Thanks for the comments and likes guys, I was about to abandon the whole gun rigging process but finally getting one finished the way I wanted it, inspired to me keep going...at the expense of setting back chapter 7 for a very long time. Lol. I’m going to get started on another one soon, hopefully it will get easier.
Glenn, I think I understand what you are saying, I’ve seen both examples online. I’ll post a photo of my next one when I start. Would it just be crossed and that’s it? No seizing or smaller line to at all to keep the loop crossed? Would that be standard on a 12pdr?
JJ
             Portland Scale Ship Co.
I’m certainly no expert and I’m sure however you want to do it will turnout great.  From a model perspective I doubt just crossing it would stay in place, either a small seizing or a dab of CA.  Hopefully people smarter than me might have a suggestion. I’d not seen your way before now, which doesn’t mean anything I see something new on this forum all the time.
I admire your goal to rig them all, it will look great.
Regards,
Glenn
Current Build: HM Flirt
So I’m hoping someone smarter than me chimes in as well! Haha.
so after examining a few logs I came up With that method, I mostly borrowed from Fred’s log @jfhealey and From what I could see that is similar to how he did his breech lines.
maybe Fred will chime in with some advice?
JJ
As to the breech lines: JJ managed to get 5 or 6 windings beneath the knobbly bit at the back of the barrel (I'm sure I know the  name but I'm having a senior moment about it at the moment). I'm seriously impressed with that.  I got 1  - and that with a needle and thread. There is much less room there than appears to be the case from JJ's pictures. I shall try harder next time!
My only tip, if you are going to rig your guns, is to rig the  bolts to the gun rather than the bulkhead. Fixing the rigged bolt into a pre drilled hole in the bulkhead is the work of a moment. Rigging the breeching rope (or the tackle) to an already fixed in bolt is a nightmare. I know this from experience.
As to the tackle: I'm sure coiled down tackle is authentic. But was it, I wonder, Sunday best for the Captain's inspection? I can't believe (not that I know a thing about it) that ropes were coiled down like that everyday. On a model I guess it's a matter of  what you (unless you are a stickler for historical accuracy) like the look of. "Frapping", by a short head, just looks tidier to me. But lots of you have left your guns un-rigged as of course did Chuck - and you can't really argue with that can you?
Other than that I know I have a lot of work to do on my knots and splicing. But for a first go at rigging guns I'm pretty satisfied.
All the best everyone.
Fred
Are your ropes crossed and then seized?
I’m sooo far from doing guns….
Edited by glbarlow
Regards,
Glenn
I think Chuck described frapping in an earlier post as a method of securing the lines on museum ships so folks don’t trip over the lines while walking the gun decks.
as far as the breech lines being cross looped or seized as I have shown, I’m still unsure, which is fine as I have to wait for a bunch of hooks to show up before I continue with hun work. Fred...where did you come up with your breech configuration?
Glenn, you’ll be there before you know it, you’ll succumb to the desire to rig them. Lol!
Check with me in a about a year 😄
Regards,
Glenn
On 3/16/2022 at 9:04 AM, Guillermo Eduardo Madico said:
Hello JJ,
Great job!  I think you got those at the correct scale. Would you mind sharing the block and rope sizes you used?
G
Guillermo @Guillermo Eduardo Madico
Per Chucks recommendations, this should get you everything you need to rig your guns.
i also just ordered a range of photo etched hooks from crafty sailor (3,3.5 and 4mm), I will use whatever fits the best.
https://craftysailor.com/collections/fittings/products/hooks?variant=32532830486616
JJ
I hope those hooks work out. I’m all for making our own hooks but the ones needed for cannon rigging would just look out of scale for anything we could practically make. I will vicariously enjoy the rigging watching yours develop 😊.
Regards,
Glenn
Judging by how your guns turned out on cheerful, these will definitely work out. My poor attempt at them can’t even compare to these. Once they are blackened and seized to a block, they will be very convincing. 🤞
56 minutes ago, Guillermo Eduardo Madico said:
Thank you JJ,
Much appreciated,
G
Looking forward to seeing your guns G, you’re Winnie is looking great!
6 hours ago, Nunnehi (Don) said:
JJ, I used the Craftysailor hooks on mine and they look great. Don’t remember which size, but just picked the one that looked like the proper scale.
Your build looks really nice!
Don
Thank you Don, your Winnie is coming along very nice as well. To me it looks like you used the 3.5 or 4mm ones, they do look really nice! Looking forward to their arrival.
Two down...22 left to go! The crafty sailor 4mm photoetch hooks were a success so far, except I rigged one tackle backward... won’t make that mistake again. I’m going to try another method to fasten the hook to the block, I think I may have gotten it to close. Other than that, I’m pleased with the results. I’m getting better as I go but still seldom find time to work on my winnie, maybe I’ll schedule a vacation somewhere and pack the model up and go!
Building this model as we know requires patience and perseverance. Rigging all the cannon doubles that requirement, well done. Not to set you back, but it’s not 22 more it’s 30 including the eight on the QD 😊
Edited by glbarlow
Regards,
Glenn
Way to take away my steam lol! Well at least I get to skip the two in the back and the two way up front!
1 hour ago, Chuck said:
Its 24 on the gun deck and 8 on the qdeck......total of 32.   But then there are ten swivels yet to come.
🤦‍♂️Lol I’m trying to trick myself with the numbers! One deck at a time.
15 hours ago, Nunnehi (Don) said:
Beautifully done, a tutorial on how to rig these properly!
Don
8 hours ago, FrankWouts said:
Very beautiful done and a tutorial howto rig them.
Frank.
Thanks Guys, I appreciate it. I’m not sure, but were you asking for a tutorial on how I did the guns? Or just stating that I already did it?
5 hours ago, glbarlow said:
I understand I’m about one millionth done with planking
Your planking looks soo good though! I don’t want to distract you from that! It will come
together before you know it. This build is just a series of milestones.
My comment was that you’re showing us how it should be done. I’ve only rigged a couple and may go back and redo them based on how good yours look - thanks!
Don
Thank you Don!
I definitely studied your guns as an example to follow  prior to starting mine.
You already did with your pictures.
Frank.
Current builds on MSW:
HMS Winchelsea 1:48
Prior builds on MSW:
None
And then there was six of them.... 30 something more to go!!
as soon as I get six completed on the port side I plan to take a gun break and start my long awaited chapter 7 and also pick up and finish my lighting project, now that I can hang the individual lanterns.
