Background
It has been suggested that I should post a retrospective build log for my diorama of the sinking of the US gondola Philadelphia during the Battle of Valcour Island, Lake Champlain, in 1776.  The final result is shown under “Diorama” in the gallery of completed scratch builds.  A retrospective log may be unusual, but I hope that there are one or two ideas that others may find useful.  If too many people get fed up with it, I’m sure they’ll tell me.
The story started when I saw the Philadelphia in the Smithsonian in Washington DC.  Although she sank in 1776, she was recovered in 1935 and is now on display, complete with the 24pdr British cannon ball that sank her.
The Smithsonian has published a set of plans which I obtained (with some difficulty!)...
.....but Philadelphia is a pretty basic and crudely built barge, and I decided that it wouldn’t make a very interesting model on its own.  However, there is a modern painting by Earnest Haas of the US galley Washington standing by the Philadelphia and taking off the crew (Photo 4), and it struck me that this would form a good diorama.
Washington was captured later in the battle, and the Admiralty, as was common practice, took off her lines.  The draft is now in the National Maritime Museum in UK, and has been reproduced in a number of books.  (I should add that my model was built before NRG published the plans for Washington).
Although both vessels were small (Philadelphia is 53’7” OAL and Washington was about 80’ OAL), I have run out of room for large glass cases, so I decided on a scale of 1:144.
(......to be continued)
John
Diorama, Washington & Philadelphia - 1776.  1:144 scale scratch build
Sir Edward Hawke - Schooner, 1776.  1:72 scale scratch build from H Hahn plans
Matthew - 1497.  1:25 scale scratch build from Colin Mudie plans
Mediterranean Cog - 1343.  1:40 scale scratch build from Xavier Pastor plans
Nonsuch - 1650.  1:32 scale Aeropiccola kit
Caustic - gunboat, 1776 . 1:36 scale scratch build
Philadelphia
Philadelphia is flat bottomed with the deck at several different levels, so the starting point was a solid former made to the moulded (i.e. inside planking) dimensions of the below-deck area, screwed upside down to a plug so that the assembly could be held in a vice while the former was shaped to the hull contours.  A print of the waterlines was glued to the base assists in this process.
This former was to be planked and become part of the final model, so the next step was to remove it from the plug and add stem and stern posts and deck details (planking, lockers, etc.).
A second former was cut to the moulded dimensions of the bulwarks, and a rail added to define the sheer line.  This former would also be planked, but would need to be removed after planking and so I gave it a good coating of a release agent.  I use candle wax dissolved in paraffin.  The lower former was then attached and the whole assembly screwed to another plug.
Because of the difficulty of aligning interior detail at this small scale, the mast support (essentially a large thwart) was inserted at this stage and held in place by a temporary rod so that it could be fixed to the planking as that progressed.
I then planked the formers from the bottom up to the sheer line using 0.02” thick lime (basswood), with 0.04” lime for the wale.  Below decks, the planks are glued to the former, while those above are simply edge-butted.  I use PVA.  Once that had dried, the screws were removed and the shell removed (gingerly) from the upper former.  Having incorporated the mast support helps to give the shell some stability, which was then reinforced by adding internal knees and a capping rail.  Unfortunately, I did not take any further photographs until a much later stage, after the awning support, guns and most of the figures had been added,  However, the shape can be judged from the photo below.  For ease of handling, the shell (which has a solid base) has been screwed to a block of ½” chipboard.
(....to be continued)
Edited by John Garnish
John
Washington
Once the shell of Philadelphia was complete, but before starting to add the details shown in the last shot in the previous post, I put it aside and embarked on making the hull of Washington.  This would be a waterline model, to be set into the water surface.  My approach was similar to that used for Philadelphia, in that the part of the hull below deck level would be solid and incorporated in the finished model.  In this case, however, the upper former was complicated by the fact that Washington had a tumblehome so the plug needed to be modified so that it could be extracted from the shell of planking.  I made it in three pieces, located by steel dowels, in such a way that – once the planking was complete – the centre section could be lifted out and the side pieces collapsed inwards.
This photo shows the degree of tumblehome, especially aft.
With the upper former well coated with release agent (candle wax) and the lower former screwed to it, I was then able to plank the hull.  Again, planking below deck level was glued to the lower former, that above simply edge butted.  However, before removing the upper plug, I tacked a printout of the elevation to each side to enable the gunports and oar ports to be cut out.
In this way, the sides – which at this stage are very fragile – are fully supported.  Finally, I was able to remove the plug ready to reinforce the shell with upper frames and caprails, and to add the quarterdeck.
Unfortunately, I seem to have let the camera take a holiday for a while and the next picture that I have shows the hull after painting and the addition of quite a bit of the detail.
