6 hours ago, popeye the sailor said:
really superb progress Frank........truly great progresses to watch  :)   really enjoying how you make the parts  :)
Thanks Popeye, glad you're enjoying it.
4 hours ago, cog said:
Frank, exceptional, you even got Popeye stumbling over his words!!!
LOL - Thanks Carl!
Part 67 –Boom Hardware
Kathryn’s boom has three rings that serve various rigging functions (these will be covered in detail when we get into the actual rigging). The following process was used to make these rings.
First, an appropriate piece of brass strip was annealed by heating it with a torch.
The strip was then bent in half and the joint was pressed closed using a pliers.
Using a hammer, the bent strip was then flattened.  After flattening, the joint was inserted in a vise. The joint and approximately 1/8” of the sandwiched strip was held in the vise, and the two pieces of the strip that were exposed were spread onto the jaws of the vise, and then were flattened using a hammer.
A piece of brass rod of the same diameter as the boom was used as a form, and the strip was bent around this to form the ring.
The formed ring was then held in the vise for soldering.
After soldering, the tabs were drilled and then shaped.
This process was used to form the rings that would take two rigging connections, as in a bail on the boom or two stays on the mast.  In the case of rings with only a single connection the annealed strip was bent around a rod and the ends were pressed together and then soldered.
Almost every rigging connection on Kathryn includes shackles.  After trying several approaches for making shackles, I decided to use the following.
First, using a diamond cylinder on a rotary tool, a small needle-nose pliers was shaped to serve as a form for the ‘U’ shape of the shackle.
A copper wire (in this case 26 gauge) was held in the pliers and then wrapped around one of the jaws of the pliers.
In developing this approach, I first attached ringbolts to the shackles.
The ringbolts were made by twisting copper wire around an appropriate sized drill.
The pin vise holding the copper wire was in turn held by a manual drill, which made the ring-making process fast and efficient.
The rings were added to the shackle and the shackle was then soldered closed.
The excess ends of the copper wire were then clipped from the shackle, and the assembly was blackened.
After successfully attaching ringbolts to the shackles, I moved on to attaching shackles to the boom and mast rings that had previously been made.
The shackle was added to the ring and was then soldered closed using the tweezers setup of the resistance soldering unit.
After cleanup and blackening, the rings are ready for mounting to the boom and mast.
There are still a lot of preparations to be completed before rigging can actually begin.  The next few posts will likely be concerned with those preparations.
Cheers!
Part 68 –Boom Cont’d
The last components that needed to be made for the boom are three Reefing Blocks.  These are positioned aft of the boom Iron and bail, so they needed to be left to last.
The Reefing Blocks were made from 1/8” x 1/16” stock. Two holes were drilled for each block, to simulate the sheave.
The sheave was shaped using a chisel that was made from a #76 drill – the back end of the drill was shaped and sharpened using a diamond cylinder in a rotary tool, and was held in a small pin vise while in use.
The stock was then thinned down further in the thickness sander.  The side that would be attached to the boom was made as thin as possible (about half the diameter of the #76 drill, or .010”.
The blocks were separated from the stock and the forward and aft vertical edges were rounded.
After attaching the blocks to the boom, the boom is now completed.
There are many components to the boom.  The following is a summary of those components:
At the aft end of the boom, there are two boom irons with an embedded sheave between them.
·     The aftmost iron secures the fixed end of the Topping Lift.
·     The embedded sheave is for the Topping lift to pass through on the way to the Topping Lift Cleat.
·     The forwardmost of the two irons serves to secure the clew of the sail.  The line from the clew runs to the Topping Lift Cleat.
Moving forward, the next components are the Reefing Blocks discussed earlier. There are two on the starboard side and one on the port side of the boom.
Forward of the Reefing Blocks is a boom iron with a bail.  This is for securing the Main Sheet.
Next, there are two cleats on each side of the boom.  On the starboard side these are both used to secure the Reefing Lines.  On the port side, the aft cleat is for a Reefing Line, and the forward cleat is for securing the Topping Lift.
