Found a picture of some small Dutch galleon...visual addition ,could be considered as artist vew  to the question of rigging proportion...
:))) and... how many people could exists on 1 m 2 !!!  Unbeliveable!
What is the matter of high cooperation, coexistance , and so on ...!:)))
Good example for us , modern ... :)))
Edited by kirill4
Foot ropes.
There was a question about the foot ropes. They were not depicted from before the year 1600. At the end of the 16th century, many inventions were made in the field of shipbuilding. One of those things was the use of foot ropes. Before that time they were usually not there because the two  main yards of the lower sails were lowered on the deck. There the sails were stowed and then the yards were hoisted again. The sails could then be lowered from above. In the Netherlands, the railing had long time  the name "rahout" (ra = yard, hout = wood). Which also indicates that the yards were lowered on it. Barentz's ship from around 1595 did not have those footropes either, which was clearly visible in prints from that time.
Constant
After a really long break, I made progress again. Fore and main mast heads created. Just grooves for ropes and fittings... 🔥
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
 Finished the details of the mast heads (cap).. 💥
Dewetting for processing bonded parts..
Ready for the next floor with flagpoles...
Ondras.
I finished the mast fight..
Towards the end there are already very fragile parts..rmy...thumb.JPG.d846a2d45126b4a6133809335460d1e6.JPG
Repair. It's worth creating a few extra parts..😪
Mast parts done..💥
Result..
Continuation - Tops..:rolleyes:
Ondras.
Thanks for the like..:imNotWorthy:
I was still missing structural elements on the tops supports. So late, but added..
Plate tops..🔥
Ondras.
On 8/3/2024 at 4:09 AM, Hubac's Historian said:
Awesome!
Thank you very muchHubac. Thanks for the like.:imNotWorthy:
Moving on to the tops. Creating an accurate 0.75mm thick wooden hoop took some trying. Finally, I looked at the production system on the dividing device under the mill. The dividing device was a bit wobbly, I found a system on the net to adjust the length of the collets and center them.
Base plate leveled on a lathe..
Milling works great by rotating the hands..
Board nails..
The board is glued to the hoop and carefully cut off..
Milled to the correct strength..
Now the top hoop. She is very fragile..😪
Ondras.
The second plate weakened under the cutter. After 0.1 mm, it removes sensitively..
Continuation of making hoops. My first attempt from the board broke years later. Second attempt according to reality from glued parts..
I had the cutters narrowed to 3 mm to shape the posts..
Now I will gradually create the shape of the posts, then they will be cut..
Ondras.
Hallo Ondras. Your work is fantastic, I follow it very closely. I am trying to build the same ship using 3D software. I just want to say thank you for this priceless collection of pictures that shows your work step by step. It is invaluable to someone like me. I am just a hobbyist, you are the professional, so I just want to thank you. I upload a picture of my effort so far. It is just a work in progress, not the final colors or textures yet. As ever, looking forward to more uploads from you. Regards, George
Hello George. Interesting and clean painting. I also try to look for details and shapes on the internet, so I agree with your effort. I am curious about the resulting drawing. Ondras
Ondras.
Thus, the production of column tops had two episodes.
The first, of course, is an exam. The direction of the flight of wood betrayed me. The second attempt was successful..:Whew:
The top of the main mast dries, After waxing, nails and other details are added. The second top will be a piece of cake..🔥
Measurement by a sailor..
Ondras.
Tops received mounting elements..🔥
Like the pattern of Barents boat tops..
TopWitteSwaenreplica(2).png.edb47371d97a69251613b62ec3af2b84.pngTopWitteSwaenreplica(1).png.6d30c9bf7181f161b77d9199c7c93026.png
Here is a beautiful series about construction
Finished tops..
koenalodi(1).thumb.JPG.5d7776d62065275986b43e879cf6728a.JPGkoenalodi(2).thumb.JPG.415d51f8963526b9ac495dda43ef607a.JPGkoenalodi(3).thumb.JPG.f5835db2d74bba2b4139459cca2478c9.JPGkoenalodi(4).thumb.JPG.f3d6fb01b0ebed1b9a75e591e9c0cb11.JPG
So it's rope and block time..🔥
Ondras.
