Peter -- I like your idea of the shroud cleats -- it solves a problem of where to belay those cluelines, and is a lot neater than tying them off on the block.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Hi Martin
Yes, I just stumbled over that solution by chance and think it is quite tidy and easily done (and hopefully even historically correct).
Cheers
Peter
Next step is the making of the fore course and its attachment to the yard. It will then be fixed on its mast.
I will show the making of the sail step by step and hope to convince one or two fellow builders that sail making is manageable with a moderate effort.
First step is to find out the dimensions of the sail. I took a suitable plan sheet where all the masts and yards were shown. Usually the yards are shown in full frontal view and therefore the sails can be drawn directly into the plan.
For the head of the sail a parallel to the yard is drawn at the position where it would be with sails set.
The depth of the sail can now be found. The width could also be taken out of the plan but it must be checked with the actual yard.
At the head it must be a little less than the distance between the yard arm cleats. The width at the foot is the width between the cleats of the yard below. The foot of the main course is 2 clothes wider than the head. The fore course has parallel sides. The width of one cloth is between 24 and 30 inches. I took 10 mm which corresponds to about 25 inches.
All those and a lot more details can be found in James Lees’ The Masting And Rigging of English Ships of War.
My sails are simplified because in furled conditions hardly any details are visible. The seams are pencilled on (on both sides) and no linings or bands are shown. The boltrope is not sewn onto the edge of the sail but glued into the hem – in this scale the difference is hardly visible and the result beats any of my clumsy attempts to sew a rope onto the edge. Also the foot of the sail is straight – no curve is necessary.
Finally the size of the sail is reduced by 30...40% to produce less bulk on the yard.
For the hem I ad about 2,5 mm around the sail. This is rather wide but some extra width is needed to fix the boltrope inside the hem.
Sails pencilled into a plan sheet
Sail drawn
Check with the finished yard(s)
Sail pencilled onto the fabric (both sides!)
The sailmaker has the sail ready for hem and boltrope
Me too, B.E., me too. Still it looks a bit hazy and things are hard to see in that great distance. But I will stubbornly continue like the one and only CAPTAIN Jack Sparrow: Towards the horizon and beyond…
Cheers
Peter
Now the hem with the boltrope inside was glued.
To lessen the bulk of the furled sails the rope was only included where visible: along the top edge and the two lower corners.
The holes for the robands were made with a large pin and finally the whole glue fixed with a hot iron.
According to the manufacturers information this should make the glued parts washable but in fact it’s only marginally water-resistant. Furling the sail would be easier when the fabric is damp but I have to be careful when applying water in order not to dissolve the hem.
Boltrope parts for the top edge and the lower corners were prepared
Top edge being glued...
...and finished
To form the head cringle the top boltrope is pushed back into the side hem through a hole
Preparing one side
Gluing it
Pushing holes for the robands (2 per cloth)
The sail maker is closely checking the finished sail
Mere mortals look at this in awe :).
Cheers
Alistair
Current Build -
The sailmaker is doing a good job Peter
Nils
Current builds
-Lightship Elbe 1
Completed
Peter -- your photos are great at showing the successive steps in getting those sails looking right.  And that sailmaker is probably going to need even bigger muscles to pick up those scissors!!!
But wait a minute -- Jack Sparrow?  What about Lucky Jack Aubry?
Cheers,
Martin
Thank you, Alistair :blush: :blush: :blush:
Yes Nils, I’m very glad to have him. Just think of all the work I had to do myself otherwise…
Martin, you are right, of course. The Captain Jack appearing occasionally in my pictures is blond haired (not grizzled yet) and a regular sea officer but sometimes one fails to ignore that other likeable ruffian.
Thank you all for the comments and the likes.
Peter
After a longer brake for some gardening, hiking, holydays on Mallorca B)  and even some genuine work (flying) I found finally some time to spend with the little helpers in my wharf.
The sail was bound to the yard. I tried to do it as close as possible to the description in Lees’ book. It is repetitive work again but much, much faster done than ratlines.
Sail at the yard
Now all the lines had to be attached to sail and yard. Again only one end per side of the double buntline could be fixed as it leads trough several blocks before returning to the foot of the sail. It can only be finished after fixing the yard to the mast. This time I even thought of attaching the parrel ropes before furling the sail – much easier that way.
All the lines, including parrel ropes attached
The sling was also prepared and its parts fixed to the yard respective masthead.
Parrel ropes and sling on the yard
Sling lying on the sail
Ready to furl
Now I furled the sail by first pulling it up with the buntlines over the front while leaving the two edges protruding. Then it was rolled up – again over the front of the sail – with the help of clumsy fingers, pincers and censured language and provisionally held with a few strings.
Provisionally furled and bound with a few strings
At length the sail could definitely be bound. Working again from the ends to the middle I tried to tighten the sail even more to create a roll as small as possible. By working towards the middle I tried to get a visible bulk there. Dampening the sail carefully where the gaskets became to hold it helps. While furling you have to check constantly the correct run of the attached lines. A few gaskets will nevertheless have to be tied twice because something is always overlooked.
