HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
On 2/20/2021 at 9:48 AM, JohnU said:
Hi Per,
While perusing you log I noticed you are using double-sided tape. I see that in other logs too. I've looked all over for a good double-sided tape but they are either too thin and designed for paper or too thick and designed for mounting parts permanently. What tape do you use?
John
Hi John, I used regular double sided tape you can find anywhere, craftstore, supermarket etc.
I use the Scotch brand.
Respectfully
Gentlemen and ladies (have to include them too),
I need your input regarding belaying pins, should I use the brass pins as they are or should I go with the blackened?
I have plenty of each.
And yes there is some touch up to be done before they are in place.
Respectfully
As discussed in previous postings the question has been what material to use for glass pane.
I looked into the super-thin glass, I am curious how they will hold up for transport with USPS or UPS?
Then the sheets were rather large and not so cheap either.
However, next to on the work bench I had an old billing envelope with that address window, and I thought to myself..... "hmm, maybe that can be used for the pane I am looking for?!"
Sure enough, it's clear enough to reveal detail underneath.
So, yes that became my window pane. Works great with CA as well.
Respectfully
On 2/9/2021 at 8:11 AM, JohnU said:
Hi Per,
No, he just said medical supply companies. Anywhere they sell stuff for microscopes I expect. I wish I could remember the blog name. I was browsing in the tips and techniques forum under painting and ran across a question about weathering. A responder to the thread said to check out "...., he's the king of weathering" or some such. I'll try searching for it again. He WAS INDEED the weathering guru. He even went into detail about how to do a realistic broken window.
John
John, I found a company making microscope cover on their website I they listed
Microscope Cover Glass - 24mm x 40mm x 0.14mm Thick (Number 1 Thickness)
This was the thinnest they had available.
One package of 82 each would cost you 36 dollars! phwee.....
Respectfully
2 hours ago, pwog said:
Hi Per, I think I like the black pins over the brass.
Black is a more common color for steel. The black pins aren't true to the prototype but they definitely look nice. The brass looks good on a ship designed to look pretty. Especially with natural wood finishes. Not a true model though. Brass would require some sort of coating or it will tarnish over time.
John
Ahh, what price accuracy and detail!
You could maybe resell to others in need of windows and recoup your cost. Set aside 10 or so for your own use and sell the rest for $1 each.
John
My Admiral didn't recommend the glass. They shatter way to easy.
She's been in the medical field for 35 years. She recommended super thin plexiglass or acetate film for the windows we  need.
Respectfully
Interesting. I bought some of that Scotch double sticky tape and it was about useless. Only good for holding paper. I try to stick something down and it just pops off. Maybe I got a bad or outdated roll.
I eventually found some tape at a hardware store that worked well. It was sold for mounting things but was thin. I also bought some fabric tape to try. It says it's for "permanent" mounting and I worry about it being too strong.
John
Looking good, Per.  I lean toward the blackened pins as well.  Interesting, in my vintage of the kit, the provided pins were the white metal variety, and I just stuck them in the rail as is.  I didn't go back through your entire log to see if the brass pins were supplied or aftermarket, but I did notice a difference in our box art.  Mine is old enough to be labeled "Canadian Fishing Schooner" while yours is "Bluenose".
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
Bob,
The part number from ModelExpo is MS1401B(r) according to my part list.
Bought a package of 150 brass via ModelExpo amazon site.... price 23 dollar (free shipping)
And yes, I leaning towards the black ones as well, the shiny brass doesn't look right.
Respectfully
hello Per.......catching up on your progress :)  I wish I had checked in sooner......I use a variety of acetate for glass......I've even used the film out of floppy discs.  my favorite though comes from the plastic packaging that a lot of products come in these days....you can harvest a lot of flat pieces,  but if you need a special curved piece,  what you need can be found there too.  there are a few products out there,  but what I use is Testor's window cement and maker,  which works well for port holes.  it dries totally clear so you can't see it when gluing a window in place.
