While on an obligatory trip to Home depot to pick up some caulking for the home reno, I took the opportunity to do a little grazing in the tool section, and came upon a small pencil engraver. this tool had a diamond burr for doing the engraving. Advertised as a standard 3/32 shank regular burr, with pictures for putting names on anything and everything. it was the 3/32 shank that piqued my interest, because I have a whole bunch of 3/32 shank miniature twist drills. It was also touted as 20,000 rpm, so fast.
It was $39 so I purchased one as compensation for having to go back to get the second tube of caulking which i should have purchased the first time there.
the yellow button is a momentary on switch.
I drilled a few holes easily with a .022" drill  it was true and smooth in its operation, and uses 2 AAA batteries.
So it will be very useful for small hand held applications.
Michael
Micheal,
I purchased one at Lowes in Mobile, $ 19.98 US it was awhile ago but would that be that much a price differential between Can & US.
It is a great little addition.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Fraid so John.
Michael
Edited by michael mott
Wow had no idea, you have my sympathy:(
John Allen
On deck
Finished
Here is a link to the Generals website, click buy now and your screen will be populated by various retailer, stock situation and price.
Respectfully
Great find.  I checked Amazon and they have it for $14.95 with free shipping for Prime members.  Also there are a couple of similar engraving pens with higher ratings and a bit lower price.
My advice and comments are always worth what you paid for them.
PROXXON has been doing something of similar size over here in Europe for many years, but it is a 12V cable-version:
Proxxon Graviergerät GG 12 Netzbetrieb
There was a problem with the take-up of the end-thrust by the motor-bearing alone, but I sorted this with a small metal disc at the free end of the electric motor.
The General version has been on Micro Mark for a while.  There is a Jacobs chuck that fits it, so
wire gauge bits can be used with it.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Quote
Ah yes us folk who live on the outskirts of the civilized world eventually hear about these things, or stumble across them accidentally as I did. ;)
Michael
I saw an ad in the Canadian Tire Christmas flier today they have them on sale for $12:49 so tomorrow I am going to pick up a couple more.
Michael
This pen drill is nice, but still too long for confined spaces (like inside the hull).
Is there anything better than this ugly hack I was forced to make using the cheapest parts available?
I am pretty sure that there are smaller motors available, and batteries could be wrapped around it, keeping the body short.
I have been thinking of adapting a dentist's angled drilling head ('hand-piece') for such purposes, but the problem is that it only takes short inserts with a fixed diameter. So one would need to construct a collet/chuck as well.
The problem with smaller motors is that they have higher RPMs in order to deliver power. Otherwise you don't get enough torque. This in turn needs a well-balanced chuck in order avoid vibrations. In your case I would replace the Philipps-screw with a headless screw (which is what these little collet-chucks come with anyway, as far as I know)
Mike an interesting point. I remember that Gerald Wingrove built himself a small micro drill years ago using a model train DC motor and if my memory serves me correctly it was pretty short as well. At the low cost of these on sale, as an experiment I might just chop it up and use a short flex power connection between the head and the battery part of the body.  It might be more trouble than it's worth, but on the other hand it might just be the ticket.
Michael
Small DC motors with chucks =
AliExpress   a commune of sorts in China
Marlin P Jones   motors, wires , and a DC 2A power supply that is 3/4.5/6/7.5/9/12 V  with banana plug and gator clamp wires - no need for batteries
and speed control from power supply  @ $17  it would not take many batteries for it to be cost effective
Edited by Jaager
NRG member 50 years
Current:
NMS
Other
One thing I noticed with the second one, is it has a small vibration in the shaft. so it will be used for polishing brass with the small wire wheels and mops.
Michael
Guessing that you are asking about AliExpress
Under  Home Improvement
is tool
try 12V DC motors
and drill chucks
also have water stones
They have low cost flex shafts with 1/4" sockets and chucks that mount there.
I needed for 1" / 2" / 3" bowl sander tools (hook & loop media mount)  ( PeachTree)- but I
bit the bullet and bought a Kirjes flex shaft from Lee Valley  to finish inside frame bevels
instead of the low cost Chinese  tools.
The cost is generally very low at Ali  - and mostly they are reliable - shipping is surface post and
not too long.   There were a couple of mistakes- and instead of a refund - I got some sort of something
for a cell phone - a device that I am mostly a Luddite about.
NRG member 50 years
Current:
NMS
Other
As long as you make sure there isn't a burr on the cut end it should work perfectly.
I had the opposite problem with another brand of micro chuck - the shaft was too short to go into my dental drill hand piece so I ah do de-solder the one that came in the chuck and replace it with one a bit longer - no problem as it is a std size.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