I will mention some of these items later…….and, yes, the guns really were of different sizes.  Benedict Arnold’s fleet had been thrown together in a hurry, and Washington was armed with one 18pdr, one 12pdr, two 9pdr and six 6pdr cannons, plus numerous swivels.  Keeping track of the ammunition must have been a nightmare.
At this stage, a confession, which bears on the on-going discussion of what constitutes ‘scratch building’.  The deck planking and gratings are computer printouts glued to the deck.  I could probably have laid proper deck planking at this scale, but the gratings would definitely be beyond me.  Is this still a scratch build?
John
Fittings and details
Both shells were screwed to separate blocks of chipboard for fitting out and the addition of much of the detail.  Most of this was fairly routine and doesn’t rate a mention here, but there were a few points that may be of interest.
Shrouds and ratlines
I used black thread for the heavier standing rigging (shrouds and forestays) and brown or tan polyester cotton for lighter and running rigging.  For the shrouds and ratlines I made a simple jig which is just a strip of plywood a little over twice the length of the shrouds with the surface hollowed to leave a shallow rim, and a series of saw cuts along each edge at the correct spacing for the ratlines (about 2.5mm at this scale).  In the middle, I set a steel pin of the same diameter as the mast, and at each end a series of pins of the same diameter as the deadeyes.  This allows both port and starboard shrouds to be made up at the same time.  With the shrouds and appropriate lashings in place, I wrapped the entire length of the jig with cotton, using the saw cuts to regulate the spacing.
I then painted each shroud with a diluted solution of PVA.  Once that was dry, all the cotton outside the shroud assemblies was sliced away with a razor blade.  Removing the steel pins leaves a set of shrouds ready to be attached to the mast.
For deadeyes, I cut slices from a 2mm diameter plastic knitting needle – probably overscale, but I didn’t think I could drill three evenly-spaced holes in anything smaller than that – and then pressed them into the loops at the end of each shroud.  The final result after adding the lanyards is shown here.
John
Guns
As mentioned, Philadelphia and Washington carried a variety of guns from 6pdr to 18pdr.  At 1:144 scale, the maximum diameters of these (excluding the reinforces) vary from 1.7 to 2.8mm, with the intermediate guns scaled proportionally.  Working along the barrels, the differences in reinforce spacing for the different sizes are measured in fractions of a millimetre.
On my Unimat SL lathe the taper (2 degrees) is easy to achieve by setting the headstock over, but generating the reinforces at the correct intervals rapidly taxed my mental arithmetic.  Accordingly, I modified the lathe with larger graduated hand wheels and, more importantly, a digital readout along the axis.  This greatly eased the problem of spacing the reinforces correctly.  The results are shown here (a UK 5 pence piece is identical in size to a US dime).
I spent some time trying to work out how to produce convincing shot to fill the shot garlands, given that at this scale the diameters are between 0.6 and 0.9mm (0.024”-.036”).  In the end, I settled for poppy seeds.
I haven’t mentioned the swivel guns.  A visitor, peering into the box where the cannon barrels were stored, commented “Oh, you’ve got some bits of swarf here”.  “Er…no…those are the swivels!”.
John
That's remarkably good miniature turning on the Unimat, John!
Thanks, Druxey.  It would have been almost impossible without the digital readout.
John
John
Crew figures
At the time of the battle, Philadelphia’s crew numbered 43, while Washington had a complement of 80.  I couldn’t see how to fit that many figures on the model – nor, to be honest, did I fancy having to make them.  I wanted to convey the idea of purposeful urgency, not rush-hour travel.  In the end, I fitted some 35-40 figures to the model.
I based the figures around an armature of 0.91mm copper wire (0.036”, 20 SWG, 19 AWG).  Head, trunk and legs were formed as a V, with the apex pinched together, with a soldered cross member.  The ends of the V were flattened and bent up to form feet, and the armature bent to a shape appropriate for the activity intended.  I filled out the figure shape with dabs of Windsor & Newton “Galeria” heavy modelling paste, applied with the tip of a cocktail stick.  Once dry, the paste could be shaped further with a scalpel blade and then painted with acrylics.
Sails and flags
Sails were made from lightweight copy paper (30 gm/sq.m - almost obsolete nowadays), dyed with cold tea.  The seams and reef points were simulated by pencil lines.
I used an inkjet printer to print the flags onto cigarette paper, taped to ordinary paper in order to feed it through the printer.  Once printed, with cigarette paper it is impossible to tell on which side the printing was actually carried out.
Diorama
For the base, I used a piece of 6mm foam-cored board, 26mm x 18mm, covered by a sheet of heavy textured water colour paper.  After cutting suitable recesses to take the hulls, I sprayed this base with water-colour paint in various shades of blue, grey and green.  When dry, I then stippled on a layer of Windsor & Newton “Galeria” acrylic heavy structure gel, again tinted with greys and blues, to simulate the lake surface.  After fitting the hulls into place, I added more figures as well as various pieces of floating debris, and touched in hints of water flow, etc., around them.
