Old Collingwood
Black Pearl by Old Collingwood - 1/72 Scale
Good day all,      Thank You sincerely  for all the  likes it certainly helps,     anyway  back on the pearl today  - nothing of  any significant interest,  I constructed the  nine rope lifting beams for the other side - just a length of 1x1mm  with a small block glued onto the ends, just need them to set now before drilling a hole in the ends.
No pics as  its just the same as previous pics.
OC.
Share this post
Link to post
Share on other sites
13 hours ago, Old Collingwood said:
an element of monotony  doesn't help.
Thought you were a big fan of those ... you do them so extraodinairy well ;) Now you've got patience as virtue too :D
Share this post
Link to post
i had the same issue of inserting all the sheaths above the gunports, and then securing the lanyards, it took me weeks, then i did them all again, because i i got better it showed up on the earlier ones, hence i vowed never to do another first rate again
and then what happens, Chris Watton, is designing new ships, so maybe there will be another one in the distant future, after the St Nectan
Share this post
Link to post
Mind you - not far to go now,  after I fit those and attach the ropes/paint them,   I can then move onto the anchors - im looking forward to doing the anchors.
OC.
Share this post
Link to post
Evening all, some good progress on the pearl today  - firstly I drilled out the holes in the hull, then I applied some glue and fitted the nine lid rope devices,  I then turned the ship around and tied the ropes together that I had fitted before  - just need trimming than painting.
OC.
Share this post
Link to post
Next I decided to tackle the little side project  - the pearls  small shore boat,   this is a kit in itself  and comes all together on a fret  with everything there,  first off  I cut both hull sides away and did a bit of tidy work inside and out to remove a couple of injection marks and to give the inside walls a bit of texture.
Next off I worked on the lower deck fitting - this was aslo worked on a bit then I applied a couple of coats of bluff paint, then after drying with the hairdryer I mixed up a watery mix of dark grey/black  and just brushed it on in a rought fashion  - several light coats with drying between coats, and the final result is a weathered old deck.
This is my current situation - here's the pics -
OC.
Share this post
Link to post
And how I like that weathered old deck O.C. I find it relaxing sometimes to "step away" from the monotonous and take on something rather different. The mind emerges out of that slightly dulled state and kicks back into life. Nice work sir.
Share this post
Link to post
Thank you wallace,   its turned out better than I thought - but its one of those things with weathering  - just do it in thin layers till you reach what you are happy with.
OC.
Share this post
Link to post
1 minute ago, Old Collingwood said:
Thank you wallace
Actually, now that we have become somewhat acquainted ( :) ) I can tell you that my name is Mark. That user name was already taken when I joined here so I took the next best name - my Labrador, Wallace.
Share this post
Link to post
Indeed, strange they may be, but they do look great!
Nice start to the boat as well. The weathering looks good and will look even better once the hull is weathered up a bit also.
Share this post
Link to post
Thank you sincerley ej,   yep  the rest of the boat is being painted/weathered  black/grey and shaded with buff/white.
OC.
Share this post
Link to post
Since thanks for all the likes and replies.
More work on the wee boaty  -  I  painted the grey/black all over,  then when dry I highlighted  ontop including the top framework and a slight amount to the bottom deck section,   then I glued the lower deck inplace followed by the top framework.
Just a few pics to show this stage.
OC,
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
The Guild is a non-profit educational organization whose mission is to provide support to our members in their efforts to raise the quality of their model shipcraft.
The Nautical Research Guild puts on ship modeling seminars, yearly conferences, and juried competitions. We publish books on ship modeling techniques as well as our world-renowned quarterly magazine, The Nautical Research Journal, whose pages are full of articles by master ship modelers who show you how they build those exquisite details on their models, and by maritime historians who show you what details to build.
Our Emblem
