Thank you very much Christos, Piet and Antony,
for your kind appreciations...
Also many thanks to the "likes" for clicking on...
Christos,
I searched at Ebay for a 3D size suitable necklace-charme that could fit either in right or left mode....
Piet,
no "antique sawing" in this case, I was happy that I need`nt do any carving on it...
Antony,
thanks for your kind words, I`m glad you like it...
Basically its still after the enlarged Amati plan, but with individual fitting out and some changes...
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Love the ornate details!
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Thanks very much for your nice comment Jesse,
Nils
Current builds
-Lightship Elbe 1
Completed
welcome on board Zappto,
thanks for looking in and enjoy the ride...
Nils
Current builds
-Lightship Elbe 1
Completed
decorations are looking splendid Nils.....really looks good !
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Denis,
thanks for your kind appreciation...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils.
On 05/01/2018 at 9:46 AM, Mirabell61 said:
Antony,
Yes it is BUT you are putting so much more into your version that makes so  interesting to follow along.
Waiting on your next update.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Right, and thanks Antony,
I have a bunch of ideas still to integrate into my version. Momentarily I`m doing some trials with a set of sweeps, that will pass through the oar ports (as demo) in the stb. bulwark, but only on one side.
BTW, as you showed interest for a nice trade junk build, I have this link of a seagoing Hainan junk model of 1834 for you that I found on the web some days ago. Its built exactly from the plans I am going for, I find it looks awesome and so well built..., trust you shall like it as well...
http://www.modelships.de/seagoing-junk/seagoing-junk.htm
Nils
Current builds
-Lightship Elbe 1
Completed
Update :...
made a trial 143 mm long (upfront) 1:48 sweep from bamboo wood, in order to determine size and length as well as position in the bulwark, where all the oar ports meanwhile had been cut into...
there are 9 sweep ports on each side...
the pivot point is the bulwark itself, whereby the inside rail supports for hight and angle, when the blade is submerged
hight of the tin figure is 35 mm
its all from one piece of bamboo rod
the thin black serving line coil protects the pivot bearing point in the bulwark...
Current builds
-Lightship Elbe 1
Completed
Hi Nils.
I have to ask a question... Can one man use a oar that size ??. Two people  ?
The oar hole in the bulwark should be big enough to get the blade through.
Thanks for the Junk link.
Very nice pictures and information. Love this style of boat. Has a lot of character.
Have you ordered any plans yet ?? from this site ? http://www.modelbouwtekeningen.nl/nvm-1000032-hainan-handelsjonk.html  Are they trustworthy ??
Never used this site before.  £66.14 (75 EUR)  is quite expensive for a set of plans.
Regards Antony.
Completed Mayflower
Hi Antony,
The oarholes in the bulwark are large enough to slip the blade through, but unfortunately I ca`nt tell if perhaps two men were necessary to operate the sweep...
the sweep is a bit counter balanced by the solid square section part. Would appreciate if anyone of the fellow builders would be able to answer that more precisely...
For building the junk I have`nt ordered from that source yet. I presume that they are trustworthy, have`nt found anything negative about that site to date. Yes, the price is quite an investion to face, but I hope its worth it, as I found no such alternative yet....
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils.
I will let you know what the plans look like and the quality when they arrive.
Such a nice boat its a shame not to build it.
Regards Antony.
Completed Mayflower
23 minutes ago, MESSIS said:
Its beautyfull.
Christos
Nils
Current builds
-Lightship Elbe 1
Completed
24 minutes ago, AntonyUK said:
Hi Nils.
Regards Antony.
Hi Antony,
Thanks very much, I`m also very curious already, and will be looking forward to your comments on the plan set in due time....
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils.
Regarding the amount of oars men.
"By the early 16th century states and navies grew and required more men. They used more and more unskilled slaves and prisoners. The Venetians designed a new system "alla senzile”: 3 to 5 men per bench, handling one large oar. Only the lead rower needed to be skilled, the others just followed his move. This allowed larger ships, but the side men were much less effective. Maximum speed dropped from some 6 to 4 Knot (more or less: a much discussed topic), as compared with 9-10 Knots maximum for ancient triremes (cf. Olympia's trials). The "senzile" system was soon adopted by all Mediterranean nations, and older galleys were reequipped that way."
This is from http://www.cogandgalley.com/2009/02/16th-to-18th-century-chebec.html
this is the only article I know off.
Regards Antony.
