Whew! Well done, Edward. You have the hands of a surgeon! Glad the operation was a success.
Jim
Current Build: HMS Winchelsea, Model Shipways Mayflower
Completed Builds: NRG Half Hull Project
                                   Model Shipways 18th Century Armed Longboat
                                   Dumas 1954 Chris Craft 36' Commander
                                   Dumas 1940 Chris Craft 19' Barrel Back
Great save Edward! 👏
Jack
Current buildUS Constellation
That’s quite clever, removing planks without damaging others. I’m sure you are happier with the result.
Regards,
Glenn
Current Build: HM Flirt
With the remove and replace work done, I gave the whole deck another good sanding. 20230224_170419.thumb.jpg.49f6893815058ef50f77bb17d4431286.jpg
and a coat of WOP 20230224_170442.thumb.jpg.31f59638934436c37b47bf486a0d2741.jpg
As can be seen (or not, as intended) the remedial planking worked.  No unsightly overly dark planks😊20230224_170449.thumb.jpg.9b4510ca69d84067094629e50fecd3f1.jpg
I still need to do the detailing of the patners and the waterway. I yet to find a satisfactory method of shaping the waterway. I shall try and get these jobs started over the weekend, then onwards to Chapter 5.
Thanks once again to all who gave advice and removal methods, all of which helped enormously.
Also for the likes, comments and popping in.
Cheers
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Edward, that looks beautiful! A bit of a stressful detour for sure but an outcome to be proud of and I’m hoping you are happy with. I certainly would be!
Jim
Jim
Thank you Jim, to say I am pleased with the result feels a bit of an understatement, but yes I'm very happy how it turned out.
Current builds;
Completed:
I agree 👍  Looking real good !
Jack
Very nice looking deck. The result is definitely worth the effort to replace those planks. Well done!
Regards,
Glenn
24 minutes ago, scrubbyj427 said:
26 minutes ago, scrubbyj427 said:
Nicely done Edward! Perhaps you should have been a surgeon!
Thanks, I don't think I'd have the nerve to be a surgeon, that's why I became a bricklayer😁
Thank you! Watching you do your Cheerful, made me realise removal and replacement was all for the good.😉
Current builds;
Completed:
With the deck done and finally just going with something approaching a quadrant profile for the waterways, I've moved on to the rudder.IMG20230310200205.thumb.jpg.39365aff0fba5c66fc868177370f5b82.jpg
I had a mishap with topmost bracket on the sternpost, as in breaking it getting it from the fret🙄.
With the hole in the counter drilled, I fitted the cabin benches.IMG20230310200025.thumb.jpg.3f606fcbe84817b81acc612d2b2f9c6d.jpg
Also a start be was made on the gun port lids. Inbetween all this I'm also making up some eyebolts and split rings. I tried Glenn's (glbarlow) method for the eyebolts, not a great success for me, I could not make them consistent, so I went back to the twist method.
Thanks for all the comments, likes and dropping by. All is greatly appreciated.
Cheers
Current builds;
Completed:
Looking good Edward! You are moving along indeed, you’ll be past me next! Haha. Gun ports are fun, I spent a lot of time trying to get them right. Next time I build gun ports I decided that I will do them during the planking process and use the same planks as I'm using on the hull so they match better. It looks like you’re off to a good start on your ports.
I know what you mean. I saved all the offcuts from the hull planking, even the very short ones, now I'm glad I did not throw them out.
I'm definitely having the ports open as a couple of them are very oddly shaped🤔
Current builds;
Completed:
Smart move. I quickly realized that I should have done that. I made it work but it just would have been better to take care of it early on.
it is nice that they remain open except for the four (2 at the bow and stern), its an offer of forgiveness for one’s gunport assembly sins! Lol.
Just a small update, I've dry fitted a couple of ring boltsIMG20230311204402.thumb.jpg.7ba5ccd9316a88ef3f0cd72539e42ffa.jpg
Just to see what they look like on the deckIMG20230311204345.thumb.jpg.d117c77bdf6467fc4b9ce6619e02d3ca.jpg
I've used brass wire at .5mm, which according to the  conversion chart is equivalent to 24 gauge, and blackened IMG20230311204249.thumb.jpg.25d92ee149c0b68dbe782b53adc384c6.jpg
If I'm honest, I'm doing these, just so I can put off making the port lid hinges. I'm not sure how or where to start with those, even though I've read and reread the hinge bit in the monograph 🤷😬😕.
Any pointers be will be gratefully received.
Thanks once more for your comments, likes and visiting.
Cheers
Current builds;
Completed:
Cheers Dave E.
Not wanting to put it off any longer, I sat down with some brass strip and a flat file. The following results may not be perfect, but for a first attempt, well.....IMG20230312163647.thumb.jpg.8e9132ac05ed560de6db8bf1f444a7c2.jpg blackened makes them look a tad betterIMG20230312172249.thumb.jpg.7754d63d705380845a61a4510eb37e89.jpg
Need to make some small eyebolts and split rings now.
New skills being learnt, as I would have gone off the peg and purchased them before this build.
To everyone looking in, commenting and giving the thumbs up, many thanks.
Cheers
Current builds;
Completed:
Those look very neat Edward 👍
Andrew
Completed (Kits):-
Thanks to all for the encouraging comments.
Over the last week or so, I've made eight hinges, only 12 more to go, but I've only got enough brass strip for 9. The search is on for some more strip.
4 gun port lids have had their hinges fitted
I still need to make and fit the pivot for the hinges and remove the molding where the hinge will sit.
An order of .8mm wire has arrived, so I will make the larger ring bolts.
Thank you everyone who has commented, and for the likes, or for looking in.
Cheers
Edited by Edwardkenway
Current builds;
Completed:
Neat looking row of hinges!
Andrew
Completed (Kits):-
