thanks Frank........good to see your around  :)    I appreciate the thought........but I'm still being careful.   one slip of the knife,  and it could become a scow  :)   are you working on your build my friend?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nice job with the planking!
Tin
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Planking looks really really good Popeye!!  I have yet grasped the whole idea of planking and much of mine is faked with plenty of putty and sandpaper!!    Yours however,  very very nice!!
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
mine ain't no walk in the park either...........most of my builds are painted.   the only one that is a wood grain hull is the Gothenborg,  and I second planked that one.   there's still a couple of flaws........if you look in the right places :)   to be able to single plank the Half Moon...I hope I can get it right ;)     I still use the putty........one of these days,   I hope to attain the level that I see some of them done in.   work in progress  ;)   thanks Adam !
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Just catching up Popeye, making very progress my friend, deck and hull planking look great.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
thanks Mobbsie........I wish I had something to report to celebrate your return.   I hope to have the planking done soon.....then on to sanding ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thanks Aldo,   it's a work in progress.  I really need to get her fully planked,  so I can see where I stand.  this kit is rather vague about a couple of aspects..........good that I see them now......but the areas in question have already been done.   no matter.......they're still making x-actor blades and drill bits!  LOL!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
just a small update with this build......but first,  I want to show you sort of a review.
see anything odd here?  back when I did the bow rabbits,  I should have seen this.......like how far the first rib was to the rabbits themselves.    it might be hard to see,  but it equates to about 1/4 of an inch.
a more recent picture........what do you see?    you can clearly see the shortcoming with the first rib,  but what about the second rib.....it's off too.   since I have pre bent my planking,  the first rib is not that big a deal......leading off from the bow rabbit,  the contour is ocurring,  none the less.   but,  the further down I planked,  I found that the planks kept wanting to pull away from the second rib,  no matter how much I tapered.
to remedy this,  I made up a pair of fillers to bring the line consistant with the keel.
this picture really shows how far off the first rib is.....it will get buried with no trouble at all.   these fillers {at least the starboard side at this time}  seem to do the trick.    the starboard side is done now.  once the port side is done,  I can do the final tweaking.
I did have to use a little filler,  it's ok though,  since the bottom below the waterline is to be painted a darker color.......although I have seen a red bottom.   I will do a bit more surfing to make sure of the color,  but none of this will be seen.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Planking and fix worked out great!!
Really nice stuff!
-Adam
-Adam
Current Builds
Completed Builds
thanks Sjors and Anja....I'd say it's a little of both........what would be considered a small design flaw by some,  and me,  with little experience with this type of hull.   no excuses.......just an assessment.   I will fix it though........no hull will be left behind  ;)
thanks to you as well Frank,  Adam,  and John.......you folks are too kind :)    I have the starboard side done as you can see.......I really like how rounded it came out.   so far,  the port side is coming along well...the contour of the bow is matching perfectly.   hopefully,  I can get the planking finished soon.
thanks again for the good word folks......I'm still having fun!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Good catch and good fix, Popeye.  Another builder would have tossed the whole model at the point of "oops".  Planking is still looking great.
thanks Mark.......When I got the kit,  it was duly noted that there were parts missing.........so it was orphaned from the get-go.  since all the major hull part are here.......heck,  I might do well to build it and have fun with it  :)        I know what your saying though,  I'm hoping that someone who has built this kit before chimes in and tells me how their build went.  I'm interested to see if they found the same problem.
     the parts that are missing equals one complete part's panel,  so this tells me that someone got shorted with their kit.   the hull will come out,  but I'm finding the same problem with the port side,  so I'm thinking that the first two ribs are off in dementions towards the bottom of the hull.   the upper dementions are ok.......or I wouldn't have been able to plank the bulwarks and fore cabin.
I have three planks on her at this point,  and it's beginning to ocurr again......the plank wants to pull away from the rib.  I'm doing this without the use of joggers,  and with tapering the plank,  I can steer the planking as to where I want it to go.........I can achieve the curvature needed to follow the bow rabbit.  as long as I keep the start of the plank perpendicular to the rabbit,  I can compensate the run.
nawwww!  I can't throw it out now.........what fun would that be?  true.......my inventory would look all the better for it......but I would end up feeling like I've forsaken it........a kit is a terrible thing to waste  ;)
I'll whip this bad boy in shape!   I'm one of those thick headed yankees.......never could figure that out.......we are yankees.........but we have red sox........we're suppose to hate the yankees.  I'm not a sports fan.....I'm doing America's REAL past time right here! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye,
It doesn't matter what color sox you wear, you're still doing a fine job.
Bob
Current build:  SS_ Mariefred
Nice work Popeye the hull looks pretty clean to me.
Michael
thanks Bob.......I'm bare foot'in it today!   when i was a kid.......it was hell keep'in shoes on me  :)
thanks Michael........just hoping I can get the port side the same as the starboard....so far.......so good  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Popeye,
With your skills mate there aint nuthin you cant fix, you've made a great job so far.
You love and respond to a challenge so I have every confidence that this will just be another Popeye triumph.
Hang in there mate
mobbsie
mobbsie
Next Build :-
thanks Mobbsie and John..........not much more to go,  I'm almost there ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Carry on, Popeye - she is looking nice!  No doubts from me whether you can work your way through the challenges - with or without socks.
From one Swamp Yankee to annudder - HAVE FUN!!!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
fist bump! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I didn't win the lottery............400-some odd million!......three winners!  what I coulda done with a cut of that!   I'll just keep trying.......one day my ship will come in ;)
you probably heard it from some of my other builds Andy.........;)
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Popeye
Nice progress on the Half Moon, you make good fixes to. ;)
Børge
Current build(restore, bashing)
BB582 "Dragen" Scale 1:12
On hold: BB534 Bolougne Etaples Scale 1:20
Not started: Model Shipways MS2040 USS Constitution 1:76
:piratebo5:
thanks Borge..........looking forward in seeing you back in the workshop  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
