Finally created my make-shift fume hood!  Not a modeling pic but was fun to make. 🤣
My wife made some draught snakes to seal up the window gaps for when I actually get it set up for external exhaust. 😊More pics to follow.
Moving on...👍🏽
Edited by Overworked724
“Here.  Hold my beer..." --- Common phrase uttered by Lord Admiral Nelson at any pub. 🍺
Better use some sort of drop cloth if not using acrylics.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Not certain what you mean, Kurt?  You mean to put on the floor?  Again - I am NOT a airbrusher or a painter in general.  (But I think I did a pretty good job on my makeshift airbrush hood...)
Yes.  At least in front of the table - spill some paint = BIG trouble.  If you are using acrylics your only issue is spilled paint.  Acrylic over spray will be dry before it hits the floor - you may need to sweep up some dust.   If using solvent paints  they are not always dry before hitting the floor and make sure the fan at the rear is explosion proof.
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
I see. Thanks for clarifying. I have some painters drop cloths I can use.
Tried applying and sanding some wipe on poly (sanding between 3 coats) to assess how well the self adhesive copper plates adhere to the wood. Works really well.
Very smooth surface. Like a baby’s butt. 🤣
Used a 1/2” dowel with double sided adhesive scotch tap as my ‘peeling’ foundation.
Comes of fairly clean and uncurled.
Tried a simple swatch with blank plates. You can see the plate where I sort of ‘peeled’ the plate away From the backing by hand (circled in yellow). The crimping of the foil happens quick and can’t be undone.
Nice thing is you can remove the paper backing and reuse.
11 hours ago, RichardG said:
When doing my coppering, I found peeling the paper away from the copper worked better.
Well, I tried that but couldn’t find a clean way of doing it without crimping the foil. I saw the video a few times which I posted earlier and tried it that way. But I always ended up crimping the trailing corner as I peeled the paper.
Guess it’s all in the technique. 🤔
I certainly wasted quite a few initially and occasionally later when I wasn't paying attention.
I found that bending the paper almost into a U shape when I got the first 1/4" peeled off worked best. So I'd hold the peeled end of the  copper between finger and thumb of my left hand (I'm right-handed). Then support the copper with the middle finger (to keep it flat). Finally peel the paper off using my right hand finger and thumb.
Richard
Current Build: Early 19th Century US Revenue Cutter (Artesania Latina "Dallas" - messed about)
Completed Build: Yakatabune - Japanese - Woody Joe mini
Member: Nautical Research Guild & Midwest Model Shipwrights
2 minutes ago, RichardG said:
...found that bending the paper almost into a U shape when I got the first 1/4" peeled off worked best. So I'd hold the peeled end of the  copper between finger and thumb of my left hand (I'm right-handed). Then support the copper with the middle finger (to keep it flat). Finally peel the paper off using my right hand finger and thumb.
Hmmm. That sounds simpler. Will give it a go!!!
Well, some slow progress between meetings.  I did manage to put a couple coats of wipe on poly on the ship. I mean I know the surface isn’t perfectly smooth, but a couple light coats of poly with sanding in between really smoothed out the surface.  👍🏽
Moving on....slowly...:dancetl6:
Looks great, Pat. The idea of using wipe on poly and lightly sanding really added a whole other dimension.
Previous build: NRG Half Hull
Previous build: MS Bluenose
Right!?  Too bad I’m going to stick copper all over it. 😂 I just wanted to ensure I had the smoothest foundation  before putting on the plates.
I'm always torn when it comes to covering natural wood with anything other than clear or tinted poly.
So much of my Bluenose is painted and there have been times when I wished I'd left it natural.
I know the plans call for the paint and it should be painted to be historically accurate. But at the same time I occasionally think this is my model and I can finish it as I please.
Totally true. If not for the poor planking job and tons of obvious wood filler, I would forego the coppering. But, as I’ve never done it before, I figure it’s a great learning opportunity. 👍🏽😊
That's a great way to look at the coppering. And I know exactly what you mean about the hull planking. Black paint covered my errors and filler.
Spent some time finishing up painting the upper edges of the gun port sills. No more red paint for a while thank the Lord.
Got the rough prep of the bow margin planks done. Not a bad first try.
Moving on...
Patrick
she's looking very good I like you margin planks and the scarf looks nice equal on both sides Port & Starboard. I notice you went with a darker red paint I like the darkness not a over bearing red color that's why I went with vermillion red with a little brown.
Now the belaying pins per Thomas he dropped me the not and the photo is in his log posting #600. It really helped to have a sketch with dimensions in front of you so you could eyeball the distances.
Hope this helps
Stay well and stay safe
Wii
HM Cutter Cheerful  Syren Shipmodel Scratch 1:48 scale
On Hold:
Syren by pearwill Model Shipways 1:64 scale
1776 Washington Row Galley scratch scratch from NRG plans #121  1:48 scale
Completed Build:
Erycina 1882 Fishing Trawler by Vanguard Models 1:64 scale
Charles W. Morgan by Artesania Latina circa 1988, Lowell Grand Banks Dory 1:24 scale by Model Shipways, Norwegian.Sailing Pram 1:12 scale by Model Shipways, Muscongus Bay Lobster Smack 1:24 scale by Model Shipways
Your paint job looks really good! It may not be your favorite occupation but the result is very convincing 👍
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
2 hours ago, Gahm said:
Your paint job looks really good! It may not be your favorite occupation but the result is very convincing 👍🏽
Thank you, Thomas!  (But I have yet to attack the black stuff. 😣). Step by step!!!