There are three fairleads under the boom for the Lazy Jacks, and a pair of cleats forward of these fairleads that serve as anchor points for the lazy jacks.
There are screw eyes located every 24” along the boom for the sail lacing, and a larger eyebolt is located at the very forward end of the boom to secure the boom lift and the tack of the sail.
The following photo shows the boom as completed.
Thanks, everyone!
Part 69 –Bowsprit Iron
In Part 67, iron rings for the boom and mast top were made by bending annealed brass strips to form the tabs and the shape of the ring itself.  This approach worked well for irons that have 1 or 2 tabs.  However, Kathryn’s Bowsprit Iron has 4 tabs as shown in the following photo, so a different method was required.
A brass tube that would fit over the forward part of the bowsprit, along with 1/8” x .025” brass strips for the tabs were used.
The end of the strip was formed into a small peg, using the rotary tool and files.  The peg was sized to fit into four holes drilled into the brass tube.
The holes were aligned using an index block in the milling table, and drilling was performed on the milling machine.
A jig was made from Corian with a hole for holding the tube and with slots at right angles to keep the tabs properly aligned while soldering the tabs to the tube.
The tabs were then drilled.  The drilling was performed using a series of drills starting with a #72 and progressing to a #53.
After the drilling, the tabs were roughly ground and filed to the rough finished shape.
The configuration was held in the three-jaw chuck on the lathe, and the ring was parted off using a jewelers saw.  For this work the lathe remained turned off, and the chuck was simply turned by hand.
The shape of the Bowsprit Iron and tabs was finalized by filing, and the iron was then cleaned up and polished.
The Bowsprit Iron was painted white and was CA glued to the bowsprit. The forward end of the bowsprit was also painted white.
Before the bowsprit can be permanently mounted on the model, the Trailboards need to be created and mounted.  This is a subject I’ve been working on and thinking about for some time, but I still haven’t determined the best way to create the Trailboards.  I’ll keep thinking about it while I do other work required for the model’s rigging.
Cheers, everyone!
Are you putting on the fishing weight?  ;)
Jerry Todd
Click to go to that build log
Ha-ha - no, Jerry - I don't think so.  I didn't notice the weight at the time I took the photo, so I don't know the story behind it.
Edited by Mahuna
Frank,
Keeps getting better!
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Only additional comment I would make at this point is that your work product is museum quality in my opinion!
In regard to trailboards. If you are considering relief carving I would suggest laser etching. I witnessed a very convincing demonstration of laser etch, at reduced power, that inscribed a beautiful stern banner on a model part. A drawing was scanned into Corel Draw and converted to a laser file that was compatible with the unit. Just a thought.
Joe
9 hours ago, John Allen said:
Frank,
Thanks John.  I'm happy with the progress - getting closer to the start of rigging.
Joe
Thanks Joe.  I've been looking into laser etching the trailboards, but the carving isn't the real issue.  The painting is pretty complex, and I'm not confident I can pull it off at 3/8" scale.  I did get some laser etching done on the name plates attached on each side at the railings.  I'll be posting some pics of that once I get them onto Kathryn.
Frank,
They could be etched and then the etching filled in with paint.   Might make the painting less daunting.
11 hours ago, mtaylor said:
Frank,
Hi Mark.  That's one of the alternatives I've been considering, but I'm still concerned about the painting.
Part 70 –Bowsprit Cheek Block
The Jib Downhaul runs through a Cheek Block located on the port side of the bowsprit, immediately behind the Bowsprit Band as seen in the following photo (just aft of the fishing weight :D).
The housing for the block was made from 3/32” x .020” brass strip.  It was first filed to a square shape.
The square housing was filed to a round shape, then the strip was annealed.  After annealing, holes were drilled for the shaft that would hold the sheave, and for mounting posts on each side of the housing.  The housing was then bent to shape.
The shaft for the sheave and one of the mounting posts were soldered to the housing.
