This is a older kit picked up from a estate - someone with a large stash of model ship kits.  I bought 2 of the last 3 available - I didn’t need the wood for a  scratch build Essex so I only purchased the 2 kits.
I gather Aeropiccola has been out of the model ship kit business for many years but I can't be sure of the date of the kit.  The plans indicate they were published in 1984.
Since this an old kit I'll show the contents.  I am quite satisfied with the quality of the parts.  The plans consist of 2 sheets of detail images and construction expansions.  The instructions are very brief but I think the plans are going to guide the build quite well.
IMG_1803.jpg.b97999f8b67a8a472dd95e5b48382c3f.jpgIMG_1184.jpg.dfe0a00634b67df6c8677c295db5c611.jpgIMG_1185.jpg.50bfa87cf093fcbeb43bc52a309d136e.jpgIMG_1186.jpg.f5642e51b81ac3d522a7e8dc88ae2fe5.jpgIMG_1190.jpg.16ededc91b523b90401b8d913093e044.jpgIMG_1191.jpg.3f4c8b780a343d031bd5a8f956f5cfa9.jpgIMG_1192.jpg.5efdad305a0ff2def4a70f7af13ef23c.jpgIMG_1189.jpg.0f26a265a8a08a381497ddfefd362fd7.jpgIMG_1188.jpg.bdd1b626b77a5bf39b948b1fef45276d.jpg
IMG_1193.jpg.775250175b6fe5ff93ab539f93f977d0.jpgIMG_1187.jpg.2ae6e181b514f38660f8bf9e9ca450da.jpg
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Should be a interesting build. Looks like it is copper plated,are these supplied? Looks cool
Hi Don and Steve.
Don, the kit as provided suggests painting the lower hull copper coloured.  I've ordered some copper foil tape so that I can try out coppering.  I'm considering copper for the Prince de Neufchatel and for the Syren so a warm up is in order.
I think this is a fun looking build and it has several positives associated with it:
-  it is easy to plank so I can get to other aspects of the build
- it is going to take up a lot less display space when complete
- it has significant but not overwhelming standing rigging
- the cross-section lets me see what goes on below decks since most POB kits don't bother.
- it will be a a great test bed for steps I have to learn - rigging the cannons, 2nd planking, copper plating, and square rigged mast configuration.
Doug
Hi Doug.
Not seen this kit before. Looks like a nice build. Got my premier seat booked.
I like cross sections as you can add such a lot of detail.
All the best.
Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Welcome and thank you Antony.  I wonder how many and what ships Aeropiccola produced and how many may be languishing in closets still?
Doug
I have do a bit of work on this project before I started this build log - so I'll catch it up with the current state with a couple of posts.
The 1st planking of the outer and inner hull is such a breeze - not a taper or a bend in any of the strakes.
IMG_1198.jpg.364a6994c00f63968858c0e15aaa38ed.jpgIMG_1200.jpg.30288b394d341a25c4f5adf353ecc5c8.jpgIMG_1214.jpg.e1d6651738156efab1a1c9dac0a15b7a.jpgIMG_1301.jpg.2437b467780fe2afb7c8c9a001ed2080.jpgIMG_1303.jpg.a39f44e02be85fc950869ad11d373e98.jpgIMG_1517.jpg.209b87553a0cbf9a3b95284fbf1748a2.jpg
It was going so easily I forgot to stop on the inner planking to leave a gap for the deck to sit on.  I only had to remove a couple of planks to fix that since the width of deck gap was an integer multiple of the  plank width.  Very considerate if the designer - thank you whoever you are!
Doug
The next step was to smooth off the ends of the planks.  Once again the shape of the section makes this a very easy process.
IMG_1672.jpg.212d405be3d27d24ff43a600b285a07d.jpgIMG_1671.jpg.1d79c7c254d0681c7e8ca6d2f1a00798.jpg
I 2nd planked the  outer hull for the experience.  I am planning to copper plate below the waterline and paint above so it wasn't necessary but I wanted this to be my testbed for various procedures I haven't done before (like getting in the shallow end rather than diving into the deep end!)
Next was to cut out the gun ports.  A bit nerve wracking but I thought I could turn the 1st one toward the wall if I botched it too badly.  It worked out ok.
IMG_1670.jpg.a00f854d42c2f803737327598de6931e.jpgIMG_1750.jpg.58b15ff22294d6329d3c4ade749ed008.jpgIMG_1755.jpg.a9c84393bf22c29334ed4cb6fca7bba1.jpgIMG_1766.jpg.cca79f27d566947cbad8c0f163f720a8.jpgIMG_1768.jpg.48d10c903d39273e12f02ebf9c51fb02.jpg
You might notice in the last photo that the 3 gun ports further from the camera have been framed in while the 3 closest have not.  They are all done now.
This is where it stands at the moment.
Doug
I like how it is shaping up. Cross section is something I've wanted to try someday, please carry on.
No worry - I will continue!
Doug
I need some advice.
I don't have a very well developed aesthetic for colour.  This cross section obviously has ends of the ribs showing. Before I can go on with installing decks and furniture I need to apply some finishes to the hull and to these ribs.
I have a plan for the outer and inner hull but I'm not so sure about the ribs.
The box shows them stained in natural wood finish.  Seemed reasonable so I tried one part with Ipswich Pine. Seemed way to light.  So I stepped it up to Golden Oak - slightly better but the basswood frame doesn't really look that good.  Pushed it up to Jacobean (dark brown) and thought it looked hideous (so I do have some sense of what I like).  Sanded that off so I didn't have to look at it.
