great job really great
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Thanks Mort & Jason for comments & and all likes,
Jason : Caldercraft's Diana kit offers a lot of " improvement/adding your own interpretation" opportunities and you make such an awesome job of it !  For example : whenever I work on my model I always bear in my mind I should have remplaced the copper plates, just as you did.
Related to the beer : I understand the artisanal beermarket in the US is subject to a huge improvement the last years, but that's another subject
Hi Mort always good to hear from you : I sincerely hope your doing fine.
Wanted to post the pics before going to sleep (yesterday-evening ) So the standing rigging was realised pretty forward according to building instructions. I've tried to understand and implement this as best as I could as everything related to naval vocabulary is already a vocabulary on itself and as a non native English speaker I can assure you I went through some trouble : Ray's explanative photo's ( see his Diana log ) were a tremendous help. Except the ratlines ( Gutermann ) I used what was supplied in the kit.
While working on the tops and in a burst of masochism  :D I decided to fore 1 mm holes in the 3 main tops as I wanted to add crowsfeet. ( The real Diana never had ) but I just  like the sight of it although I have no clue - whatsover-  their purpose was
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
Crowsfeet ? I love them:P
For the interested : the euphroe-blocks are made of styrene. Walnut was not an option
I fixed 2 small sheets of 0,5 mmm and one of 0.25 mm in the middle : thas was (more or less)  the suitable thickness.
A needle and a pin to obtain the best possible alignment to fore the 0.8 mm holes
The paint is from  the Acrylico Vallejo-brand and the 311 colortype is until now the closest to wood, at least in my opinion, some more filing before assembly and that was that.
Here's the pics (part I)
Kind regards
Christian
very nice work Christian,
your standing rigging is well done !!
Nils
Current builds
-Lightship Elbe 1
Completed
Nice work Christian.
"Crowsfeet"  Never heard of it before
Again another word learned MSW ;)
groetjes
Greetings
Hi Nils, Sjors & Patrick
Thanks for the nice comments & the likes.
Patrick : Please, take a look in Sjors' Agamemnon buildlog. You'll find them. In other logs too : Vanguard, Pegasus,...
Diana never had, so this detail is a bit fictitious, I'm afraid. Also the open bulwarks, I guess.
But it's fun and those features were typical for ships from the second half of the XVIII century, so I still work within boundaries ;)
The funny thing is : I have no idea what purpose they had. Moreover, in French they are called "Pattes d'Oie", I think. So here's already another bird involved (Oie = Goose).  I wonder in Dutch...?
So if anyone has an some info regarding the use of those crowsfeet : feel free to drop a message
Kind regards
Christian
Thanks guys,
Hi Dave : thanks for the info : now I understand : it makes sense.
Hello Rob : your nice comments are much appreciated.
Kind regards
Christian
So far for the good news show.
Here's a word of caution related to the position of the seats of ease in front of the gallion.
As the pics show and as consequence of a mistake of mine the, holes are covered.
So I filled them up, sanded with a high grid.
I'll see were to install on the gallion the seats of ease later on.
Sad but not critical.
Kind regards
Christian
Christian,
Maybe you can find here more information about "seats of ease"
Lots of info and links .
Groetjes
Greetings
Thanks a lot Patrick, much appreaciated this info. Pics related to the subject from HMS Victory are super !!!What a difference between sailors and officers, isn't it ?
In the meantime, the problem has been solved. I'll post some pics next week. regardless the poor weather conditions, we're to spend an extended week-end at the Belgian coast.
Perhaps other Diana - builders ( maybe also other kits ) faced the same problem ? The two protruding masts may obstruct the original ( correct ) position of the seats of ease
At present I'm preparing the yards
Thanks for the input.
Kind regards
Christian
Indeed BE, after the boomkins  it is.
Thanks for the appreciation, and again ( to quote so many) glad you're back with with us : your buildlog is milestone
Kind regards
Christian
Hello,
Yards : preparation : The stunsail brackets
As Ray quite rightly at page 15 mentions  (HMS Diana by Ray - FINISHED - Caldercraft/Jotika - A 38 gun Heavy Frigate, 1794) they are a bit oversized, indeed.
I decided to go for the "styrene"-option.
I used 0.25 mm thickness sheets. As the end of the yards are tapered, the strip that was to be bended and fixed with superglue around them, described a small curve.
The stunsail brackets are to be overpainted anyway.
The 3rd pic shows what was supplied with the kit
I also had to fore a 1mm hole at both extremeties of each concerned yard, no big deal.
Kind regards
Christian
Hi Christian, a very nice fix on the hole for the seats of ease.  This seems to be a challenging area but sure it will look great.  The other difference/deficiency I see with the kit is that it seems to completely ignore a seat of ease in the back corner of the false rail and the ships side, simply leaving a large triangular hole which looks odd.  Are you thinking of adding those as well?  Your styrene yards are a much better solution to the really clunky white metal parts and look so much better.  Really nice work!
Cheers,
Jason
In the shipyard:
Hi Jason,
thaks for drawing my attention regarding the additional seats : I'll have to check this...stay tuned
By the way : I completely  forgot to post pics related to the seats in the gallion. This turned out rather well( a job for next W.E. )
Styrene has proven it's utility in previous occasions. I can only recommend it. Some tiny parts in cutting and shaping out of walnut ?...I don't think so.
I have 2 diifferent sheets at my disposal : 0.25 mm  and 0.5 mm.
Now a less pleasant job : to the vet with my cat. She's 16 years old and not going to well lately and a blood analysis is required.
Kind regards
Christian
Hi,
It took a little bit longer but here's my best shot related to the seats of ease.
Just behind them there's indeed an intriguing void, so I wouldn't felt that comfortable on these seats of ease....
Other pics are related to the preparations of the yards. Some bending was required. For the footsteps or whatever they were called I used 0,5 mm brass
Kind regards
Christian
Hi Christian, that looks great.  I'm still stumbling through a solution to the upper and lower cheek/head rails and would love your opinions on those when I get comfortable posting.  You really did an amazing job with the kit parts to get them looking as good as you did.  I've been tearing my hair out with placement and I was interested to see you placed the lower cheek at the top of the wale, that's were I believe it should be to get it looks proportionally correct to my eye - but it seems that on the models and AOTS the placement seems to sit slightly below the top of the wale.  I think you've given me the courage to go with that so I appreciate the photos of the completed headworks.  Really beautiful work!
Cheers,
Jason
In the shipyard:
