HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
WOW Carl, that's all I can say. I need an optiviser looking at those pics ^_^
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Nice work Carl, plenty of detail and well worth the frustrations.
Mark - I wouldn't recommend wax of any type unless you are absolutely sure you will get it all off before painting?
cheers
Pat
Thanks Piet. You need larger pictures ... hmmm. I'll need to take my tilt/shift lens out. The only one with a wide enough angle ...
Carl
Thanks Pat, about the frustrations ... I'm not so certain ... there is a level one shouldn't exceed to avoid throwing with things :P
Edited by cog
Carl
Started priming some of the parts, they're drying now, dropped one which I can sand and repaint, fortunately not the tower ... or some of it's parts. So before getting all ... you know what, I cleaned my airbrush, and made myself a log bench from a piece of cherry ...
Needs some smoothing, but we can sit, and I can ponder on my multitude of building erros ;)
Edited by cog
Carl
Carl, very nice work. I don't think they make strong enough meds for the migraine I would get trying to work with parts that small.
Regarding the tweezers and Marks candle wax idea, would tool dip work? You should be able to thin it down. Or maybe a rubber cement like Barge?  You can think that way down and get a thin coat that might work.
Sam
Current Build Constructo Enterprise
HI CARL
NICE TO SEE YOURE STILL TOILING AWAY SHIPMATE.
I HAVE A NICE 4" BELT SANDER ,WITH SOME 60 GRIT BELTS,THAT WOULD FLATTEN THAT GARDEN BENCH A TREAT!!!
PITY I CANT DO MY GARDEN...RAINING AGAIN!!!!!!!!!!!!
ACTUALLY GOT SOME TIME OFF SO WILL BE DOING SOME BUILDING MYSELF FOR A CHANGE.
MUSASHI LOOKING GOOD....WELL FIDDLY ALL THAT PHOTOETCH.....BLACK CARPET THE ORDER OF THE DAY FOR ALL THE BITS THAT PING OUT OF THE TWEEZERS.
CHEERS FOR NOW...ALMOST RATION TIME.....MICK
Thanks for your concerns gents, and your support(!) it is well appreciated
Sam, I bought meself 3 detail up sets, Pontos, Fly Hawk, and Eduard. Now I can have some of the tiny parts jump around like fleas without me worrying about loosing a piece :D
Mick, Maybe you should come over - jump the creek - and have a go at smoothing out my bench ... You can do it in the garage,. dinner included, just let me know your preferences ;) - I know a few persons whom would like to trade places ... How's moving, and settling in going?
Carl
Some samples of my priming work, three to four layers each to get it covering the plastic. I'll be adding some dark tones to get some depth in the final layer(s). Right now it is a bit "sterile"
(Piet, hope these cause less "anxiety" on your fragile eyes ;) )
IMG_0416.thumb.jpg.31e1872ac484ad8ae81d6b328db0ce9d.jpgIMG_0417.thumb.jpg.02a65efc101beee372eafd68f15463ab.jpgIMG_0418.thumb.jpg.3452b67557c40661d2d2291a53ea23a2.jpgIMG_0420.thumb.jpg.5ab5ea981ff5aa1038bbc7950f4afe5b.jpg
Still some more airbrushing to do. Enough practise with this build(!)
Carl
Nice work, Carl.  It really shows when the image is clicked and enlarges.  (Piet..  hint.. hint... great for tired eyes).  I forget to click on the first batch above... my bad.
Edited by mtaylor
Thanks Ken. I used vallejo air primer (airbrush ready mixture),pressure about 10psi, and use a double action airbrush. I would like to get one with a bigger cup for the quantity I need to prime, right now I keep on filling it: Spray a few items, refill ... and repeat ...
I kept about 4" - 6" space between the nozzle and the item, but for the narrow nooks and crannies, for those 2" with low pressure
Edited by cog
Carl
I have a gravity feed.....but I don't use it.   I like the siphon feed better.   I have one that has different size 'feed' bottles,  but I'm still using the Testor EZ airbrush set up.   it uses the bottle that the paint comes in {1/4 oz},  and I can do pretty much the entire job with it.   your paint work looks great......glad to see your getting in some build time :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Dennis. I like the double action on the gravity feed airbrushes, especially with the mesh in the PE. I can blow out the paint which forms a skin over the opening in the mesh. So far I haven't seen a syphon feed with double action. Although I've got a syphon feed type, I never used it. I should have a try with the one I've got even if it is merely for large surfaces or priming ...