As one corner of the base seemed a bit deserted, I added a flight of fancy in the form of a separate small rescue drama.
The photo below shows a comparison between the Haas painting and the finished diorama.  I took one liberty in replicating this scene.  I cannot believe that anyone would undertake an operation like this with the wind aft, as shown in the painting, so the model shows both vessels head to wind.
John
Beautiful work at this scale.  I've been wanting to add a digital readout to my Unimat.  Now I know how, Thanks.
Bob
Current build:  SS_ Mariefred
    Superb work!!!
    When I looked at photo 4 and 5 of post 12 I thought the rescue scene was taking place next to the beach. I now see that what I am looking at is not the beach from the diorama but the actual ground.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Sorry, Chuck.  It is a bit confusing.  It's actually the edge of the diorama base and my kitchen worktop!
John
John
Thanks for posting John.  Very informative and some wonderful work there to study.
Joel,
    Wouldn't their heading be ship dependent?  The galleys would have been as you said so as to present a broadside to the enemy, but since the gunboats mounted their heavy gun in the bow I would think they would have been facing the enemy...south-eastish.
Chuck Seiler
They would have presented their heavy gun to the enemy and would have made a much smaller target, yes, Chuck.  That famous Admiral Benedict Arnold was in command: who knows?
There was barshot in the barrel of the 12 pdr, and the ball found in situ seems to have entered a bit from the bows:  who knows?
Maybe they anchored at the bows and moored to the next in line aft, harder to moor to anchors fore and aft with Army crews perhaps.
Joel / Chuck
Thanks for the comments, with which I agree.  However, Philadelphia didn't actually sink until after nightfall (".....about an hour after the engagement was over."), so there would have been time for both vessels to manoeuvre into a more practicable position.  Even if Philadelphia had remained at a single anchor (and Col. Haaglund's report mentions only bow anchors), she would naturally have swung head to wind.  I still maintain that the transfer would have been very difficult to effect with the wind aft.
The question would have been settled if I knew in which direction the wreck was facing, but I can find no reference to this in those parts of Col Hagglund's reports that I have been able to find.  Still, I'd be happy to be proved wrong!
John
John
John,
    I got the impression that they secured the anchor cable to bits in the stern so that 'downwind' had them facing the enemy.  I'm not sure where I got that from, but I know in my days with the navy were moored to a pier like that once or twice.  Since the cable was coiled up on deck, it would not have been hard to re-run it.  There are 2 bits aft, one either side just aft of the rear cockpit.
    You are correct, however, since both anchors were with the wreck it is probable that it was not anchored when it sunk.
Chuck Seiler
Chuck,
I certainly don't disagree with your and Joel's assessment of the situation during the battle.  In fact, they would almost certainly have had anchors out fore and aft, and probably with a spring on the cable to be able to aim the bow gun.
However, it seems that Philadelphia sank relatively slowly ("...an hour after the engagement was over"), so there was time for Washington to come alongside - and for both vessels to assume a more seamanlike position for the transfer.  This could well have included abandoning the stern anchor(s) and allowing her to swing head to wind.
It would be good if someone could track down a full report of the 1935 recovery to see whether it mentions the orientation of the wreck.  There should be a report in the United States Naval Institute Proceedings LXII (1936), but I can't get the search engine to play ball.
John
John
John,
    I have a copy of the thesis "The Continental Gondola Philadelphia-A Dissertation by John Raymond Bratton" from Texas A+M University.  It can be downloaded from the following site:  http://nautarch.tamu.edu/Theses/abstracts/bratten.html
    It goes into detail about the recovery, but I'm not sure it gives heading.  He does indicate both anchors were found in the mud directly under their respective catheads, indicating they were onboard when it sunk, eventually dropping off when the cables rotted.
Chuck Seiler
The other question is, even if we can find the orentation of the wreck, how long did she drift after being cut loose, did she drift? They would have cut her loose well before she endangered pulling the Washington down with her.
With being down a the bows, the wind would have pushed the stern downwind, as she sank.
Ron Thibault
Ron,
Good point.  I guess we'll never know.  In any case, it lets me off the hook!
John
John
At any rate, your interpretation of the wind is as good as any.  Most people who look will not even notice. They will be impressed with the overall diorama itself.
Chuck Seiler
I read through the Bratten thesis, what seemed to be the relevant parts, and there is no discussion of the heading either during the battle or as she was found.
There are indications that the crew was trying to jettison the waist guns, or perhaps to transfer them to another vessel, and both anchors were found underneath their respective catheads, indicators that she was drifting and about to sink.  She was also about 300 yds. south of the island, so traveled some distance from her place in the line, either after recovering her anchors or while sinking in the water column.  It seems unlike she would have dragged an anchor that far and have come down almost on top of it, so they must have been catted.
