Back in the shipyard after time in the mountains for Christmas and New Years.
I was going to put one decorative stripe just above the wale, so I spiled a thin strip, hand thickness-sanded to 3" (1/16") stained with India Ink and installed just above the wale.
It's much cleaner this way than me trying to pain a perfect line.  On to the garboard planks.
Maury
Edited by Maurys
Garboard plank (Port side).  The plank is interrupted by the centerboard well on the port side so there are only two pieces. A thin batten was laid and each frame carefully marked.  Then the distance from the rabbet to the mark on each frame was laid out on the bass wood and a ships curve used to determine a smooth line. I like working with sacrificial wood (Bass, 1/32") rather than card to make templates.  It can be sanded for a better fit and it actually twists like the final plank.  First pic. is the aft portion laid out on the bass.
Second is the template cut out.
and the third pic. is a shot of both fore and aft templates.
The "wavy pattern" of a garboard plank can be seen clearly.  Using these templates, I'll cut the final pear planks.  Sorry about the quality of the photos.
Maury
1/32" Bass is about the thickness of card, can be sanded for small adjustments and twists like wood...and for what else will I ever use all that stuff I bought 15+ years ago.😀
M
Garboard planks installed both sides.
CC_Garb2.jpg.5e9a193d9c2a1f5196c0eab29668cc57.jpgCC_Garb4.jpg.b8388748f3df2e50ccd15a4dd3d31e76.jpg
Now I have to lay out the bands for the planking.
Nice clean work, Maury. However, to my eye, in the first photo the garboard twist is a bit 'off' over the 3rd to 6th frame, counting from aft. More fairing needed there, perhaps? Feel free to ignore my unwanted comment!
Druxey, Comments Always appreciated.
It does look odd.
I laid out the lower band.  I like David Antscherl's method using a thread with a little white glue.  The bands are of uneven strakes because of where they land in relation to the frame at the stern.
A few minor tweaks to get them smooth.
Maury
Re. the twist, I hoped clamping and the heat gun would fix it.  So far so good.
Old on top, revised below.
CC_Garb1.jpg.ef8d5e0dc338ba009bac65f21aa53145.jpgCC_Garb6.jpg.8b197ccf2a1fc77d0a63edd6f3c643a5.jpg
Maury
I test-fitted a strake above the garboard and it seems way too thin at the bow.  It's actually a hair less than 1/2 the width of the strake at DF.  That means two or three drop strakes.  Question arises...which pattern?  2:1 or 3:2.  Is there a standard?  Either way would reduce the number of strakes by two or three (from 16 to 14 or 13) at the bow and bring the width up to > 1/2 of the width @ DF.
Comments?
Maury
Back to the drawing board on the planking plan.  I've cut the number of strakes between wale and garboard at DF to 14 from 16.  That makes the width at 9.1" at the DF frame.  The butt pattern stays the same...just eliminated strakes 1 and 16.  Three drop strakes (pattern 3:2) near the bow (@ Frame "I" where the foremost butts occur) yields a plank width of 6" at the bow.  All those tick strips I made will be redone and the lines on the frames erased.  I still have to see what I can do about fair line of the wale on the port side forward.  It  just doesn't look right.
Maury
First plank above garboard on port side.  Straight forward, spile, sand to adjust, fit, glue, clamp.
Maury
Planking continues.  Each piece is spiled.  I find using the 1/32 bass is so much easier than card for making patterns.  Below is the pattern (laying flat) for the lower edge of the fore part of plank 10 (second up from the garboard).
The pattern is transferred to 1/16" pear. Once that edge is correct, then the width is marked at each frame location.  A ships curve is used to form the line.  After it is cut, it's (heat) twisted, bent and glued.
Maury
Planking continues (slowly).  Three strakes above the garboard are done.  Notice the garboard needs some scraping to better line up with the adjacent plank.
I started on the first drop plank.  Carefully...
It still has to be bent to form.
Maury
Planking continues.
Maury
Edited by Maurys
added pic
Planking continues...
I'm getting close to finishing the first band of planking.  Once done, I'll decide which side I'll leave partially exposed.
Maury
The lower planking band is done.  Views from outside and inside.
A lot of sanding to be done.
Maury
I do not like the way the lower planks are turning out at the bow.  I think it's a matter of the garboard not ending correctly.
It looks fine when upside down and straight on, but from the side, I do not like the "bump" (more obvious on the second photo).  It's not going to get better, so I think the lower planking needs to be replaced.  I think if the garboard is re-done per the pencil line, it will be OK.  A lot of work to be undone, but I am just not happy with the lay of the planks.
Maury
Ooooh That looks painful Maury, Do you have to replace the whole garboard or can you just remove a portion of it?
Michael
Maury
I agree with you Maury. As painful as it is to tear it out. If you aren’t happy with it now, you won’t be happy later. I think your new pencil line of the end of the garboard looks about right. The previous placement was too far forward.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
You might consider ending the garboard just forward of your pencil line so that it does not end at the keel/stem joint. See how many strakes will comfortably fit above that into the stem without needing a drop strake.
The forward planks down to and including the garboard have been removed and the re-shaped garboard planks are now in. I think I can leave much of the former planking in place.  Druxey, the re-shaping allows me to eliminate one of the drop planks.  These boats are so wide amidships that drop planks are the only way of keeping a plank no less than 1/2 the width at DF.
Maury
thanks Druxey.  This helps a lot
Maury