Sail furled
Now the yard was brought to the mast and fixed there first with the parrel ropes. Blocks were spliced into the ends of those and a simple tackle set up with a block on a ringbolt beside the mast.
Parrel ropes and their tackles on both sides of the mast
I seriously have to think about adding furled sails now. They are a superb complement to the model. It is way down the track for me but with your log I have a reference back to it. Great work it looks amazing.
Cheers
Alistair
Current Build -
It's interesting that your process of furling the sail replicates the real act -- except that the spar is off the mast.
Nice work.
Martin
Hi Alistair
Thank you for your compliment.
Yesss! And all that masting and rigging work will suddenly have a raison d’être.
Take care
Peter
Hi Martin
Nice compliment.Thank you.
And yes, I try to follow the original way with the furling – except that I don’t try it balancing on a flimsy yard with 30m of empty space below and no safety lines attached. It seems the logical way and produces quite acceptable results with a reasonable effort.
Cheers
Peter
Thank you B.E.
Sometimes holding the camera somehow between all those lines while hoping not to tear one and trying to force to focus it on the part you wish to show while illuminating the model with all sorts of old leftover desk lamps and pushing the trigger blindly several times produces surprisingly satisfying results.
Cheers
Peter
So, to work through this analogy just a bit: there are aspects of photographing your build that resemble working the rigging without safety lines, eh?  :o
Cheers,
Martin
Very nice work Peter.  This is bringing back flashbacks of when I added sails to my Badger - some good memories, some not so good :)  What I remember is how much time all this detail takes to do, and yours came out very nicely.  I'll have to try out your approach when I add sails to my build.
Alistair, I'm a big fan of adding sails.  With your attention to detail and precise work, your Fly would look fantastic with sails.  It took me a lot of time to research and experiment adding them to my Badger, but I think it was all very worth it if not for the aesthetics, but also to better understand how sails operated.
Hi Martin
No safety lines and no wings either! Rather scary – but fortunately the feeling is scaled down to 1/64th as well. ;)
Cheers
Peter
Hi at-least-able-seaman Mike
Yes, improving the understanding of what you build is one point. And it never ceases to astonish me how they could sail such a complicated machine and even more often with success than failure.
Steven Maturin, I feel with you and all other landlubbers! :unsure:
Have you seen what astonishing things others do with their guns or their boats? Adding a little fabric seems comparatively easy.
Take care
Peter
After installing the sling and the lifts the next task were the buntlines.
I had only one end of them attached to the foot of the sail. The loose end was now thread through the block on the yard, the dedicated blocks under the top, through the upper of two single blocks stropped together head by head (similar to a shoe block) and back to the top and yard. This arrangement with the ‘shoe block’ is according Lees. A line leads to the lower part of the shoe block, hanging under the yard but close to the deck, with both ends belayed according the plans on the forecastle rails. I used a short end just fixed with a rolling hitch and a long end with a coil of line for working the whole arrangement.
The lose end of the buntline - after threading it through its block on the yard - was brought below the furled sail and then discreetly fixed around the yard as the correct fixing to the foot of the sail was impossible now. This should be overlooked.
The last line was the clue line. It was installed according to the kits plans.
Sheets and braces of the lower yards will be among the last things to be fixed as they will hinder the access to the deck too much otherwise.
Sling and lifts installed, the loose end of the double buntline still hangs over the sail.
The black clip holds the free end of the buntline, while the red in the middle ground hangs on the lower of the two blocks stropped together.
The incorrectly fixed end of the buntline.
Clue lines belayed on the bitts
Some adjustment of the sling is done
Scary work without safety line
The fore top starts to look businesslike.
That pin above the cap waits for the next task: Fore topsail yard with sail.
The rigging is coming on very nice Peter,
would love to see one or two sails completely rigged and set,
the ship Looks great as she is...
Nils
Current builds
-Lightship Elbe 1
Completed
Hallo Nils
Thank you.
And yes, I would like to see fully rigged sails done that way as well. That’s why I’m thinking of a small kit as a next project but with fully rigged sails. At the moment CC’s HMC Sherbourne is the favorite but Pickle or even Badger are not completely out of the race yet.
Cheers
Peter
Thank you B.E. Getting a compliment from somebody who is capable of carving a beautiful and completely detailed longboat in 1/64 out of a toothpick really is something. ;)
Cheers
Peter
Great and ambitious idea Peter,
whatever your choise, any of these three ships will look marvelous under sails, am curious already...
Nils
Current builds
-Lightship Elbe 1
Completed
Very tidy rigging, Peter.  This is a beautiful build, nicely photographed.  The figures complement the sails and all the other fine details (in particular I have to admire the line belayed on the bitts -- just the right amount and nice volume).
Cheers,
Martin