Yesterday evening I found I had still some additional pieces for the funnel and the barrels on the turrets. Got the knife out and tweezers for another PE session ... don't be afraid, still lots of PE left :wacko:;)
Carl
not sure that there is,  since the paint doesn't get routed through the nozzle...although I think it does with the Aztek 320.   I have this one......with extra bottles and at least two of each tips........probably $400.00 for the whole shoot'in match.........and it sits in my closet.   here I am using a cheap $30.00 set up.........it does the job though,  so I can't complain,  I guess.
remember to blink every once in a while.....OK! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Looks like a nice brush, Sam. Thanks for the information. I'll have to think about that one. First have a try at my "el cheapo"
Carl
These were sprayed at 20 psi, trigger pulled half open (thanks Pat) a lot less paint loss
IMG_3167.thumb.jpg.59c81e82794a773f2b267d12ea54e47c.jpgIMG_3166.thumb.jpg.726b6ad91b414c719990f8ea28da7024.jpgIMG_3168.thumb.jpg.d046b62a76da930cdf2cb88ac6a4c43c.jpgIMG_3169.thumb.jpg.48b083fcc9d75109d4a994288e3e0903.jpg
IMG_3180.thumb.jpg.1d5b3c9b8b78b23edbf4a75b768d91ad.jpgIMG_3181.thumb.jpg.690001b9673ec650b3beae6044d51076.jpgIMG_3182.thumb.jpg.4389a456d90260b7bc6196edddb8091a.jpg
And naturally, to keep my finger's dexterity into shape ... PE cutting and folding ...
IMG_3171.thumb.jpg.01c05e0fdd4b3d7492e5dc81ab45e6ca.jpgIMG_3170.thumb.jpg.491cd504c3ba74ded436cc6a1f5a6bbf.jpg
There is more where this came from ........
Carl
Nice even coverage there Carl; looks good.
I like the third-hand too :)
cheers
Pat
Thanks Pat. Your information on the pressure worked well. That 3rd hand ... looks familiar ...?
The only thing I need to get beter at is my usage of CA, although, it has gotten slightly better ... less blobs ... at least when you look at the funnel (first thing of the build with hughe blobs) and the tower later build with less enormous blobs ;)
Carl
No showable progress. Presently I am making the tripple 25mm AA guns ... 29 of them, each 17 pieces :huh: I cut them per type, batch production, I am at the second piece which needs to be bent into shape ... there are only six pieces which do not need to be bent ... at least I will have a couple of nights "bendertainment" ... see y'all soon ... in about a week and a half, two weeks ...
Edited by cog
Carl
nice bit of progress there Carl.  what color are you using?  quite a P.E. task you got going there ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Dennis,
Thanks! This is just grey primer from Vallejo ... the grey top layer will be darker (IJN Grey).
PE, well for this tool version there is a heap. I found out that the kit expected the tripple 25mm AA guns to be the covered type. So I got my new AOTS on Yamato and Musashi out, and it appeared that from the thirty five tripple AA guns only six are the covered type. The Fly Hawk set only has PE for eight uncovered, and for twenty seven covered (plastic & a bit of PE), the Pontos set has twenty nine uncovered. So that was an easy choice, at least to get all looking a like ... The difference between eight or seventeen pieces ... why take the easy way out ;)
Edited by cog
Carl
Nice progress Carl and your airbrush work loos super. Even with clicking on the pics I still had to use Gwen's binocs :P
Cheers,
                       VOC Ship Surabaya
Thanks my friend, still a ways to go, although the sheets with PE are showing lots of empty spaces ... Darn, must ask if I can upload larger pictures for you Piet ;)
Hope you and Gwen are living on the sunny side of life again!
Edited by cog
Carl
Carl,
Even if i was adept with an airbrush each piece would appear to be crying with all the runs. Caught your build late must have been asleep, by the way fantastic build first class.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Welcome aboard mate.
Thanks, very much appreciated. You might be astonished with yourself if you give it a try. To be honest, so was I when I first started :) If you do it regularly, it is "a piece of cake", although, I do not know about Greg (RGL) his magnificent weathering, looks far more challenging than a plain spray job ;)
Cheers
Carl
Got the perforated beams for the "flight deck" in place (need to take a picture during day time). Finished the covered 25mm AA (12x), and have all parts for the uncovered cut and bent. Remains to put them together. Easier said than done ... Unfortunately life keeps on getting in the way: Had to work last weekend again, so little progress (start to sound like Sam [src] ;) )
59d2b12294005_IMG_3190copy.thumb.jpg.e029d5e7f3364cdf22ff1f8789b10d9c.jpg59d2b12fc38e4_IMG_3189copy.thumb.jpg.1484e4d2d8a150b39f78d3f471b98578.jpg59d2b115926b1_IMG_3192copy.thumb.jpg.6cb1b63b29537a25f206997719478e32.jpg
Carl
as they say....any progress is good progress :)   nice work on the guns.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