I'm a brass fan,  but I do agree that the blackened belaying pins look better.  tarnish will occur if you have high humidity or haven't got the model in a case.  every once in a while,  you may find bags of silica in boxes....keep 'em . if you have your plans and stuff in boxes throw 'em in with 'em.....it will help preserve them from humidity.   your progress looks very good....... ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I have heard about Testors Window Cement and maker.
Will have to look it up on youtube, and see how it works.
Respectfully
Hi Per, I finally tracked down that build log with the glass recommendation. The guy who's a weathering guru. Here's a link to the page about glass. It's worth browsing the whole log. Lot's of tips and fantastic work. Be sure to check out the finished pictures.
John
A long time ago..... back in the stone ages I learned working with silver soldering.
In those days it was small items but I noticed today when I did it for the first time in 26 years it's not that easy.
But I am satisfied with the outcome, I made the small rings too.
Now I am hooked with soldering I do look forward to do more of it.
Once blackened I think it will be okay.
I am to leave the bowsprit natural in front and white inboards.
Respectfully
Worked to make one of the hooks......   Oboy! I have to say...... when I shot the picture I realized how coarse the items are.
But to the regular naked eye at a distance of 16" (40cm) it is perfect. You can't see the imperfections.
"Macro" (or as it should be micro in true photography) surely can reveal flaws in material.
The hook itself measure about 4mm overall length.
Block and hook are both from Syren Model Company.
Can't imagine other companies quality.
I am to replace Model Shipways blocks and non-existence hooks with items long time ago ordered from SMC (Syren Model Company)
Model Shipways blocks are about 1/3 larger than SMC, so just imagine how bad they would be in the picture.
I will do an upload tomorrow, for comparison.
The black cord inserted in the hook and surrounding the block is regular sewing thread. Which will be replace.
P3150541.thumb.JPG.f6ff6af66bd5d40b10cd041d6f1bc39a.JPGP3150542.thumb.JPG.80d4f23245cb9da82ed777195f962817.JPG
Respectfully
Hi Per you could but this .006" glass from Clover House for a lot less.
Regards
Richard
Edited by Retired guy
A comparison shot between SSM (Syren Ship Model) and ModelExpo and their block "according to same size"
SSM to the left and a ME to right.
Respectfully
  • 11 months later...
I have surely not payed enough attention to this girl, but in the background changes and movement forward has occured.
One area is the cabin furniture, the skylight gave me some headache about centering. Then I thought about tape, this way I could get the skylight perfect in all locations.
Respectfully
I have also shaped the masts (bottom parts).
Once shaped the will get a coat of pine varnish and clear varnish on top of that.
Respectfully
Great idea on using the tape. Looking forward to seeing your progress on the spars. Not yet sure how to stain / varnish mine as I approach that step.
Previous build: NRG Half Hull
Previous build: MS Bluenose
My masting in works.
20220308_001151.thumb.jpg.8532b2b45f11f170be8e566c98eb08ca.jpg20220308_002821.thumb.jpg.6e02f1ff88c89b98c09a32c7ee4e6ca6.jpg
Sorry for America and Syren in the background.😁😉
Respectfully
2 hours ago, ccoyle said:
Per, your workspace is far too tidy! 😉 Refer to pictures of my modeling desk for ideas on proper levels of slovenliness!
I didn't know we have stipulations how clean a shop can be..... tried to find it in our "by-laws".😆
Respectfully
Second dry fitted mast in place.
So far so good.
But I never realised the shere height of
masts from waterline
20220308_232219.thumb.jpg.44070c760c8de39857d82050bb013619.jpg20220308_232826.thumb.jpg.dd6ffd03dafe3b13e0b9b925e42f1930.jpg .
Respectfully
Re about other projects in the background - it's like a proper boat yard I'd say. There are always several ongoing jobs at any given time.
(just found this log)
Bluenose looks good. Tall and proud masts also. I guess, when you look at sailing photos of these era you can get a appreciation for the sheer amount of canvas and actually how tall the masts were (are). Especially if you can spot a rigrat handling the topsail when tacking.
Keep it up!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
     Thank you Håkan!
Respectfully
