Thanks Dave.  You are too kind.
Cheers
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
After a long period of attention to my group build, I’ve returned to the Independence.  Since the last post I’ve tenuously added, without glueing, the lower fore shrouds. But my main focus has been on the fore lower sail which is a gaff sail.  I want the sail to be brailed and look proper. When I attended the meeting of the Northeast Clubs at New London, Connecticut, I acquired a collection of designs of ships published in 1882 in Paris.  One of the plates shows a ship very much like the Independence with brailed sails. I want my model to look like that ship. But I couldn’t get either cloth or silkspan to behave. I came up with the idea to make the sail in two parts.  The first part is what is furled up to the gaff; and the second part is what is furled to the mast. Some photos:
DOHvmbpEsaPRm0t8YLN3kKet_YPKbIbRSL6-7ksdVeFv_7fNH5y5VubZ85ZwEkExwPMxmuMs_3bVEkQgkEyEPrq20aPmbhmCSJrACfBuQbhQWh1nVbixgiJRNwrUdfAoksW18vuk             LZk9u5bYTPlz8uo6Rs5D6Be1BfFyxK0AuTXiUo2PKTcmjy-Ge8F3xoPppskZV3hLlIkpTgLgvLiCMmrkc6c81V39rm29FAyfj34m7WVnrzdFmoM9YNft8BFzq2MElqC7V_Qipk1V
The piece that is furled to the mast I done first.  Then the diagonal part is furled to the gaff, with some effort to merge to two pieces together.  (Not a good explanation, but it’s the best I can do.)
579TAXTFyAQ9GDiVKDHNHH8GsoT6fH7bTVt_YixKZTD-BKSrTVV-VFOVX0Ih44ydhFj59uDngNytyFNM8TrEbdeU2AMok59yuxJQ6ew_3a06OSsBX_1epCp8La2BS8hj3mR5rWu7            ZFML8uroekJcp4bx7Np5hzymt2gzq20oAqtgZkAozQJefb_9BTu8f5ifxjlCQqneVXIu_0GQf_Ew6gvPGKsgQkpo0M1M9MpOZQC6U4UnD2DqDFzxOD8L2_7V6U94_qCn9UZBXpmv
The last photo shows the sail brailed exactly as shown in the 1882 plate.  (I’m not able to get a decent copy of the plate to include here.)
Ken
Completed Builds:
Ken,
Lovely work...  and success on the sails.    Somewhere, someone else that problem with brailing.   As I recall so others mentioned that the lower end of the sail is full width but the top is only about 50% of the width.  The other idea I heard was to dampen the sail but not sure I'd want to try that on the mast.
Thanks Mark for the ideas.  I still have the main spanker to do.
Also thanks to Dave for the encouragement.
Cheers.
Ken
Completed Builds:
After some family visits, I ‘finished up’ the model for a presentation at the May club meeting.
None of the rigging has been tied off and the shrouds have been ratted up.
5YGcO0x3IL52BAbMsFWygN_j7G3Mb6uBWsZmiDwRxq-aszQNfSKnWFuTK6Xvhsll8X5ZK9lDeWPGBpW3AYJoC8CEL0vI5gJdJYCAE6Vb-yxvKhfwc_5Fii7h_xpqVwhpYwLuEGyI
Ken
Completed Builds:
Great  work! Just to finish this kit it seems an accomplishment. Glad you got thru that planking. Looking forward to seeing your sails and completion I am going with silk span also. There is 3 weights at sig wich did you use?
I do have one  question for anyone that has completed this  one .Did you plank the inside of the bulwarks before installing them.
Getting ready to really get started on my independence. It will be my 1st ship model ever .Not counting the small water line ww2 ships I did in my younger years
Thanks for the comments Dave, and yacht1255.
Thanks also to MtZigg.  In answer to your questions:  As I remember the sequence of events, I first planked the deck and then the first layer of the hull.  Next, I planked the inner bulwarks, followed by the final layer of hull planking.
I've been using silk span from this site:  https://brodak.com/silkspan-lite-white-only-2-sheets.html
I use the thinest silk span, which Brodak calls "Lite Silkspan BH-916".  As described in my entry I laminate three sheets together using white glue diluted with water at a ration of 1 part glue to 7-10 parts water.  When it comes to furling the sail, I wet the sail with water and form the furl.  Once the sail dries, it's stiff but looks good.  You can always re-wet and re-form the furl it you think it's necessary.
Hope this answers your questions; and, good luck with your model.
Ken
Completed Builds:
Next up is to step the main mast and its rigging.  The shrouds, vangs and halyards are the same as on the fore mast; while the boom topping lift is different.  I also changed the way the brails are tied off. The new method frees up space and is similar to most of my research.  I also added the jib boom in preparation for rigging the fore stays and sails, as well as the fore topsail.
Edit to enlarge the photos.
