92.jpg
Adding the main topmast shrouds.
20220214_174454.thumb.jpg.d66e93e29c0c432acf62894adcbd38e1.jpg   20220214_174621.thumb.jpg.999ab575a17c4ba01b02473cdc7562cb.jpg
And gluing the ratlines onto them.
20220216_123716.thumb.jpg.78b4003b14eb16ff0a62824b8116d18d.jpg       20220216_123633.thumb.jpg.fa2c86c932b1975a3f0012ddc7dfb10c.jpg
Steven
Edited by Louie da fly
Your model is looking very good!  Keep up the good work.
Results, not Excuses,
ChiefClanker
“Behold, how good and pleasant it is
when brothers and sisters dwell in unity!"
Ps 133:1
"And the sea shall remember its own."
The effort was worth it Steven; looking good.
cheers
Pat
Edited by BANYAN
Thanks for the comment, Roger, and to everyone for the likes.
I just looked at the date on the first page of this log. It's taken me over 6 years to get to this stage (though on further inspection it appears I had a gap of two and a half years where I did nothing on it. Don't feel quite so bad about it . . .)
Steven
Some good news and bad news.
First the good news; I've finished adding the ratlines on the larboard main shrouds.
In progress:
All ratlines in place but before trimming
20220222_201626.thumb.jpg.53148116a0bac21f1742219c1e224a4e.jpg    20220222_201636.thumb.jpg.c52b6d0911b68d410932e1312fc91300.jpg
After trimming
20220223_080448.thumb.jpg.05457c58fee6bb0ebd3be13ec01622c8.jpg   20220223_080503.thumb.jpg.cf02244c8d93740db3413a3483869762.jpg
Now the bad news - the main starboard deadeyes really aren't working.
They're all over the place, some of the deadeyes themselves have broken (red circles below - they're made of wood), they're different sizes, different distances apart, some twisted (yellow circle), the holes have pulled through so the lanyards terminate in the wrong places (blue circle) - and I have no idea what happened in the green circle. Add to that the fact that some of the lanyards got glued into the holes so I couldn't pull them tight.  Gak!
I think I really need to re-examine all of these, probably rip them all off and start again doing it differently. I've started experimenting, but not having a lot of success so far.:default_wallbash:
Steven
This is indeed not good
I think it is best that the grain of the wood of the deadeyes is in the same direction as the holes you drill in them.
Think about it first before you do drastic things 😉
I love the ethos on MSW: if it’s not good enough - repeat till (the builder) satisfied
Steven, you might consider using thin Paxolin (resin-bonded paper or cloth). Very strong and won’t do the splitting that wood is prone to.
 Bonus - it’s not too far from wood colour!
Disadvantage:  smell of phenolic resin when drilling
alternative: thin birch ply (0.4mm) maybe in two laminations depending on the thickness required
i make small holes in this ply with a needle - sometimes a hot needle
Both materials would laser-cut easily, toooo
andrew
Stop press:
Activity detected at Viking Shipyard!
blog creaks into action
Andrew
"Pas d’elle yeux Rhone que nous”
Kits under the bench: Le Hussard (Started in the 1980s)
Scratch builds:               Volante, Brig (R/C): Footy Drakkar "Rodolm" (R/C).  Longship Osberg (R/C)
Thanks everybody for the reactions, and suggestions on how to fix it.
Baker and Druxey, I really think that wood isn't capable of this kind of job - I don't have any boxwood so I don't know its grain would be fine enough, but I think it would be the only wood suitable - and maybe even that wouldn't work. I've tried pear wood and it splits as well. I've tried card impregnated with white glue and it works better, but still not really all that wonderful. Don't worry, I'm not going to do anything drastic until I have a better solution, but I really think the current deadeyes have to go.
Liteflight, I've never heard of Paxolin. Where do you get it in Oz? I don't think the birch would work any better than what I'm using, but I have considered the hot needle method - just a matter of practicality; over 100 deadeyes each with 3 holes, without burning my fingers . . .
Henrythestaffy, I'm sending you a PM.
Thanks again, everyone.
Steven
 Steven, I think you'd be better served impregnating the card with CA instead of white glue.
