On 8/3/2021 at 6:27 PM, BANYAN said:
Hi druxey, not at all :)  While wire would be more authentic, I think cotton will serve just as well if I can get the right colour and lay.  I'm just being a little stubborn in trying for additional authenticity.
cheers
Pat
Pat...you are the only one on the planet who will be able to identify the heritage of the rigging line.  Your authenticity up to this point has been nothing but stellar.  Museum quality had been in your rear view mirror for some time now....I want to see some progress......As you know...I'm the epitome of impatience...can you help me with that?
Rob(adoring fan)
Current build:
Finished build:
Current build(On hold):
Ah Rob, you embarrass me; I don't think my work is that great when compared to some of the 'masters on here.  I am somewhat 'becalmed' at the moment due to research etc, but have a made a start on the spars and some of the fittings.  I will post a couple of small updates soon.
cheers
Pat
Pat,
In my opinion, your model is scratch building at its finest.  Not only is your workmanship first class, your replication of detail at this small scale is remarkable.  In addition you are modeling a unique subject and doing your own research as you go.
Keep in mind that some materials do not “scale” accurately.  While you might be able to find stranded wire, or solid wire of the correct diameter or solid wire to make your own, its stiffness will probably be “over scale.”
I believe that appearance and longevity of the finished product are what’s important.  There is no reason why properly stained cotton wouldn’t work.
Roger
Thanks Roger, appreciate your very kind comments.  I think you have convinced me that I will go with grey cotton/linen/rayon (not sure which yet) to emulate the wirerope.  I think your comment re scale provided that last little 'nudge' I needed to settle on a method.
cheers
Pat
I'm glad that you've come to that conclusion, Pat. I don't think you'll regret it. After all, if the original material for the hull were oak, would you really be impelled to use oak for a scale model? Obviously not.
cheers
Pat
Thanks bro.  Your doing great,  can’t wait.
Rob
Current build:
Finished build:
Just for Rob (and others if interested :) )
I have made a start on the spider bands for the three masts.  I experimented with several methods but settled on using my tried and trusted soldering a brass tube into a brass washer as the starting point.  Fiinding a brass tube that is of the correct diameter is the hardest as the OD can be thinned if need be, or the hole in the washer can be reamed out a touch.
Below are two shots of my progress.  The one to the right (as viewing it) was my test piece where I used a mild steel washer to work out how to set-up the mill to allow me to drill the 0.8mm holes equally spaced (for the belaying pins.  The specification is silent on the type or material used for the spiderbands - the belaying pins were specified to be brass.  I am going to leave them brass but equally, they could have been painted white.  I will part the inner part on the lathe to the same height as the test piece once I finish polishing it.
Points to anyone who can spot the error in the test piece.
cheers
Pat
Looks good Pat.  As for the error... I see it but won't mention as let others find it.
...and here I was thinking it was a band of spiders (mates to those guys that do rigging) ;)  :P
cheers
Pat
Looks like someone didn't have a rotary table for the test piece.  The holes are not equally spaced at 30 degrees. This where a lathe and mill spoil you as the spider band could easily be turned and reamed on the lathe then drilled in the mill. But certainly not cost effective for just one fitting.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
52 minutes ago, druxey said:
Or a rock band called Spider?
If you google "glass spider" you get pictures of David Bowie. From Wikipedia - "The Glass Spider Tour was a 1987 worldwide concert tour by English musician David Bowie, launched in support of his album Never Let Me Down. "
Steven
Thanks for the laughs guys; the levity is much appreciated while we are in lockdown :)
Seriously though, back to the product:  yep the spacing was out between three of the holes.  Greg, I did use a  a rotary table for the test piece but I made the error (about half way through) of miscalculation/set-up in only progressing 20 degrees instead of 30 degrees.  Shows you really need to concentrate. :(
I am having some difficulty finding the appropriate stock (tube) to use for the mizen mast spiderband.  I need brass tube of 5.75mm ID, or something close to it with enough meat in the walls to ream it out a little.  I have searched the online stores here in Australia, and some overseas with no luck.  Does anyone happen to have a short length of something suitable that I could use?  Edit: or point me to somewhere I can et it?
cheers
Pat
Edited by BANYAN
Pat,
i had a look in the junk box and found a spent .243 cartridge case.  The business end of it is (of course) .243" ID which is about 6mm, but this section of the case is only about 6mm long.  If that's any good to you I'd be happy to send it when our lockdown allows me to get to a post office.
John
cheers
Pat
Sall good Pat....its was just a test part...hense the word *TEST*.  your soldering job was very nice for sure.