Edited by KenW
Ken
Completed Builds:
Thanks much Ken. I've just added stern and bow blocks to mine.
Your masts and rigging looking great. Hope I get there soon before I forget reading all this good stuff and looking at all the great pics
Thanks MtZigg.  Hope your model comes out great.
Cheers.
Ken
Completed Builds:
I added the standing rigging in the bow section; specifically the forestay and jib stay.  I’m exploring ways to rig all the lines and not use too many timberheads or space on the bitts.  I always worry about not having enough room to tie off all the lines. I did use two timberheads, but I think everything is going well and I’ll find the space somewhere.
Ken
Completed Builds:
Since the last entry I’ve added the furled fore staysail and the jib.  Both were made from silkspan as described earlier and the furling was based on previous research.  I think the ‘look’ is good. The mainstay was added but not finished or tied off. Also, I decided to use footlopes or ‘horses’ rather than the netting that came with the original kit.  Somehow the net didn’t look right to me. I made netting, so if I’m challenged, I can always change my mind. I’m constantly changing the rigging plans from the kit to be more in line with my limited experience and research.  As a result, the boat looks less and less like the kit’s instructions and photos. I hope I haven’t created a boat that is completely different from what existed at the time.
Next up is the fore topmast yard and sail.  I feel I'm getting closer to the end.
Ken
Completed Builds:
The fore topmast yard and sail were installed without too much trouble.  The shrouds were also added as well as the fore topmast stay and back stay.
0__IRQQhvgSHkzFjz8zoxUEWAdT5mBMnsAavft9VFcoh2I0vxo33H-9d35Ed8FcYQlEytpC901BWngp8SncoA5dlfjNn66HAjxXGsfyN7Et-nB2XSLJBM6Hji_4gomX2nRvJ46Bx
3lbx9DwNPp1VFn_Q1SAmeSPij0mtwkN6m2AdgPB8UgmEdL-HM98ExKBjLQiyumZPLIW10_aiDT3Qpj_dd6dhgXv6z8IQPYaWsROEpyY3a2XTRxiZR-VsjUPoUWtTaXISVd3KlScA
vhVhhmEYtHiqaMtuYbUaC9ehKDtu0DknzgKG4ro--CtakjOMy5qK-JrXHIVf8p2lX-aflHOshmlgXCJYQf0iAz-zCOf2GLZqt2QlyN-Ylf4xkI94TD5NOMt6EYtZ74IxnchC0rQs
One thing I noticed is that the way I’m tying off the rigging is very similar to the rigging plan that came with the kit.  The differences are that I’ve given all the stays and fore topmast yard lifts the ability to be adjusted. I believe this was done on all ships.  One thing the rigging plan, and my rigging, have in common is that the fore bit is becoming very crowded.
ecK0Rp6cWs9eqdjqIZ8CXWnZ6-EHLBoteMJJF17_ezq5hx00jv770U6A0R3W3Ng7J3OPX8PYFiD-gjZOPTggRtJtL5K-yOxMLeonY95MRZ8m3sofAHJDN8QvcY9JdIYe4pIaBAzW
I’m going to have a major task when I glue and trim all those lines and then add rope coils to that bit.  The deck looks very messy now, but I hope to change that soon.
Ken
Completed Builds:
I’ve been working on the two remaining sails: the gaff topsail and the main topmast staysail.  I made both sails and started by attaching the staysail to the main topmast stay and then attempting to furl it.  I couldn’t get a furled sail that looked reasonable. However, I read in Darcy Lever’s , “The Young Sea Officer’s Sheet Anchor”, that the staysail was either brought down to the foremast and made into a bundle that was stored on the top.  Or, it is taken down and stored below. My boat doesn’t have a top and my bundle looked horrible so I decided to store the sail below deck. I left the halyard hooked to the stay block and considered the problem solved. I wanted the gaff topsail, however, to be furled and seen.  The furled bundle is nowhere as bad as the staysail, but … I do know that I need to replace the gaskets; and I may consider adding a silkspan covering, if I can, to make the bundle look more appealing. Any suggestions would be welcome.
Qu7c725NiEPFxw7VXSe12dGZvmWzIboA9gq5r4EFN6iYj-3nuPctr-eLRDKST7jN8Vp3zA_AAkpe85ET8KaAgyGPaa8o3II8aPZQreBYIfzBw0SNUeOfpiglhP_FS8Lr4HyD_nyU
fek8M0VUF6fkaQhnQXAyRERRfUQvyqDjXM57hwqGVaObTIPO0IFIyNh38OIbWxs7H0oa4F0Isq6PH2FR0-dxaqQTr5gDb_ClNukhTwh6uf5pmF_MPYF6sP6L_xyjoaOB3IhUU5ki
Edited by KenW
Ken
Completed Builds:
Big Thanks to JerseyCity Frankie for this photo of a furled gaff topsail.  I guess my efforts aren't too far off base.  I still think I can make my furl neater.