Have you tried a very thin CA to impregnate wood the size you need?  Otherwise, it sounds like  you'll need to go to plastic.
Steven,
Henry Grace a Dieu is looking phenomenal.
What’s the wood grain orientation on the dead eyes that are holding?
At that size, that would become a factor.
Also, I’ve used thin CA on small wood parts to shore them up before.
Building:
1:50 Speeljacht (Seahorse card kit)
Just to answer a question several of you have asked, the grain orientation is up and down or side to side (depending on which way up the deadeye is), not front-to-back. I think that would be an even worse invitation for the wood to split.
Steven
Steven
Paxolin, also known as Tufnol ( both trade names).  It’s Sunday name is SRBP ( synthetic resin bonded paper).  Resin is phenolic, and it’s equally strong in all directions at right angles to the sheet ( what we need for dead eyes
its stronger brother SPBF (Tufnol Carp) is the same resin bonded into cotton fabric - even stronger and tougher
they all seem to be available in Aus from electrical and gasket suppliers, 0.5 mm to 75 mm thick
https://agaus.com.au/?s=Srbf
https://au.rs-online.com/web/b/tufnol-/
I should go back and see what thickness you are using.  Tufnol  sheet goes down to 0.4 mm and I would guess you are using something like 1mm, or 40thou to its friends.
 Birch!  I was speaking of my favourite birch ply!  0.4 mm thick 3-ply.  A couple of laminations of that and little matters like “grain” and “ tearing” are history
Best way to make the lanyard holes would be laser - I have found many places in Melbourne who will laser cut from a program ( or drawing) and will supply material or use yours.  They might bilk ( or balk) at phenolic because of the fume properties.  Birch ply cuts beautifully, so they could nest many deadeyes and spares and cut them in one pass
Sadly my flying buddy with a CO2 laser died last year or I would offer to get them made as a trial
andrew
Andrew
Reread the shroud saga!
Reminded myself how small these bastards devices are!
Snippet of info that may help you or other threaders of gnats eyes:  fly tying thread is not round but flattish with many near-parallel strands with a slow helix (for good and sufficient fly-tying reasons).  It therefore can be split into thinner strands.
This info from https://www.bottledshipbuilder.com/topic/393-fly-tying-thread-for-rigging/
BTW - there is a staggering amount of info about the small side of model shipbuilding which we all might find interesting in the forums
I have some fly thread - again the thinnest that was available at a local shop called "the compleat angler" about 5 minutes from me.  They are probably still laughing on finding out the intended uses of the materials I buy
I'll have a wee keek at the fly thread and see if I can split it - I'm intrigued now
 andrew
Andrew
https://www.bottledshipbuilder.com/topic/34-thread-silk-rope-etc/?do=findComment&comment=876
This thread mentions actual sizes, and also the makeup of fly threads from multiple strands
andrew
Andrew
Steven, I have some 'privet' which is in the boxwood genus.  This is a dense wood which is very tight grained and strong, but as with any wood when you go thin, it loses strength.
I can spare you some if you would like to experiment/use it?
cheers
Pat
Thanks everybody for the suggestions. Fortunately it looks like @henrythestaffy is coming to the rescue by 3D printing a whole bunch of them for me. My heartfelt thanks, mate.
And this is the reason I'm having so much trouble making the deadeyes out of natural materials:
That deadeye is 2mm on each side. I haven't been able to make any myself that are smaller than 3mm. And keeping in mind that those three holes have to be big enough for cotton thread to fit through . . .
Steven
8 hours ago, druxey said:
Kudos to Henry!
I totally agree. Not only henry, but over the years I have had so much generous unselfish help from many MSW members which has been invaluable to me. This is a pretty special forum.
Steven
Steven i have two lots of deadeyes totalling about 250 so far. The sides are a bit straighter than the previous ones but not completely straight. I found they didnt print very well unless i added a bit of meat around the holes. I have made the ends a lot tighter as you wanted as well. I reckon if i print this amount again it should give you enough to complete your task . I should have them finished on monday for you.
regards
Paul205B5D32-F45B-4F4A-850B-6C488A85C0AC.thumb.jpeg.18ff37915b83ade1d90e3c54103f50f2.jpeg