Say...how you doing with all the lockdowns there in your neck of the woods........?  Makes getting modeling supplies a bit tough.
Rob
Current build:
Finished build:
Hi guys, thanks for the offers; much appreciated.
Rob, speaking for myself, but I am sure many others, are well and truely getting tired of the continuous lockdowns - made all the worse by idiots who will not do a few simple things - only interested in their own interests.  Now that our vax levels are getting better we are all hoping to be able to avoid the lockdowns.  Online has been OK during the lockdown but some supplies are getting scarce - I have heard a rumour K&S have stopped making some small shapes which may explain why I can't find much.
John, thanks for that; certainly a fall back option.
Tony, many thanks - much appreciated.  I think I can easily stretch the 5.5mm ID tube on a mandrel to make it work; but either would work as I can ream out the thicker walled one.  Would greatly appreciate a short length of either.  Please let me know costs and postage etc.
cheers
Pat
Hi all, thanks to Tony's generosity I was able to complete the spiderband for the Mizen mast.  The dust on the base of the mast is where I was sanding it ready to put on a coat of finish.  I think the series of shots posted earlier, along with these are self explanatory as to how I made these.  Once the set-up had been worked out it simply became a matter of production line activity.  The final photograph is of the masts with their spiderbands and collars (I have yet to simulate the wedge shapes on the collars)
cheers
Pat
506506271_Stocksolderedandroughcleaned2.thumb.JPG.58fa209ff4cee229c546da9f1a43c022.JPG
 Nice, precise work on the spider bands, Pat.
Sweet work Pat...fine machining.  I've yet to use my rotary table to make spider bands...you did magnificent.
It's this kind of precision work that sets your model as the bar to be aimed for.
Rob
Current build:
Finished build:
Hi all, many thanks for the likes and comments; they are much appreciated.
Tony, I used the thin walled one as its' ID was pretty well right - just need a very small stretch with a mandrel.  The mill set-up is all Sherline.  The rotary table is actually part of a horizontal indexing accessory bed from which I remove the rotary indexer head and fix it to the mill x-table bed,  The drill is fitted into a 'sensitive drilling' accessory which makes life a lot easier.  Once I had determined the angular spacing, all became a 'production run'.
I am now debating how to create the 'wedges' in the mast collars.  My initial thoughts are to use the horizontal indexing accessory mentioned above.  The more difficult decision is whether to lightly score them in, or simply mark and draw in with a hard pencil.  My worry with scoring them is that I end up snapping/splitting them based on the grain direction.
I meant to mention in the earlier post that the lower masts in Victoria were red pine (the upper where needed were yellow pine), so the colour has come up pretty well.
cheers
Pat
Hi folks, a question (or two) and hoping for some answers or pointers.
I am still sorting the rigging of the vessel based on the imagery and the Rigging Warrant.  I have also raised a question in the 'Masting, Rigging ...' area :
Also, I am trying to determine which of the imagery re traversing mast hoops is correct (the hoops that slide up and down the mast).   The photographs (where I can make it out) shows that the foremast had 7, the mainmast 8 and the mizen had 6 hoops, whereas the lithographs both show the foremast with 13 hoops, the mainmast 14, and the mizen 6.  Normally I would accept the photograph as the better evidence, however, in very rough terms, the number of hoops would result in a 60 inches (5') between each hoop when the fore-and-aft sail was fully hoisted.  The same calculations result in about a 32" spacing using the higher numbers in the lithographs.
To my mind the 60" spacing would be too far apart placing too much pressure on the luff at those few points?
Can anyone please advise of a reference/pointer that might provide some guidance?  I would appreciate it also if anyone can help with the linked question, but would greatly appreciate that each question is responded to separately in the appropriate topic area to prevent any confusion and duplication.
cheers
Pat
regards
Edited by BANYAN
Pat, just a couple of comments on your questions in the last two posts:
- you wouldn't need to worry about showing individual mast-wedges. They would normally be hidden under a painted/tarred sail-cloth cover that is nailed down to the deck and to the mast. The upper edge may also be fastened to the mast by winding a thin rope around it, that would also be painted over.
- the eyelets/cringles for the mast hoops are usually set into the seams between two sail-cloths. Sometimes there is an additional in the middle of the cloth - this depends on the angle with with the cloths run against the mast and, hence, on the effective distance between the eyelets. The sail-cloths would normally run parallel to the after edge of the sail, so the angle at which the cloths intersect the mast depends on the angle of the after edge of the sail.
- the hoops are normally strips of flexible wood that are thinned out at the end to overlap. The overlapping ends are 'sewn' together. At this point the hoops would be lashed to the eyelets/cringles of the sail.
