For those who are impatient to see what I have done with the ratlines, 1 picture of my progress.
Notice that I started at the bottom ( normal i think  :D ) and how higher I go, how better it goes….
I don't know if there is a measurement of the distance between the ratlines but I take 1 cm…….
It looks good , so I keep continue with that.
Really great, Sjors...
But, 1 cm is 75 cm on the original from the scale 1:75...
I understood... You run away from the numbers...
Edited by ashiponthehorizon
Best Regards…
Ferit KUTLU
Under construction: Frigate Berlin (Brandenburg Navy)
Hope: Frigate Wappen Von Hamburg (Brandenburg Navy)
So Ferit,
Are you saying it is to high ?????
I have to take it all off then?  :(
Or can I say that those crew members are giants??????
Or maybe there is another solution and take 0,5 cm ?
Ratlines would generally be 13 to 15 inches (33 to 38 cm) apart so at 1:75 scale .5 cm would be a good measure.
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
I don't know the exact distance acceptable...
As for me, maybe wrong but I had decided to rig the ratlines between 0,75 cm but the scale is 1:40. This means 30 cm.
As Wayne mentioned, you should double the work...
Sorry...
And if you use a rope of 0,5 mm that means 3,75 cm. It's too thick I suppose...
Best Regards…
Ferit KUTLU
Yup.... That would be the easiest solution.... Add another row between the ones you already have. Have you also considered using a card template? (Maybe you are but didn't show a photo of it.. ;) )
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Ok,
Looks like mathematics to me  :(
I was happy that I don't have to school anymore and now this…...
No sorry for it Ferit.
I'm happy that you pointed it to me.
And it is not thick wire….about 0.3 mm.
A row in between, that's it.
Yes Andy, I'm using a template but remove it before I take the photo….
My drawings quality are that bad that I don't want to show it to you  :D
If I'm doing it without that one, It never goes straight……then it looks if I'm drunk ( mmmmm not a bad idea  :D  )
bottom's up Sjors...........putting rows in between would be a good solution.   super job on the ones you already have though  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Randy,
You are a real friend  :D  :D  :D  :D
How are your ratlines going?
Thanks also Popeye,
I have done a few now and I almost like it  ;)
I don't know Sjors, they look pretty good to me, of course my eyes are not up to par right now....... but, if you don't plan on climbing up them, I'd leave well enough alone :D
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
My ratlines are improving but yours are neater. At least I understand the knots involved and like everything about this hobby, the first time stinks, the second try might improve and eventually a rhythm occurs.
They aren't pretty, and they are probably too far apart too but I'm working 'em.
I'll put pics on my thread later today... maybe :P
Thanks Frank but you are to late  :(
I have all ready place a few in between…...
@ Randy,
Rome is not build in one day !
Remember that !
For the distance….use a template behind the shrouds.
It works perfect !
When you closed the knot, Take a tweezer en pull the rope tight that is coming from the left side.
Then pull a little at the long rope and let it go.
Then you have a nice straight rope and a good knot.
Don't forget to put a little glue on the knot to keep him in place.
And I want to see pictures from you tonight !
And because I'm a Commodore and you are a Commander, you have to follow orders…... :D  :D  :D  :D  :D
Sjors that looks very neat and tidy, hope putting the ones in-between does not cause you too much trouble
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
Nice to see you at work on Le Mirage again Sjors. You are doing very well with the ratlines... or should I praise your spiders? :P
Padeen (Adeline)
"When there is a will, there is a way"
Completed build: Le Camaret - Constructo - static wood 1:35  (build log, gallery)
Current build (very limited modelling time at the moment...): HMS Fly - Amati/Victory Models - static wood 1:64 (build log)
Projected build: HMS Victory - Chris Watton's design - static wood 1:64 (when available..., no rush!)
Hi Kevin and Padeen,
@ Kevin,
It's no problem to fit ratlines in.
It's only more work …..
Adeline,
Thanks  :D
I don't use spiders…..I have gnomes  :D  :D  :D  :D  :D
Well then Sjors, your Gnomes are doing an outstanding job and should be rewarded - the ratlines look really good!
I will be sending mine over to you when it is time for ratlines.
:piratetongueor4:
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Hi Adam,
Thank you :D
I know a better way….
When I'm finished I'll be sending the Gnomes your way…. :P
I almost like the ratlines…..good that I like it because I have a few more to do…..and that on two of those big ones !
Master of ratlines...
I almost begin to believe that you love to rig them although the work has been doubled...
You will enjoy enough with your Mirage, with those all unnumbered ratlines... :-)))
This will make you be very experienced gnome handler...
BTW, your ratlines are strict, orderly and neat...
With doubled number, it should be really inspiring...
Best Regards…
Ferit KUTLU
You are to kind to me Ferit  :D  :D  :D
I have not done much because we where talking to Mobbsie on Skype but next week I'm a week off duty, so I can go on with those lovely ratlines ( or the Gnomes )
Gnomes, spiders, whatever... You're doing a great job on those lines that can't be named.   :)
Nice work on the ratlines Sjors. Good choice to insert the extra ones, I think you will be well pleased with the end result.
yes!!!!!  good to hear that it is not much of a problem.   actually,  it a good head's up for when you do the S.F.........it's all the same spacing.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Mark, Grant and Popeye,
@ Mark,
It sounds maybe strange but I almost like it to make those ratlines…. :D
You don't have to think what you are doing , just if you are on a conveyor belt ( correct word? )
@ Grant,
I'm all ready pleased.
I have now done a few and it looks better.
The Moderator in the house is agree with you :D
@ Popeye,
It's no problem at all, only more work…..
And it is not the SF but the SI…..
PICTURES, WE ALL WANT MORE PICTURES. Sounds familiar don't it.
Good job my friend.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Mobbsie…..
Be patient my friend !
First I have to fill up the spaces till I reach the part that was at the last picture.
Then you can see the difference !
I'm sorry for you but…..I have to work and can not the hole day working on my ship……...
I want to but that takes still about 10 years…. :(
@ Danny,
Thanks for the like :D:D:D:D
You'er starting to sound like me :(  with excuses !!!!......... at least get some pictures up!! :D
                         USRC "ALERT"
O dear,
Are you also starting against me Frank ????
Ok, I shall see if the light is good and I shall make a picture…..
One moment please !
@ Popeye,
We have also the SyFy channel  :D
But we have the hole serie at DVD at home...
Just love that serie…..
Best Regards…
Ferit KUTLU
