Red Jacket by MrBlueJacket - FINISHED - BlueJacket Shipcrafters - Scale 1/8" = 1' (1:96)
Shipyard work soothes the soul..... Can't wait to see how you affix the bowsprit.
Rob
Current build:
Finished build:
Current build(On hold):
Link to comment
Share on other sites
Nic,
On behalf of the Connecticut Marine Model Society, our members wish you a speedy recovery. It was just a few years ago that you were our President!
Your latest build is looking great.
Best Regards to You, your Family, the "crew" at Bluejacket.
Ron
Secretary, CMMS
www.ctshipmodels.org
Ron
Director, Nautical Research Guild
Current Build: Godspeed 2, (Wyoming, 6-masted Schooner)
Completed Builds: HMS Grecian, HMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
Link to comment
What a following
Current build:
Finished build:
Link to comment
So it's time to install the outriggers for the main braces. The instructions say to drill a hole, then use a sharp blade to square out the hole for the outrigger. In a moment of inspired laziness, I figured it would be easier to round out the square piece than to try and square out the hole. Worked like a charm.
Link to comment
Time to start the rigging. Normally, I step all the lower masts and add the shrouds and stays, then work my way up. However, the instructions say to build the masts and rig the upper parts before putting mast to the deck, claiming it is easier. I will try it on the foremast and see if I like the method. Here is the foremast, finished and ready for some thread.
Link to comment
Nic,
  That’s an awesome looking model!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
So now I'm into the ratlines. It's about a wash as to whether it is easier on the model of off the model. Notice that to get the mast to stay at the correct position, I had to use a couple of clothespins to stabilize it. Also, putting a white background behind the mast helps my aging eyes.IMG_2983.thumb.jpg.8508599587addbfff6a98398a785f3fa.jpg
My opinion of ratlines is like forming the deadeyes (see page 2) "it's hours of great fun"
Link to comment
So good to see you back and at it hard.
Several questions if I may?  How did you apply your mast straps(what are they made from?)
What is going on with the top mast at the doubling......It appears to be resting on a square post?  Is this the simulated stepout the mast head would have to accommodate the lower shrouds?
And does not the instructions call for double deadeyes and lanyards for the top shrouds?  Some rigging diagrams call for simple bulleyes and stropping...much like what you created.
I'm assuming the Redjacket had varnished masts and yards.   Your work is wonderful and vary clean and tidy.
Rob
Current build:
Finished build:
Link to comment
Rob
Let's answer these in order:
mast straps are 1/16" black vinyl tape, once they were all on, I sprayed flat clear over them.
Yes, that is the bumpout for the shrouds.
Instructions and plans are for single bullseyes for the upper shrouds.
Instructions say masts are dark brown, but since they  were probably greased, and since I did the red bottom it would be her maiden voyage (she was coppered after she arrived in England) I thought a little lighter finish would be appropriate.
Link to comment
Great job on the offsets....I like the method described...seams very easy....short of turning your own masts with offsets within them.
I also like building the masts and adding the ratlines for the top and topgallants off model.  I found it far easier to rotate and do the miniature work in its own fice...giving far more access and ease of work.
Then you can place the masts and add the main shrouds.  Here's a pic of mine done this way before yards and sails.
Rob
Current build:
Finished build:
Link to comment
Thanks Nic...I just thought it was easier to treat the shrouds/ratlines as part of the masts and them as one unit....so when I added the yards(Off model), everything would go together nicely and nearly complete.
Your approach seams similar....your channel/chainplate work looks very nice too.
Rob
Current build:
Finished build:
Link to comment
On ‎8‎/‎22‎/‎2019 at 12:52 PM, MrBlueJacket said:
Then I guess we have a mutual admiration society going here.........
I love clippers and I'm getting warn out on Cutty Sark examples.  Your Redjacket is done well and is quite refreshing.
Rob
Edited by rwiederrich
Current build:
Finished build:
Link to comment
Affixing the blocks will seam like the longest job you will embark upon...cuz there are just so many.  Especially if you are going to rig all your sheets/downhaul/lifts and buntlines.
And so it begins...…..
Good luck.
Rob
Current build:
Finished build:
Link to comment
Catching up...very nice results......clean and crisp work.
Rob
Current build:
Finished build:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