Thanks again Frankie.
Edited by KenW
Forget to add the photo
Ken
Completed Builds:
lovely work Ken,
I like your ship, nice clean modeling !!
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Nils; and for all the likes.
Ken
Completed Builds:
I’ve finished the rigging of the model.  I’m not totally pleased with the way it came out because the shrouds and back stays are so loose.  I only hope that when the weather turns dryer the lines tighten up a bit. Included are many rope coils to give that finished look.  The fore and main bits are especially crowded. The remaining posts for the swivel guns were also glued in place.
2019_08_26_02.jpg.36cb3f2d0aa9fade46618ca35e577c41.jpg  2019_08_26_05.jpg.eafdb61de5729d1e6747d40be5981f26.jpg
That means all that is left to do is install the rudder pendants, anchor, swivel guns and ensign.  So the end is in sight.
Some more photos -
Ken
Completed Builds:
Sweet work, Ken.  Beautiful ship.
Beautiful indeed! I understand fully the frustration of rigging lines that won't hold tight. I'm getting into that battle more and more on S.R.. Hopefully, like you said they will tighten back up when the humidity decreases. Even if they don't, she still looks very nice.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Thanks Bob, Mark and E.J. for your kind comments.  I enjoyed working on the ship, and it's not done yet.
Cheers.
Ken
Completed Builds:
It’s taken me awhile, but I’ve added the rudder pendents and six aft swivels.  I’ve spent more than a week carving out the anchors (I can’t use the kit provided die cast anchors since they are too big).  So I just need to install the anchors and the two remaining swivels; and then I need to make the ensign. I also made a pawl for the windlass.  Almost there.
MDeVZTuUaJbMC8BbrgM151Y4OrEGlgus58odEoutuoHI_mFzk4PUNWTjNrV3soU_wQFPLvZ3dz_qI8OKIcX32y3u5cvRe2ryB7N65HY7P84bHAEHZBfQcp4TfNNdMOfVKWGSXn2H
ikWSm42_rgCa_FFTru5Oln6O9GVYUYDAdIiUP6iEwFxABkhRSXnNWNRs6aLv1uXRfxjS8ZeZFznXE7kDRe9JcjjNw-KtLrmAQPKDCONfViVckJCDwhKstJVXIR9K-oCSlIc-ejNH
3CSQNZo6VXX9jgrtDwIXitYwm36YfKn_tvhVW9zYoNKuuBRG7I4HeNgP4kc1PkUM0EGB2fkGByoD5e8Ory8-L2LIr3qEsIgKGuQTKRMR9GctqcYas4QN3thqrTZQpox9F5a6taN7
Edited by KenW
Ken
Completed Builds:
The anchors were installed, including the buoys.  Plus I chose the Ensign of the New England Navy. It was in use from 1775 through 1777.  I’m flying it from the gaff.  To make it I followed Chuck Passaro’s method from his log of his kit of the Queen Anne Barge which can be found at ‘https://modelshipworld.com/index.php?/topic/12476-syren-ship-model-company-news-and-forthcoming-new-projects-products/&page=34’.  His method worked and I’m really pleased with the flag.
uc26mIL5wL3T0voyhtuXnKwB4bBy8fXTEK_rm0Fk20GADNgh4I3Cr1_3bx-aLGb95UxpXvZA6C4mJFgl1HCuBA0XO-rrEmX4nUKwEhzDdWlZ0Fp3LoJtbVr-ruA_poLMtdiLsj6Z
As a result, the model is finished.  I attach some final photos.
A0qROZZ3gTbtKYYVvW8wSfOiRrg_LsY_zZ_Ghk7LnnfIZT2U9b-dO6PnW0g7QCbf3wT5ulC18XBxPmiRk7A86Fq19etkEKpjer4y-YvaFyLZkRo07vKlZJ6itmRGmJ41QhmEvxie
WQ50kHCJTxggSSdNO6ZB8G4WqAf61fJxsHtZsmrDEwLFqFTGq-n08usxqAchajuGvfvA8eEfuhOXdxieqz6LEf93Ck3G5jv00u-iwFqKm6dICWTj51lWljqHHEgh91VpzN0y9V_e
3WEuI5hrQz2QqWT88v-eGxsduQfrwgdx-Vx3TeYzpuCryyE-h_4nPR3ONCogJz7yPqPoJBZNrm4zb95hVC86muSjuOKUnkE8qM1HryjTYBPOyP4Lfo1y5xidra3LSOeXJckPqsBQ
_c1yzkZRSp39frGGz6c5D7bw7Dn1hJGtW5Mduaw6beNU0oMwojJU6OAaFKvMHUrcq7gK8wJslyB-eKivKO702TCwyo5FGet7jbdRYkCiMCGrPh2xAym5Oe7rxzj4D53-_uzvzcKn
Ken
Completed Builds:
Congratulations on very well done model.