I’m not a paint expert either, but I am reading that some polyurethanes and acrylic paints don’t play well together.  If your poly goes up to where there will be black over it, you might want to look into a oil based primer after scuffing its down some.
“The sea, once it casts its spell, holds one in its net of wonder forever.”
― Jacques Yves Cousteau
Work in Progress: US Brig Syren
Completed Works: Thermopylae
That’s a good point @Jamie Coleman . I believe I should be ok on that score. The poly stops just a smidge below the waterline so I should be coppering over a bit of the black paint. At least that’s the plan. 😊
Decided to take a side trip into the carronades...again.  Like others, the metal fittings in the kit leave much to be desired (being kind here...they suck).  The carronade wheels and brackets are metal - and like all other metal bits in the kit look like they've been sandblasted.  I decided I'd try an idea I had when making my bulkhead blocks containing the sheaves made out of sculpy.  I thought I could use a similar technique for the wheels for the carronades.  The problem was how to make the wheel brackets.
I decided to try using 1/16" (1.588mm) scrap piece of boxwood.  I planned to cut grooves using my table saw into the edge of both sides of the boxwood  and keep the grain horizontal to keep the grain in the right direction for cutting the multiple brackets.  I would then have a stock piece to cut multiple wheel brackets reproducibly.
BD9113E9-6C14-49B6-B7AD-9B2B7D33AB93-16771-00000960203EF872.JPG.047d8f6984dea50bc9444fceb8064ddc.JPG
1D871AA8-DA81-43AE-8393-6C8E6180DE02-16771-00000960209FE55D.JPG.16029f3ab3bd135c55004bb075d66c07.JPG
I knew my wheels would be exactly 0.95mm thick and 2.4mm in diameter (I'll explain later). I set up my table saw blade height to 2mm, and cut 1mm thick grooves in each side of the strip.  The strip itself was 9.9mm wide.
ED162629-AD23-408A-9AA1-76907BE3D896-16771-0000096020F3576C.JPG.a6274a20161a5d6a85e102fc8dea3d03.JPG
E2A56A3C-21F4-410A-96C1-058326BD511D-16771-00000960213D3FBE.JPG.9d9e32af98d3dff7ff493dd16fdb6de8.JPG
I then cut a bunch of 2.25mm wide sections from this stock strip (I think I cut about 20 or so).  These would make the wheel brackets.
F4C91936-6792-4424-8D62-B62D2F152B26-16771-000009602185924B.JPG.845507c3b4a9ac42bcef76e934605bd5.JPG
8E692251-B11F-4106-BE9C-8E2A5E54EF12-16771-0000096021D0BB50.JPG.c40258f31e04f3dbb2e4c46a0e2ed15a.JPG
I took off the corners with a 600 grit emery board.
1F4E65B0-9510-49AC-AEEC-FE8EC43ABB08-16771-00000960221E19AD.JPG.4fe2a3bad77b9d23c2a25adacf026187.JPG
Now...the wheels!  This was fun.  The wheels I measured to be about 2.4mm in diameter...which is exactly the width of a 3/32" drill bit.  I had a piece of metal which was about 0.91mm thick, and cut the 3/32" hole in it...and polished up both sides.  I put wax paper underneath the metal 'mold'.
9094F59B-8173-4934-A5DD-8699E7EC29EA-16771-0000096022BBECEB.JPG.ebd4efd958e033044a95179febcfc64d.JPG
I took some black sculpy...warmed it up in my hand, and smashed it into the 3/32" hole with my thumb!  I was not gentle.  I shaved off the remainder with a straight razor (just running it along the surface to cleanly lift up the excess sculpy)...this left a 'plug' of black sculpy stuck in the hole.  I used a tooth pick (cut flush so it had a nice flat base and fit perfectly into the 3/32" hole) to push out the 'wheels'.
D86AF5BD-5C3E-4049-A92E-CBAA98A3C938-16771-000009602304933E.JPG.7fb7d7371d44da8b01ec9a83faf72334.JPG
000445CB-FB70-4FC3-838D-ACE43848D804-16771-00000960234C90D2.JPG.3da11f635128d3bb455bde7e869e6f1c.JPG
284B5F10-4CD9-4CC5-9A6A-2DF26A115F9B-16771-0000096023954C39.JPG.37272dda2f1db71b037827e2b9237bd1.JPG
Like all sculpy - cook at 275 Degrees (F) for 30 minutes.  And....Voila....the proof is always in the pudding.  A bit of superglue (medium gel - slow set) and the wheel assembly is ready to paint (or stain....haven't made up my mind) and slap on the carronade sled.
879C4D04-41E2-48F8-BE23-30AE8CB26E65-16771-0000096023DE852A.JPG.7e525191d6fcb29f1ae82640aa25f49c.JPG
36DE81DC-9C6D-4C8E-8282-8F56AF1840B5-16771-00000960241CB280.JPG.ca82a153d475e63fffc5b4db7f00829a.JPG
I've made enough brackets and wheels to make the wheels assemblies at a later date when it's time.   Procrastination can be a wonderful thing when it's masked as something productive!
Moving on...again...
:dancetl6:
So much better than the castings!! Really nice! I was speechless for a moment when I saw your post at first and had to gather my thoughts 😅
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
Thank you!!!  😃.  LOL. This was a fun work around...and I appreciate the kind words!  (Besides, I watch your and other builds like a hawk, and you guys really inspire me to think outside the box!!)