This is a stunning work of art! I also admire your building special tools, clever sanding shapes, etc. You give us all a lot of good ideas. Thanks for sharing this Ondras.
Mikki
"You're gonna need a bigger boat."
Working on: Dusek's San Martin
Completed: Good ol' first ship build- Constructo's Albatross; Mamoli's HMS Bounty; Mamoli's Golden Hinde; Amati's Drakkar; Occre's Revenge; Artesania Latina's San Fran
Thank you very much MikkiC, thanks for the like..:imNotWorthy:
I keep going slowly, I'm turning the yards..🔥
I came across a new Proxxon, a 4-jaw chuck.. Great Christmas gift. The placement of the prisms is more accurate..😍
The first yards have been dialed in. Additional items will be placed..
I wish all modelers a lot of peace and, most importantly, diligence and a passion for building in the next construction year 2025.
Ondras.
I finally fought the yards..🔥
Yards ready..
I bought fabric for sails, 80 g cotton batiste. I'm starting to learn to sew..:default_wallbash:
Ondras.
I started making blocks. First large sizes, there are only a few of them, and then non-traditional shapes. "lift block", "sheet block" and "fiddle block"...
The base on the milling machine, then hand-made..🔥
I plan to produce small-sized pulleys "by machine" on a milling machine using shaped milling cutters..😴
Ondras.
On 3/18/2025 at 12:42 PM, Chuck said:
Really nice and precise craftsmanship.  Those blocks are fantastic.
Thank you very much Chuck, thank you for the like.🙂
More small blocks made..
Before I have the milling cutters ready for the production of small pulleys, I started making all the ropes. There are a lot of them, 10 basic diameters in total. All Dutch ropes are right-handed, which means that it is difficult to make weak 3x1 ropes. Right-handed threads are first twisted into left-handed threads and then the ropes are knitted. Guttermann threads are quite good, but the weaker cotton waxed Sajou threads like to hold their shape and I don't want to twist them in the opposite direction. After a long time of trying, I figured out the ropewalk settings and especially the last adjustment. All the finished ropes are slightly hairy, I stretch them under the flame of a lighter...🔥
The 3x1 Sajou cable with a thickness of 0.35 mm also has to be pulled over the edge repeatedly to align the threads. But it works..:default_wallbash:
Edited by Ondras71
Ondras.
I finally started using a tool I've had at home for a long time - a beautifully crafted Rope wrapping machine..💥
https://www.rcmodel.com.pl/rope-wrapping-machin/
It works perfectly, tightens the threads beautifully when adjusting the spool resistance. 👍 And it doesn't matter at all that there is no motor.
Edited by Ondras71
Ondras.
I am familiar with the Rope wrapping machine. I must confirm that the author Roman from Poland has mastered it with great craftsmanship. Super gears with gentle resistance prevent untangling. Polished material brass and aluminum. Interchangeable parts for many different activities. Very pleasant work...:imNotWorthy:
I wrap weaker ropes directly, strong ropes filled with thread..lanosvpln.thumb.JPG.f090e349eacee84ede297b844f444d11.JPG
Fixed rigging ropes braided..👌
Other work halter shrouds, eyes and Stay Mouse basics..
Dirt from superglue patinas well with brown bitumen..
Now I'm going to braid Stays Mouse. I found this work 1:1 on Duyfken replica..
Ondras.
I studied the Stays Mouse braiding system. I created a jig from scraps. I used two systems I found..🔥
The ends are tied on a rope wrapping machine. I gradually weaken the wrapping thread until it is gone..💥
Stays mouse on Main stay done..💥
Ondras.