So here's where I am at the moment. Either
- Live with the Golden Oak stain (and look at other parts of the completed model)
- Paint the ribs (black maybe?)
- Use some nice veneer cut to the profile of the ribs
Any advice?
Untouched end
End with Golden Oak on left hand arm
Doug
Starting to construct the decks and also apply some of the finishes to the hull.  I still have to decide on the treatment for the ribs (previous post).  Leaning toward simply painting them.
Doug
Looks very nice.  I am thinking that a cross section might be a relatively painless way to do a scratch build.  Only a few frames to construct!
I love these kits, they're a slightly larger scale and size than the others, and in my lowly opinion, are under-rated.  They had a kit of the Serapis that I haven't seen from any other mfr. - but searching for builds of these kits I haven't come across any that seem to be well done, with the exception of yours - you're doing a great job!  I'll be watching with much interest - I'm looking for this cross section and the Nonsuch, but so far have missed out on the few that I've come across - Carry on, Lad!  Steve M
Hello ragove and Steve.  I do think the cross section idea is pretty useful. When I 1st thought about ship modelling I didn't think very highly of them - after all they wouldn't float would they!  As I got a little more information and a tiny amount of experience I have come to a different opinion.  If I'm ever ready to tackle a scratch build (not a given) then I think a cross section would be must sensible.
Doug
Or you COULD go the other way - build a full model AND a Cross-section of the same to show some of the interior detail that can no longer be seen after hull and deck planking :
:cheers:  Danny
Cheers, Danny
Sorry Dan but I'm not in that league!  Cool idea though and very impressive!
Doug
Wow! That is a beautiful model Dan, I wish I was in that league. Doug adding veneer is a good idea, but the ends of the planks would not match properly would they. I didn't mind the looks of the black paint.
I was also concerned about how easily I would find it to cut the veneer into the horseshoe shape especially as there are a couple of projections (deck support timbers) that possibly wold look best if consistent with the rest of the end (I'm not actually sure of that).
A quick test with a piece of veneer and some black paper to simulate the paint:
Traced the rib (partially)
A couple of vies go the result with just veneer
and with the black arm
I think the grain in the veneer distracts from the overall appearance - in a sense I think the end of the cross section shouldn't blend with the hull but rather contrast with it.  If I paint the ribs I would leave the ends of the planks natural rather than painting over them.  How much of a challenge will preventing bleeding of the paint do you think??
Doug
:cheers:  Danny
Great idea, but way beyond my abilities!
If you apply the finish to the hull and the ends of the planks first you shouldn't have too many problems with bleeding. My thoughts are that unless you can show the actual pieces making up an individual frame, as in Danny's, I would go with paint.
Just my thoughts you are the Captain!!
I think I'm with Don on the grain vs. paint idea, but I think the black might be a bit too strong - think of those end frames as a picture frame, I think you want something that captures the eye and draws it toward and complements the interior colors, but not too jarring - maybe tone down the black a little, or how about a driftwood color, I think that would be very in keeping with the nautical theme, perhaps applied as a stain, but as Don said, you're the Captain!  Like your idea of using pieces of paper to check the various color effects.  Steve M
Just stumbled across this build log.  I would like to do a cross section as well some day.  I'm pulling up a chair to follow along.
Derek
If you want to build a ship, don't drum up the men to gather wood, divide the work and give orders. Instead, teach them to yearn for the vast and endless sea
Antoine de Saint Exupery
Current Builds
Bluenose - Model Shipways - 1:64 Scale
Fair American - Model Shipways - 1:48 Scale
HMS Winchelsea 1764 - Group Build
On Deck
Guns of History Naval Smoothbore Deck Gun - 1:24 Scale
Finished Builds
Mare Nostrum - Artesania Latina - 1:35 Scale
Guns of History Carronade - Model Shipways - 1:24 Scale
Good to see you Derek.
Doug
Minor progress.  2nd and 3rd decks built and the upper bulwarks added.  Almost ready to do interior finish below gun deck and then exterior hull finishes.  Although the plans are pretty good there are some contradictions between plans and the model photos on the box cover.  Having to puzzle out what I have to actually do!
Also noted I have one more pair of gunports to cut  for the upper deck
Doug
I'm enjoying following your Essex cross section build Doug...I'm starting my own Echo cross section build next month and it is good to see another making such good progress on theirs.
Cliff Ward
Cary, North Carolina
USA
Hi Cliff,
just at looked at the Echo xsection.  That looks great!  I'll watch for your log when you get your materials.   I am enjoying this build although since I'm timesharing on other build it won't go very quickly - I'm in no real hurry!
Doug
:cheers:  Danny
Danny, you shouldn't put ideas into my poor little head!  I just saw and ad for a OcCre Trinidad and cross section kits.  I purchased them.  Now they're going to sit on the shelf taunting me for the next few years 'til I'm confident enough to start in on them.  Thanks loads!!!! :piratetongueor4:
Doug
Small steps forward.  Applied some stain and poly to the lower interior hull.  Now preparing for the outer hull.  The recommended scheme is Black above and below the gun ports, white on the gun deck, and copper below the waterline.  I'll try out copper adhesive foil in preparation for copper bottoms on the Syren and Prince de Neufchatel.  This kit is a great testing ground for me.
1st coat of black
Doug