Completed Mayflower
Thank you for that special input Antony, much appreciated,
very interesting read, and the red sail equiped Chebec (out of the first enclosed link) I know already from the web it is showing many insperational details in the pic gallery
Nils
Current builds
-Lightship Elbe 1
Completed
Nice bit of info about model drawings in this exchange, thanks Anthony. Prices are out of my league though. I would like to build a Dutch fishing vessel, "botter", but may have to draw up my own plans. I have the lines.
Your oar looks really good Nils, quite a heavy one for a one man job. ;)
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Many thanks Piet,
in case you may be interested, and not looking only for a kit,...... I saw they also have a plan of one or two Zuiderzee-botters on that Dutch site, perhaps you know it already...
http://www.modelbouwtekeningen.nl/nvm-1003003a-zuiderzee-botter.html
For the Chebec sweeps I believe they were  relatively heavy indeed, as they needed to withstand best possible propulsion, when the crew navigated the ship swiftly into resp. out of battle range in calm seas, and the larger squarerigger vessels usualy had much more fire power
Nils
Current builds
-Lightship Elbe 1
Completed
Update
have been producing sweeps, from bamboo rods, need 9 ea. per side
Nils
bunch of 5mm diam. bamboo rods (sticks for supporting flowers), out of the gardening dept. of the local crafter
raw shaping.....
six done, 3 in progress, Then come the other 9 that go to the sweep racks on the outer side of the higher quarter deck
Current builds
-Lightship Elbe 1
Completed
Nils, your build is progressing wonderfully and I really like your work and all the clever details and decorations. During the building I have noticed that there are many gratings throughout the ship. But how do you make those gratings, because every time I have tried to make them I didn't quite have success with them.
Moxis,
Thanks for your words....
I am sourcing the kits for the gratings from the RB Model webshop. They come in different sizes and mesh distances (this gives some variation for better scale trueness)
After the parts  are carefuly and crosswise  sticked together to a "grating plate", I dip and submerge the assembly in diluted white wood glue and let cure over night. Next day carefuly sand with a fine grit sandpaper in direction 90° to the longitudinal vanes. (caution, if you do the direction wrong, you may break out some of  the tiny mesh conections). From the "plate" I cut out the individual sizes I need, carefuly with a jigsaw and fair the edges flush from the remaining mesh fringes. It worked well so far.
Nils
Current builds
-Lightship Elbe 1
Completed
She is looking very good Nils. The final few photo's show her off a treat.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you very much Keith,
am pleased you like it.....
Nils
Current builds
-Lightship Elbe 1
Completed
Update :
fitting the decore rings around the gunports. The port side remains closed to the sea with decore shield plugs.
All oarports will have hinged, small doorlets, the port ones closed and the stb. ones open, because of the sweeps in place....
The wales have been painted dull black, the mermaid decore in golden color....
Nils
the center of these butons will be cut away with a jig saw....., and remaining deburs faired carefully with a diamond file..
the rings and the lion decore are made from buttons for clothes
For the gold paint I`m using a Swedish product, Panduro, its a waterbased acryllic gloss coat, which gives far better results than the former used Humbrol gold enamel
the plug shields have a shoulder, whick lays against the inner bulwark planking. The spacing here had to be quite exact, in order to get everything in its place
Current builds
-Lightship Elbe 1
Completed
Happy New Year Nils!
I haven’t had much of a chance to drop by lately...in fact today was my first chance to visit MSW for quite a while.
Boy, oh boy, oh boy...what an absolutely superb job you’re doing; but, that’s not surprising.  Top job!
Cheers.
Patrick
Hi Patrick,
a very nice new year I`m wishing youand your family too, thanks for looking in and for your nice words....
Nils
Current builds
-Lightship Elbe 1
Completed
Update :
sunday morning my wife and I went over a flea-market in Hamburg, not looking for anything special.......
The little ball shaped (openable) only 15 mm diam. brass casing with the filigrane moorish decore came to my eye, and I thought that would be a nice aft lantern for the chebec, so I soldered a shaft on to it for mounting...., it only requires an oil-lamp inside
The horizontal wooden spill with clink found on Ebay will be mounted to take on the anchor cables, it is basicly from Aeronaut Art. 5804 /05 but bashed /modified to suit my needs as shown....
Nils
Current builds
-Lightship Elbe 1
Completed
Update :
made the balustrade with bell-arch for the quarter deck and dry-fitted the stairs...., The spill on the forward gun deck will fit under the ships boat mounting...
Nils
Current builds
-Lightship Elbe 1
Completed