The sheave was made from a 1/16” brass rod, center drilled to take the 1/32” shaft, and then parted off to be .030” thick.  The sheave was placed on the shaft without any glue or solder.  The side of the bowsprit will hold it in place.
A hole for the forward mounting post was drilled in the bowsprit.  After blackening, the Cheek Block was mounted on the bowsprit by gluing the forward mounting post to the bowsprit.  Another hole was drilled in the bowsprit through the aft mounting hole, and a mounting shaft was glued through that hole into the bowsprit.  A ringbolt was also mounted on the top of the bowsprit just aft of the Cheek Block.  This ringbolt will secure the clew of the jib.
The hole seen between the Bowsprit Band and the ringbolt mentioned above is for the Jib Stay, which passes through the bowsprit and is secured to the outer stem.
Thanks everyone for the ‘Likes’ and comments.
Part 71 –Bowsprit, Chain Brackets, Name Plates
Now that all of the prep work on the bowsprit is completed, it was time to permanently mount the bowsprit.  A hole was drilled through the bowsprit into the outer stem, and a 1/32” brass rod was used as a pin to lock the bowsprit in place.
The Bob Stay and Jib Stay (or Forestay) are anchored to brackets at the waterline area of the bow.
The lower of the two chains is the Bob Stay, and is connected to the lowest tab on the Bowsprit Band.  The upper chain is the Jib Stay, and this runs through a hole in the bowsprit to the area of the hounds on the mast.
These brackets are installed on each side of the outer stem, and were made from separate pieces of 3/32” x .020” brass strip that were shaped and drilled and then painted while still off the model.  An outer hole that extends forward of the outer stem is for support of a small post that has the chain attached to it. Two inner holes were predrilled to provide holes for pinning the bracket pieces to the lower stem.
The starboard bracket piece was the first to be installed, and then the port piece was installed using a small rod between the two to ensure alignment.
After both sides of both brackets were installed, the pinning holes were drilled through the brackets and into the stem.  Pins made from .015” brass rod were CA glued in place and when dry were snipped.
The name plates were drawn in CAD and then brought to a local trophy shop for laser etching onto some thin madrone.  The operator put tape over the wood before the etching so that when the letters were painted the tape would mask outside of the letters to prevent smearing the wood.  He also cut the outline completely through so that the pieces were fully separated.  He also burned the mounting holes completely through.
The following photo shows one of the pieces that were created.  The laser operator produced many more of the name plates than I needed, which gave me the opportunity to practice on them.
After sanding off the laser char, a thinned gold paint was used to paint in the letters.  Painting required three coats to arrive at a good cover and depth of paint.  The following photo is of a test piece that had not been cleaned of the laser char.
The tape was then removed.  Some of the very small pieces of tape (within the enclosed part of the ‘A’ or the ‘R’, for example) needed to be carefully removed with the tip of a hobby knife.
A coat of wipe-on poly was applied to darken the bare wood, and then brass rods were inserted into the mounting holes to simulate bolts.
The name plates were mounted on the bow and on the rear quarter of each side of the model.
Working on these name plates convinced me that I would not be able to paint the trailboards, whether or not they were laser etched. The trailboards have no bare wood, so there will be many borders where two colors need to be neatly painted. Even if I was confident in my ability to pull that off, it would take quite a while to do it, the laser etching would be fairly expensive, and the trailboards would wind up being hidden behind the Jack Stay chains that will run outside them.
My approach for the trailboards will be to create them in CAD and then to bring them to a shop that does color laser printing.  I hope to have them printed on card stock, and then glue them to boards that have been shaped to take them.  Hopefully we’ll be able to get that completed in the near future, since work on the bow cannot proceed until the trailboards are in place.
Thanks everyone!
Funny thing here Frank... not ha-ha but in a good way.  I can't tell the difference between the pics of the real thing and the model except for what's under it.  Water on the real, work table on the model.  More than once without those visual cues, I've had to look pretty hard to tell which is which.
Thanks Mark.  I've been fortunate that I was able to take a lot of photos during my two visits to Kathryn, and also have been able to find some really good photos form the recent rebuild.  A good friend also shared some photos he took of Kathryn at the time of the HAER survey.  These have all been a great help in trying to get the details right.  I'm afraid I'm a little spoiled now, and I've been thinking of how different it will be when I work on my next model - with only the basic plans to go by.
3 hours ago, GuntherMT said:
Great job, and I love the name plates.  Going to have to remember this method!
Thanks Brian.  I can't take credit for the method of taping and cutting the pieces as part of the laser etching.  The tech in the trophy shop (very near to where you work, by the way) is the one who decided to use that approach, and it worked out really well.
Frank;
When I was developing the decal for the Carrie Price, I went to my local print house. The best printer they had had a resolution of only 600DPI, the same as my old color laser jet. This was not enough for my 1/64th print. I had an Epson NX430 ink jet printer that had a much higher resolution that did a better job. So check the print quality of your printer, it may be better than the commercial house printers. You can use photo paper, or make your own decals. Check Micro Mart or Hobby Lobby for the decal kits. Printing it on regular paper will cause bleeding of the color at the edges.
Ron Thibault
Thanks for the input, Ron.  The commercial printing service I mentioned was referred to me by an excellent military modeler, so I'll give it a shot.  If it doesn't work I'll try what you recommend.
Part 72 –Mast Hoops
Kathryn has 17 mast hoops for the main sail.  In the past I’ve tried making mast hoops from brown wrapping paper, but wasn’t satisfied with the results.  I’ve also tried laser-cut mast hoops, but wasn’t able to find the right size, and I found that the hoops were very fragile because of the way they were cut across the grain.
I decided to try making my own by soaking thin strips of wood and bending them around a form.  I tried using Castello, but found that it split when bent into a tight circle. I discovered that American Holly is much more flexible, so I decided to use that for the hoops.
I made a form from a brass rod slightly larger than the inside diameter of the hoops.  A ledge of the appropriate inside diameter was cut into the end of the rod, just deep enough to hold the height of the hoop.  A slot was cut off-center.
Sufficient strips of holly were cut so that I could produce about 25 hoops.  These strips were stained with Colonial Maple – I stained them prior to making the hoops, because I thought there might be a problem coloring the hoops after they were glued together.
A strip for a hoop (about 2” long) was soaked in boiling water for a few hours, and then was wrapped around the form.  An end of the strip was placed in the slot, and the strip was wrapped around the form, making sure that the edge of the hoop lay against the ledge – this ensured that the hoop would be straight.  The hoop was then clamped and left to dry for at least 6 hours.
When dry, the hoop was then glued and held again in the form. The following photo shows a hoop after gluing.
The inside end was clipped off and the inside diameter was smoothed with a diamond cylinder in the rotary tool.  The outside diameter at the joint was reduced and smoothed.  Any misalignment of the sides was corrected by sanding.
Using this process, 2 mast hoops per day were produced. After all of the hoops were finished they were dipped in stain to darken them, and then were finished with wipe-on poly and left to dry on a glass plate.
The following photo shows the mast hoops temporarily in place on the mast.
Also visible in the above photo is the breasthook that covers the bowsprit from the stem inboard.  This was created by cutting and shaping a piece of flat stock 1/16" thick.
Every little step is bringing us closer to the start of rigging!
Edited by Mahuna
wow!  ...some really great progress there Frank :)   the bow spirit and hardware is very well done.   wish I had an idea for ya on the trail boards.......way too intricate for decals and such.   you could look into photo etch though...I'm sure there is lettering and frieze designs out there.   nice work on the boom and hoops,  they look great as well!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
2 hours ago, HIPEXEC said:
Frank
I'm going to challenge you to help me Saturday with some mini metal work.
I’ll be happy to help, Rich, and I’m sure we’ll get some help from the other attendees. Looking forward to it - come hungry!
